OXO integration and Break IN from PRI DID to Genesis Through SIP.
zaari
Post by zaari »
Hi Dears,
I have OXO 192.168.1.5 sending a registration request to the remote system (Genesis) on IP 192.168.1.50 on port 5065.
Genesis is send registration request on port 5065, will it work ?
i believe OXO is listening SIP registration on 5060 ... Any way to change the port from 5060 to 5065.
Secondly i want to route one DID number from OXO PRI to Genesis through SIP.
Advise the Break in Procedure. Appreciate your fast Response.
zaari
Re: OXO integration and Break IN from PRI DID to Genesis Through SIP.
Post by zaari »
SIP Port has been changed and SIP trunk is established. i am receiving the calls from Genesis but NO audio on Both Sides.
Transport Layer is TCP
Below are the traces of some calls made.
¡²ÃÔ ÿÿ \\Ë Ò5 B B €Ÿ¾aÀêä÷F E 4jk@ v^¬eÀ¨«ÛÄqɁ¸;° €Â žP \\Ë ÓB B BÀêä÷F €Ÿ¾a E¸ 4 @ @À¨«Û¬eÉÄq\Œ2}¸;±€Ð‹ ´\\Ë ¢Ç < < €Ÿ¾aÀêä÷F E (jl@ vi¬eÀ¨«ÛÄqɁ¸;±\Œ2~Pn* \\Ë ©w º º €Ÿ¾aÀêä÷F E ¬jm@ rä¬eÀ¨«ÛÄqɁ¸;±\Œ2~PRý INVITE sip:90552215570@192.168.171.219:5065 SIP/2.0
To: "90552215570" <sip:90552215570@192.168.171.219>
From: "poc" <sip:065982528@DCHQZCCV01.edi.ae>;tag=sqftsry
Via: SIP/2.0/TCP 172.17.2.101:5065;branch=z9hG4bKpU542hqpvkO3vgfv4zm6
Call-ID: 7fb036493c381689842f5d9af7801e3c@172.17.2.101
CSeq: 1 INVITE
Contact: <sip:065982528@172.17.2.101:5065;transport=tcp>
Max-Forwards: 70
x-inin-crn: 3001929130;loc=%3cRegionDefaultLocation%3e
Supported: join, replaces
User-Agent: ININ-TsServer/18.1.1.12
Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, PRACK, REFER, SUBSCRIBE, UPDATE
Accept: application/sdp
Accept-Encoding: identity
Content-Type: application/sdp
Content-Length: 201
v=0
o=ININ 2776777345 2776777346 IN IP4 172.17.2.101
s=Interaction
c=IN IP4 172.17.3.9
t=0 0
m=audio 30142 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
\\Ë ª 6 6Àêä÷F €Ÿ¾a E¸ (46@ @êçÀ¨«Û¬eÉÄq\Œ2~¸?5P ïk¸ \\Ë ¸W ^ ^Àêä÷F €Ÿ¾a E¸P47@ @é¾À¨«Û¬eÉÄq\Œ2~¸?5P ï= SIP/2.0 100 Trying
CSeq: 1 INVITE
Content-Length: 0
