Set NPRAE coupler out of service
siti
Post by siti » 14 Mar 2008 00:18
Is there any way I can block users from accessing any channels in the NPRAE card? I want to reset the coupler during working hours but it is really hard to get a chance because the channels are always occupied almost every second (One goes off and another one comes in).
There is no lift to success.You have to take the stairs - one at a time.
tincho.rn
Re: Set NPRAE coupler out of service
Post by tincho.rn » 14 Mar 2008 07:18
Hi. If you are using ARS use ARS Routes and ARS time tables to switch communications to an other TG wich don´t have the NPRAE you want to reset. I think is the best way, it is transparent for users. Regards.
ACSE R11
OT R2.0
Post by tot3nkopf » 14 Mar 2008 08:23
Or simply set overflow through ARS.
Regards.
siti
Post by siti » 14 Mar 2008 15:35
Thanks for the advise.
I thought there is a way similar to the outserv command.
torrentula
Post by torrentula » 14 Mar 2008 19:08
Most systems have a outserv or busy channel once idle command, another feature missing from the PCX.
Eliott_DUP
Post by Eliott_DUP » 16 Mar 2008 14:13
I think the outserv command can be used on the ghost equipment number (cplstat) and then choose smoothly.
But incoming calls cannot be blocked...
cplstat <Crystal> <Coupler>
Read Ghost Equipment number
outserv n <Ghost Equipment number>
Disable smoothly => Yes
Maybe outserv p <Crystal> <Coupler> <Access> all can be used. Never tried...
Never give up!
zanex
Post by zanex » 16 Mar 2008 19:23
the outserv command doesnt work on NPRAE unless it has been fixed recently.
Not All Those Who Wander Are Lost
torrentula
Post by torrentula » 16 Mar 2008 23:07
I will have to give it a try, if that's the case then I retract my earlier statement.
ather-shahbaz
Post by ather-shahbaz » 08 Oct 2009 02:48
There are 2 T2 access on NPRAE. Is there any way to reset one T2 without disturbing other. As in all commands like rstcpl, outserv or reinit, if you run it for one the other T2 also disturbed.
Ather PMP
Alcatel-Lucent Pakistan
deepakzambare
Post by deepakzambare » 21 Sep 2011 09:20
yes u can reset single slot of NPRAE card
use outserv p slot number a
ex. outserv p 0 11 1 a
And to inserv use
ex. inserv p 0 11 1 a
Deepak Z.
INDIA
Return to “Usefull commands”
