IP phone rebooting shortcut key about....
thkim81
Post by thkim81 » 23 Sep 2009 21:54
Hi!!!
I setting the phone IP TOUCH Phone 4028,4038,4068
and I have the problem no..question..
can i have the rebooting the phone Shortcut key...
For example, Voice guide shortcut key numiber 580.....this number is choiced shortcut key that i wanted voice guide number.
as above, i want know the shortcut key about IP phone rebooting .
I don't work for phone rebooting with push back the phone Lan cable.
my hand is tough with work...
pls reply the my question...
Re: IP phone rebooting shortcut key about....
Post by cavagnaro » 24 Sep 2009 14:31
:? if your hand is busy how will you press the buttons then? No way to do that...
Return to “IpTouch Phones XML Applications”