\\Ë ¹0 < < €Ÿ¾aÀêä÷F E ( @ @Ö¬eÀ¨«ÛÄqɁ¸?5\Œ2~Pj¢ \\Õ ²? J JÀêä÷F €Ÿ¾a E <Ä=@ @[„À¨«Û¬eèÉÉezé   ÐœÎ ´
- \\Õ Ó J J €Ÿ¾aÀêä÷F E <jn@ vS¬eÀ¨«ÛÉèÉþ¯qEezé¡  •à
»‹— -\\Õ Ô8 B BÀêä÷F €Ÿ¾a E¸ 4Ä>@ @ZÓÀ¨«Û¬eèÉÉezé¡þ¯qF€ ·ãO
-¦»‹—\\Õ Õª × ×Àêä÷F €Ÿ¾a E¸ÉÄ?@ @W=À¨«Û¬eèÉÉezé¡þ¯qF€ ·¶
-¦»‹—SIP/2.0 180 Ringing
Allow: INVITE, ACK, CANCEL, BYE, OPTIONS, NOTIFY, PRACK, UPDATE
Contact: <sip:0552215570@192.168.171.219:5065;transport=TCP;user=phone>
Supported: from-change
User-Agent: OXO103/029.001 GW_103/069.001
P-Asserted-Identity: <sip:0552215570@192.168.171.219;user=phone>
To: "90552215570" <sip:90552215570@192.168.171.219>;tag=8c7964f0a5a7ffdfd1171af4f167193f
CSeq: 1 INVITE
Content-Length: 279
v=0
o=OxO 1544707276 1544707276 IN IP4 192.168.171.219
s=Alcatel-Lucent OXO103/069.001
c=IN IP4 192.168.171.219
t=0 0
m=audio 32000 RTP/AVP 0 101
a=rtcp:32001
a=fmtp:101 0-15
a=sendrecv
a=ptime:20
a=maxptime:90
\\Õ
àB B €Ÿ¾aÀêä÷F E 4jo@ vZ¬eÀ¨«ÛÉèÉþ¯qFezí6€Þj
»‹ -¦\\Ø ýØ Àêä÷F €Ÿ¾a E¸÷Ä@@ @WÀ¨«Û¬eèÉÉezí6þ¯qF€ ·ä
:-»‹SIP/2.0 200 OK
Supported: 100rel,timer,from-change
Session-Expires: 43200;refresher=uas
CSeq: 1 INVITE
Content-Length: 279
v=0
t=0 0
a=rtcp:32001
a=fmtp:101 0-15
a=sendrecv
a=ptime:20
a=maxptime:90
\\Ø
™² B B €Ÿ¾aÀêä÷F E 4jp@ vY¬eÀ¨«ÛÄtÉÔ™k €Â ù° \\Ø
šm B BÀêä÷F €Ÿ¾a E¸ 4 @ @À¨«Û¬eÉÄti:Â?Ô™l€Ð×z ´\\Ø
º < < €Ÿ¾aÀêä÷F E (jq@ vd¬eÀ¨«ÛÄtÉÔ™li:Â@P- \\Ø
¿% @ @ €Ÿ¾aÀêä÷F E 2jr@ tY¬eÀ¨«ÛÄtÉÔ™li:Â@P¯Œ ACK sip:0552215570@192.168.171.219:5065;user=phone;transport=tcp SIP/2.0
CSeq: 1 ACK
Via: SIP/2.0/TCP 172.17.2.101:5065;branch=z9hG4bKjl7hUrvfdpEkEs3zOEx3
Max-Forwards: 70
Content-Length: 0
\\Ø
¿œ 6 6Àêä÷F €Ÿ¾a E¸ (ø@ @&ÿÀ¨«Û¬eÉÄti:Â@Ô™vP Ø,9 \\Ø
K ® ® €Ÿ¾aÀêä÷F E  js@ rê¬eÀ¨«ÛÄtÉÔ™vi:Â@P}S INVITE sip:0552215570@192.168.171.219:5065;user=phone;transport=tcp SIP/2.0
CSeq: 2 INVITE
Via: SIP/2.0/TCP 172.17.2.101:5065;branch=z9hG4bKn5sUjhbkU7wvmv3cfmIf
Max-Forwards: 70
x-inin-crn: 3001929130;loc=%3cRegionDefaultLocation%3e;ms=DCHQZCCM01
Content-Length: 203
v=0
o=ININ 3434825557 3434825560 IN IP4 172.17.2.101
s=Interaction
c=IN IP4 172.17.2.110
t=0 0
