No TFTP on 4038 sets
mabrgron
Post by mabrgron »
im trying to install new phones on an existing system
installed a new phone 4038 and got the following error
1) network start
2) network setup
3) config download…bad file content
4) ….
5) connection,…. no tftp response….check dot1x config….(,…. no tftp response….check dot1x config….)….
we unplugged a workoing 4038 and replaced with a new 4038 and got the message above
put the original phone back on the network and its up and running
tried 4 new phone on that conection and they all received the error above
what can i check
Re: No TFTP on 4038 sets
You use static IP address for phone (declare IP address, mask, TFTP address) or dynamic (DHCP)?
mabrgron
Post by mabrgron »
We use DHCP
the set does get an IP address
And your DHCP is also sending TFTP server address? Check maybe the VLAN? Another DHCP server? Maybe that working phone has static parameters and not DHCP
Sent from my XPeria Z
jasic
Post by jasic »
Check your lanpbx.cfg if you bot the error in 5/5
Return to “Alcatel-Lucent Series 8&9”
