I have an OLD driver in hotel mode connected to an oxo and is working fine.
Last time it lost connection with the pabx because network cable was unplugged by mistake. So the calls being made were kept in the buffer of the pabx.
When OLD was connected again to pabx it began downloading the calls found in the buffer of the pabx but it was really slow, very very slow. Approximately a call every 5 minutes.
Do you know how can I force an immediate download of calls? or else can I delete all info in the buffer of the pabx?
Wallace
OLD Problem
Re: OLD Problem
Hello, i haven't had a problem like that, but i know that old has a .conf file where it keeps the configuration about this application. There is a parameter named buffer max size, perhaps if you can change its value, the application will be forced to send you the tickets in a fast way.
Check the info on this manual :
http://rich78.free.fr/ALCATEL/OXO/COM%2 ... n_ed01.pdf
Re: OLD Problem
Thanks for the info but i found that there was something wrong with the pc.
It was giving an error that c++ was shutting down due to an error. This was having an effect on the old software.
And the c++ error was due to .net framework missing or corrupted. After the reinstallation of .net framework old worked fine.
Wallace
Wallace
Re: OLD Problem
Glad to read the problem is no longer there.
