can't delete a trunk
anisbou
Post by anisbou » 28 May 2018 04:18
hi
My system is an alcatel OXE R10 and i have to delete one trunk from a trunk group,but there is an error msg saying that there is a set monitoring this trunk.so is there any method to find this set number.
ACFE Alcatel OmniPcx Enterprise
alexeik
Re: can't delete a trunk
Post by alexeik » 28 May 2018 06:48
trunk monitoring? i bet its an attandant set...
Post by cavagnaro » 28 May 2018 07:48
readkey command maybe will help you, you will see which keys are configured and one will be the monitor key
alexeik
Post by alexeik » 28 May 2018 07:52
what a nice command... this helps really... thanks
Post by vad » 29 May 2018 01:14
"multitool" command - not bad for supervision checking
anisbou
Post by anisbou » 29 May 2018 03:48
thanks cavagnaro ,"readkey" is really useful :)
anisbou
Post by anisbou » 29 May 2018 03:51
vad wrote:
29 May 2018 01:14
thank you Vad , "multitool" is really what i need
Return to “Trunk Groups”
