Beginer questions for dect registration
Help Me!
I am absolut beginer. I search everywhre a corre ser manual or a step by step description, how to register a new dect on the system but nothing nothing nothin. User manual no just the help but that not enough for me.
Please tell me what am i need to do:(
- cavagnaro
Re: Beginer questions for dect registration
Download and read docs maybe? It is available on the forum. Search is a good option too.
Possible I am a donkey, but i find for this problem nothing for beginner.
yes is well documented in system doc
search for dectinst on command .
you should read
you should read
some command to tape and some keys combinaison to do in the mobile(dect)set
first of all you should creat dect user with the adequate set type(gap agap+ etc).
after that some command and some key combinaison (is on system doc)
Ok but where i can found the system doc? You want to say me read the help? I have now just the help but that not to correct for a beginer.
hi sysytem doc are avalaibl for download from this forum under
viewtopic.php?f=322&t=11726
select one target to your Release
when you launch the cd rom load_doc and
go under system documentation
go down to omnimobility
go down to dect
go down to dect again
go down to dect
Haroun this is a very good documentation thanks for this , but i have one problem this doc is omnipcx, and i have just omnivista 8770. You mean that omnipcx =omnivista?
- cavagnaro
Omnivista is only a configuration interface for OmniPCX Enterprise aka OXE
Hmmm ok now its clean thx. A queston possible connect/register a new dect with just the omnivista or need the command line? We would like to try a panasonic dect to register. The cordless phone say to me search te base station but nothhing found.cavagnaro wrote:Omnivista is only a configuration interface for OmniPCX Enterprise aka OXE
