3rd party Phone and Softphone issues
AndyKu
Post by AndyKu »
Hi There
trust everyone is well?
i have an issue whereby a client has opted to go the softphone route (3rd party - Microsip)
open sip licenses have been installed and the phones register and can recieve and make calls accordingly with voice quality been 100%
The problem however is that transferring calls does not work, picking up calls in a group does not work and lastly, if the SIP extension is dynamically routed to a hunt group after a certain period or with when ringing the hunt group directly... the SIP extensions dont ringl calling them individually there is no issue.
we have also tried registring a Yealink for example, and we get the very same result.
i have also tried changing the dtmf dynamic payload to a varying number of values and still no joy
The client is running the latest / last release of version 10 R103_064
Please note: the current Alcatel IP phones that are installed work 100%... its just the 3rd party phones and softphones that are doing this.
Please help, as i have registered softphones many times before and have never experienced this.
Andy
rkraehen
Re: 3rd party Phone and Softphone issues
Post by rkraehen »
Hi Andy,
Maybe your SIP Phones are not compatible with the OXO. See attached file, you might try with an Polycom IP670 that is validated
Regards, rkraehen
oxo-sip-ecosystem-january-2019.pdf
Return to “MAIN”
