Problem to install ACTIS in SO Windows 10
Ask your questions, regarding data or voice!
fabricio77
Post by fabricio77 »
I'm facing problems to install ACTIS 22-3-1-002 in my new notebook.
The setup run and the installation appears ok but when I try to use ACTIS I receive several error messages.
I downloaded the "Anomalies document" that said:
"5.1.1 ACTIS path management with Microsoft Windows 7, 8, 8.1 or 10
Do not install ACTIS in “C:\Program Files” directory, since it will not access to its internal database.
Database Error: ADMDB.MDB [FireDAC][Phys][ODBC][Microsoft][ODBC Microsoft Access Driver] unknown file
Workaround: use another path, example C:\Actis"
This workaround didn't work. I have a case opened but until now the problem still appears.
How knows how can I solve this?
Thanks in advance.
Re: Problem to install ACTIS in SO Windows 10
Make sure you install as admin
Return to “Pre-Sales”
