4059EE KO after windows updates
hawai50
Post by hawai50 » 31 May 2017 03:08
Hi:
My 4059EE was working correctly in W10 pro 64b but after to install the last updates of Windows the 4059EE not work.
“omnipcx communication failure SS_SBC_EXTENDED:L3OPEN, L2 protocol init failed”
Anybody in the world has this issue ???
pavelnt
Re: 4059EE KO after windows updates
Post by pavelnt » 31 May 2017 10:45
Is Windows Firewall enabled?
If so, try to disable it temporary.
hawai50
Post by hawai50 » 31 May 2017 11:41
NO firewall and antivirus enabled.
pavelnt
Post by pavelnt » 31 May 2017 12:00
Did you try to reinstall application? Is you Windows 10 version 1607/1703?
Could you collect very verbose traces?
hawai50
Post by hawai50 » 31 May 2017 12:27
Yes, this updates.
Find attached the traces
pavelnt
Post by pavelnt » 31 May 2017 13:12
It's really strange.
May be client doesn't send "acknowledgement" to PBX.
If firewalls and antivirus on client machine are disabled... could you try remove TFTP client feature and add again after reboot?
Sorry, don't have another ideas.
hawai50
Post by hawai50 » 01 Jun 2017 04:07
The same issue after that.
Don´t worry paveInt, thanks for your help.
Kind Regards
hawai50
Post by hawai50 » 06 Jun 2017 07:25
SOLVED !!!
desable the adapter wifi-bluthoot, no connect but after desable all is working
Return to “Attendant”
