[ASK] Explanation About CPU Usage
thekotaksampah
Post by thekotaksampah » 29 Jun 2014 22:59
Hello guys,
I need your help, to explain the parameter who include in CPU usage parameter below this my documentation:
CPU Utilization (Sample period: 5 seconds)
Name                                   CPU Time       CPU Usage        Capacity
                                         (uSec)                           Usage
BFD                                          32          ~0.00%         ~0.00%
BGP                                           0           0.00%          0.00%
Cards & Ports                            28,685           0.57%          0.17%
DHCP Server                                 516           0.01%          0.01%
ICC                                       8,529           0.17%          0.17%
IOM                                           0           0.00%          0.00%
IP Stack                                 36,292           0.72%          0.51%
IS-IS                                    11,443           0.22%          0.22%
ISA                                       4,906           0.09%          0.06%
LDP                                      12,881           0.25%          0.25%
Logging                                     125          ~0.00%         ~0.00%
MPLS/RSVP                                 7,836           0.15%          0.08%
Management                               33,999           0.68%          0.40%
OAM                                       1,522           0.03%          0.02%
OSPF                                      5,303           0.10%          0.10%
RIP                                           0           0.00%          0.00%
RTM/Policies                                472          ~0.00%         ~0.00%
Redundancy                               12,107           0.24%          0.14%
SNMP Daemon                                   0           0.00%          0.00%
Services                                  5,858           0.11%          0.05%
Stats                                         0           0.00%          0.00%
Subscriber Mgmt                           7,894           0.15%          0.04%
System                                  166,260           3.32%          1.20%
VRRP                                      1,390           0.02%          0.02%
WEB Redirect                                890           0.01%          0.01%
Total                                 4,993,373         100.00%
   Idle                               4,633,468          92.79%
   Usage                                359,905           7.20%
Busiest Core Utilization                359,905           7.20%
What is the BFD, OSPF, ISS, ICC mean.. how can they make impact to 7450 cpu usage router. Thanks for your help :D
mivens
Re: [ASK] Explanation About CPU Usage
Post by mivens » 04 Aug 2014 03:19
BFD, OSPF and IS-IS are all routing protocols.
ICC is a protocol the CPM uses to communicate with the linecards. If a card becomes unresponsive, you might see an ICC timeout error.
In your example, none of the above groups are using much CPU.
Return to “7450 ESS”
