i am connected to a system via qsig, the outgoing calls are ok, except for the incoming calls, they ring once then stop.
below are the traces:
| (041827:000065) Concatenated-Physical-Event :
| long: 60 desti: 0 source: 0 cryst: 2 cpl: 6 us: 0 term: 0 type a5
| tei: 0 >>>> message received : SETUP [05] Call ref : 00 60
| SENDING COMPLETE
| IE:[18] CHANNEL (l=3) a1 83 9e -> T2 : B channel 30 preferred
| IE:[1e] PROGRESS_ID (l=2) 81 83
| IE:[6c] CALLING_NUMBER (l=8) -> 39 80 Num : 804111
| IE:[70] CALLED_NUMBER (l=7) -> 80 Num : 869392
| [9c] Non-locking shift. codeset : 4
| IE:[31] Unknown codeset (l=1) 82
| [9d] Non-locking shift. codeset : 5
| IE:[32] EI_PARTY_CATEGORY (l=1) -> EXTENSION (1)
| (041827:000066) 1160: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 27 desti: 0 source: 15 cryst: 2 cpl: 6 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : STATUS [7d] Call ref : 80 60
| IE:[08] CAUSE (l=4) 80 e3 04 31 -> [e3]
| INFORMATION ELEMENT NON-EXISTENT OR NOT IMPLEMENTED
| IE:[14] CALL_STATE (l=1) 06
| (041827:000067) 1160: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 23 desti: 0 source: 15 cryst: 2 cpl: 6 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : CALL PROC (02) Call ref : 80 60
| (041827:000068) 1160: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 22 desti: 0 source: 15 cryst: 2 cpl: 6 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : ALERT (01) Call ref : 80 60
| IE:[1e] PROGRESS_ID (l=2) 80 88
| (041830:000069) Concatenated-Physical-Event :
| long: 22 desti: 0 source: 0 cryst: 2 cpl: 6 us: 0 term: 0 type a5
| tei: 0 >>>> message received : RELEASE [4d] Call ref : 00 60
| IE:[08] CAUSE (l=2) 81 e5 -> [e5] MESSAGE NOT COMPATIBLE WITH CALL STATE
| (041830:000070) 1160: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : REL COMP [5a] Call ref : 80 60
| IE:[08] CAUSE (l=3) 80 90 80 -> [90] NORMAL CALL CLEARING
| (041831:000071) Concatenated-Physical-Event :
| long: 25 desti: 0 source: 0 cryst: 2 cpl: 6 us: 0 term: 0 type a5
| tei: 0 >>>> message received : STATUS [7d] Call ref : 00 60
| IE:[08] CAUSE (l=2) 81 e2 -> [e2]
| MESSAGE NOT COMPATIBLE WITH CALL STATE OR MESSAGE TYPE NON-EXISTENT
| IE:[14] CALL_STATE (l=1) 13
| (041831:000072) 1160: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| IE:[08] CAUSE (l=3) 80 e5 00 -> [e5] MESSAGE NOT COMPATIBLE WITH CALL STATE
| (041831:000073) Concatenated-Physical-Event :
| (041831:000074) 1160: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| (041834:000075) Concatenated-Physical-Event :
| tei: 0 >>>> message received : REL COMP [5a] Call ref : 00 60
| IE:[08] CAUSE (l=2) 81 af -> [af] RESOURCES UNAVAILABLE, UNSPECIFIED
| (041834:000076) Concatenated-Physical-Event :
under system, I ignore all types of IE and still the same. can anyone understand from the traces what is the problem.
failed incoming calls - Qsig
Re: failed incoming calls - Qsig
there is one more option some menues deeper like "send status on IE non existing"Alcatel_exp wrote:i am connected to a system via qsig, the outgoing calls are ok, except for the incoming calls, they ring once then stop.
| SENDING COMPLETE
deactivate this option and your problem should fixed
