ftp session to OXE 12.0 with .netrc
Egidio
Post by Egidio » 15 Dec 2017 04:29
Hallo!
In the old A4400 (release 6) it was possible to connect by ftp from another server to the A4400 by entering this servers IP-Adress in .netrc file.
Now I try the same in OXE release 12.0 but cannot get it to work.
Does anyone know if this is no longer allowed for the sake of security?
Thanks in advance
Egidio
Re: ftp session to OXE 12.0 with .netrc
Post by cavagnaro » 15 Dec 2017 11:42
Ftp is allowed yes, but if your OXE has security enabled then ftp is not enabled but sftp
Egidio
Post by Egidio » 15 Dec 2017 15:02
Thank you!
I had something mixed up - and put the .netrc file on the OXE instead on the server that wants to connect.
Egidio
Return to “System”
