Analog phone programmable key RBT delay
HUSSAINQCS
Post by HUSSAINQCS »
OXE release 11.1
I have configured the programmable key in the cetis analog phones
KEY no : 1 ------0 (which is working good)
KEY no : 2 ------2000(Which is taking time to reach the extension)
when you press the key after emitting all the digits only rbt to internal extension is going but this is not for "0"
Any suggestion
2000- Hunt group
0 --- network no
HUSSAINQCS
Re: Analog phone programmable key RBT delay
Can anybody reply please
KEY no : 2 ------2000(Which is taking time to reach the extension) - type of dialling pulse?
KEY no : 1 ------0 (which is working good) - no RBT?
But if you dial 0 (not from programmed key) - do you have RBT (as I understand you have problem with RBT?)?
if you dial 0 from digital set?
may be you have problem with 0 - make trace when dialled 0.
HUSSAINQCS
Its good with one digit but as configured as 4 digit in speed dial key of analog phone after emitting all tones RBT was going