m=audio 30676 RTP/AVP 0 101
a=fmtp:101 0-15
\\Ø
¾ 6 6Àêä÷F €Ÿ¾a E¸ (ø@ @&þÀ¨«Û¬eÉÄti:Â@Ô™’îP(‰ \\Ø  ƒ ƒÀêä÷F €Ÿ¾a E¸uø @ @%°À¨«Û¬eÉÄti:Â@Ô™’îPb SIP/2.0 100 Trying
CSeq: 2 INVITE
Content-Length: 0
\\Ø l < < €Ÿ¾aÀêä÷F E ( @ @Ö¬eÀ¨«ÛÄtÉÔ™’îi:Â@P'” \\Ø J, B B €Ÿ¾aÀêä÷F E 4jt@ vU¬eÀ¨«ÛÉèÉþ¯qFezðù€þÌà
»Œà :-\\Ø ¢D Àêä÷F €Ÿ¾a E¸ÄA@ @VòÀ¨«Û¬eèÉÉezðùþ¯qF€ ·ÿ
:™»ŒàSIP/2.0 200 OK
CSeq: 2 INVITE
Content-Length: 306
v=0
o=OxO 1544707276 1544707277 IN IP4 192.168.171.219
t=0 0
a=rtcp:32001
a=fmtp:101 0-15
a=silenceSupp:off - - - -
a=sendrecv
a=ptime:20
a=maxptime:90
\\Ø åÁ B B €Ÿ¾aÀêä÷F E 4ju@ vT¬eÀ¨«ÛÄuÉs$ €Â Ê \\Ø æn B BÀêä÷F €Ÿ¾a E¸ 4 @ @À¨«Û¬eÉÄui\s%€Ð. ´\\Ø ¥ < < €Ÿ¾aÀêä÷F E (jv@ v_¬eÀ¨«ÛÄuÉs%i\PcÍ \\Ø B N N €Ÿ¾aÀêä÷F E @jw@ tF¬eÀ¨«ÛÄuÉs%i\P=Á ACK sip:0552215570@192.168.171.219:5065;user=phone;transport=tcp SIP/2.0
CSeq: 2 ACK
Via: SIP/2.0/TCP 172.17.2.101:5065;branch=z9hG4bKcp77nxq4lqwfh4yyIO5m
Max-Forwards: 70
Content-Length: 0
\\Ø ¶ 6 6Àêä÷F €Ÿ¾a E¸ (f­@ @¸pÀ¨«Û¬eÉÄui\s’=P ØbÞ \\Ù \— B B €Ÿ¾aÀêä÷F E 4jx@ vQ¬eÀ¨«ÛÉèÉþ¯qFezô׀Ȋ
»Œé :™\\á R­ €Ÿ¾aÀêä÷F E jy@ tr¬eÀ¨«ÛÄuÉs’=i\PÇÒ BYE sip:0552215570@192.168.171.219:5065;user=phone;transport=tcp SIP/2.0
CSeq: 3 BYE
Via: SIP/2.0/TCP 172.17.2.101:5065;branch=z9hG4bK6lU3fy2rrydxb5bw6Uxb
Max-Forwards: 70
Content-Length: 0
\\á S 6 6Àêä÷F €Ÿ¾a E¸ (f®@ @¸oÀ¨«Û¬eÉÄui\s”'P ú`Ò \\á _ý û ûÀêä÷F €Ÿ¾a E¸íf¯@ @¶©À¨«Û¬eÉÄui\s”'P úÚ SIP/2.0 200 OK
Supported: 100rel
CSeq: 3 BYE
Content-Length: 0
\\á -¥ < < €Ÿ¾aÀêä÷F E (jz@ v[¬eÀ¨«ÛÄuÉs”'i]ãPÿ^ \] ¯£ < < €Ÿ¾aÀêä÷F E (j{@ vZ¬eÀ¨«ÛÄuÉs”'i]ãPÿ^ \] ²J 6 6Àêä÷F €Ÿ¾a E¸ (f°@ @¸mÀ¨«Û¬eÉÄui]ãs”(P ú_ \] Ú“ < < €Ÿ¾aÀêä÷F E (j|@ vY¬eÀ¨«ÛÄuÉs”(i]äPÿ^
firewall consideration
rtp ports and @ip can be reach each one other?!
Mu law why ?
and sdp is not same !
KoenC
Post by KoenC »
Zaari posted the same issue on this forum:
https://www.alcatelunleashed.com/viewto ... 15&t=28795
Maybe you can find your solution there...
Good luck
If I'm ever on life support, unplug me. Then plug me back in, see if that works...
Return to “H323 / IP / Pimphony”
