HI AND SORRY FOR THE DELAY , i's normal because it changes dynamicly ; IN THIS CASE you should play with Phone features cos i tray it and it works
but you should play with this cos according to the user because all users with same cos will be affected , someone can tolerate that bip but an other will ask to forbid it they shouldn't be in same PH FAC COS so they can only differt with this service but have common for others , again to assign permanantely u should move concerned users to another cos where u change only this parameters
Review/Modify: Phone Facilities Categoriesqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x x
x Instance (reserved) : 1 x
x Tel.Facility Category Id : 0 x
x x
x Rights x
x x
x Prot.against dir.call pickup : 0 x
x Protected against all intrudes : 1 x
x Protected against set intrude : 1 x
x Outgoing calls only : 0 x
x Forward to external No. : 1 x
x Prot.against multi-l ringing : 0 x
x Protected against forwarding : 0 x
x Protected against beeps : 1
and this is the meaning
x
x Protected against beeps : 1 Protected against beepsqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x x
x CANCEL to close this window x
x x
x Enter a character x
x within the following range: x
x '0' x
x '1' x
x x
x Protected against beeps x
x A set can be permanently protected against any call which generates a beep x
x during a current communication (camp on call on busy set, intrusion). x
x This function is particularly useful to protect a modem link (telefax, x
x minitel ...). x
x
OR WITH OUT PLAY with cos user can deactive bip when Calling outside (or Inside) by using prefix FOLLOWED BY the destination
wich i guess will not be confortable if he has to do it each call
view/Modify: Prefix Planqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x x
x Number : 714 x
x x
x Prefix Meaning + Set features x
x Set Facilities + Protection against beeps x
x x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqq
or while on incoming communication using suffix
On-Off Warntone Protection
Re: On-Off Warntone Protection
They have worked !
Thank you very much Haroun for your effort and help. Have a nice day.
Tell us how we use COS?haroun wrote: ↑01 Feb 2020 04:13 I'M USING TERMINAL BUT IT'S SAME WITH 8770
Users down hierarcy
Dynamic State User
review modifiy.
lqReview/Modify: Dynamic State Userqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x x
x [ All instances ] x
x [ Set filters ] x
x [ Select attributes ] x
x x
x Directory Number : -------- x
x x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
put the Dir number and hit ctl v
Rachat de crédit avec trésorerie
Review/Modify: Dynamic State Userqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x x
x Directory Number : 51009 x
x x
x Forward + No forward x
x Forward Directory Number : 51009 x
x Secondary Line Forward + No forward x
x Secondary Line Number Forward : ------------------------------ x
x Do Not Disturb + False x
x PadLock + False x
x Busy Camp On + True x
x Overflow on associate + False x
x Overfl.busy to assoc.set + False x
x Associated Set No. : 7400 x
x Reset Charge pulse Counter + False x
x Consistent with Identity + True x
x User Type + Administrative x
x State of the set + In service x
x SIP Survivability Mode + None x
x
when u change phone feature COS IT WILL AFFECT ALL USER WITH THAT COS so for whole userS u can use COS
mgr -l EN0
Select categories
you have 5 cos
any the case of this topic select phone facilities
select review modifie
the default value of cos will be displayd is C0S 0
HIT CTL v
to see all cos hit enter on all instance and ctl v
Select categories
you have 5 cos
HIT CTL v
