Hello Guys,
I have this issue but not too sure if it is related to CF or any other thing.
BootableConfigBackupFailed
Any idea from anyone and how to resolve this?.
Thanks,
Eagleman...
Re: BootableConfigBackupFailed
Where are you seeing this error? Maybe you can give a bit more context?
On the SAM5620 for the specific node. I suspect it is referring to CF3 but not too sure.
It's a problem with SAM either fetching the config from the node or saving it. So not a problem with the CF card on the node.
Description: The alarm is raised when the 5620 SAM fails to back up a set of NE configuration files.
Remedial action: Investigation is required to resolve the following possible scenarios: insufficient disk space is available to accommodate the NE configuration files (additional SAM platform alarms will accompany this alarm); the NE is unreachable (including underlying transport network issue); loss of connectivity to the NE during transfer; the FTP daemon on the NE may have stopped; FTP security credential issues.
Thanks a lot, I suspect the issue was along the line of your explanation.
Many thanks
Many thanks
