MST Topology Changes
oldsk00l
Post by oldsk00l »
we have an Cisco2960s, 3750x and OS6450 mixed L2 network here. All switches are running mstp with same mstp config.
we often see STP Topology Changes on "show log swlog":
STP info Topology changed on VLAN/STP id 0
We would like to know the interface where the TC was received to find the root cause. (Like "show spanning-tree detail" on cisco)
Is there any command to identify the Port?
Or should we enable any advanced debug to see it in swlog?
THX!
Re: MST Topology Changes
in the newest releases (since ca. 1 year) you can see the source of the last tc-port with the command "show spantree cist". Before it was only possible with debug commands.
oldsk00l
Post by oldsk00l »
YES!
Topology Changes : 566,
Topology age : 02:08:08,
Last TC Rcvd Port : Slot 1 Interface 50,
thank you!
Return to “OmniSwitch 6450”
