Firmware Download - Partner Recommendation?
bgomberg
Post by bgomberg » 24 Aug 2017 17:06
How the hell can you download firmware for EOL switches like the OS6850? Have version 6.3.1.871.R01 and wanted to upgrade as this version seems buggy. Cannot get them from Alcatel directly as they do not support the product any longer. Cannot find a parter who has access to the files either. Anyone have any suggestion?
Thank you in advance.
Re: Firmware Download - Partner Recommendation?
Post by frank » 05 Sep 2017 16:53
Business portal / Resources center / Software download / Software Network / OmniSwitch / 6850
rpcollins
Post by rpcollins » 14 Dec 2017 11:46
where is this Business portal? Thanks
Post by silvio » 15 Dec 2017 01:48
it is for alcatel partners only.
Post by frank » 15 Dec 2017 08:23
rpcollins
Post by rpcollins » 15 Dec 2017 18:48
Is it possible to be an alcatel partner as an individual for just home use?
Post by silvio » 16 Dec 2017 06:12
no, there is no chance. You need help from a business partner in your country.
devnull
Post by devnull » 18 Dec 2017 03:27
As allways google is your friend, there is at least on partner in netherlands who has open downloadable Firmware repository for all Omniswitches.
I don't think that this is the "Alcatel wanted" way but..
matzio49
Post by matzio49 » 24 Dec 2018 09:21
Hello, I would like to access the Firmware of my devices.
Unfortunately, I can not register with your portlau.
What I do not do always receive the same message.
The domain of your email address does not match the domain names allowed by your company. Make sure to use an appropriate domain name.
Please help.
