Hi all,
which command shows me what calls are now on a certain trunk group?
Tom
Numbers on trunk group
- knightrider
Re: Numbers on trunk group
Have you tried command: listincall ?
Now I did. But it doesnt show me whichs trunks are used
- knightrider
You maybe need to work it out with the neqt number. Every trunk channel will have a neqt number assigned. If you use the command listerm you will see neqt number for all devices and trunk channels on the system
- tot3nkopf
Use t3 or mtracer -a (external user number). Trunk access number (e.g.: 12 1 - crystal 12 access 2) shoul be visible in the trace.
