Hi!!
my site is call center .
today. i incident error log below.
14/12/09 11:00:18 000001M|002/20/-/---|=3:4401=Ethernet broadcast reception disabled due to excessive traffic
14/12/09 11:00:46 000001M|002/06/-/---|=3:4401=Ethernet broadcast reception disabled due to excessive traffic
14/12/09 11:01:37 000001M|002/06/-/---|=3:4401=Ethernet broadcast reception disabled due to excessive traffic
(1)geps_b> incinfo US0
Incident number (q to quit):4401
INCIDENT NUMBER: 4401
OBJECT CLASS: Dhs3Board
EVENT TYPE: ProcessingErrorAlarm (10)
PROBABLE CAUSE: Unknown (0)
SEVERITY: Minor
"Ethernet broadcast reception disabled due to excessive traffic"
"Ethernet broadcast reception has been disabled, due to"
"excessive broadcast incoming traffic."
"Ethernet broadcast is enabled again after a few seconds."
"Try to understand why there's so much broadcast traffic."
"Establish a logical link with further alarms."
"Imagine some solutions by filtering incoming traffic"
"(using hubs), with network";
I don't know why did incidented log.
pls answer the question.
thanks.
- cavagnaro
Re: 4401=Ethernet broadcast reception disabled due to excessive
There is broadcast in your network, talk to your data guys so they control that in that VLAN, that disables the ethernet port by security.
Just disable broadcast reception, not ethernet port...that disables the ethernet port by security
G.
If you have two CPU and both connected to the LAN - forbid On-board ethernet on CPU with jumper (f.e. X900 for CPU6).
I agree with the above Guru, as believe me, I have experienced this and it is network all of the time. If your incident is occurring frequently and you use Appliance servers instead of CPU6/7, then the issue you get is that the system will start to slow down and IP phones will reboot randomly, due to the fact it cannot get a response from the system (due to the slowdown of the network)
I had a site whereby there was a machine infected with a virus and was sending out 1000 requests a minute to all devices in the network, the system swapped/basculed itself many times and cut a lot of call centre calls off. As soon as I unplugged the machine concerned (after running wireshark I found the MAC and IP address of who it was, then I run a Ip scanner program to find the machine name) unpluggfed the ethernet from the machine and all was fixed.
Be aware that if there are a lot of 4401 errors and the network is slow, then you will experience bigger problems.
Juste for me I have the same message 4401, but my PBX is not connected to the LAN, its connected with 2 nodes in ABCF, and i have this message.
can you please give me a response or explain this phenomenon !!!
thanks.
thanks.
Hi Hello, Could you be more specific? Please.vad wrote:If you have two CPU and both connected to the LAN - forbid On-board ethernet on CPU with jumper (f.e. X900 for CPU6).
Best Regards,
K
ACSE OXE R11
ACSE OXO R8
K
ACSE OXE R11
ACSE OXO R8
CPU board has on-board Ethernet switch. One Ethernet port usually connected to CBRMA (for external connection) and second (on-board, embedded) for inter CPU connection via backplane.
And you can use (in CPU duplicated case) two type connection:
1) One external connection (Eth0 or 1 from CBRMA). Access to second CPU via embedded Ethernet. Exist one problem - during CPU restart (which Ethernet used for external connection) you lost access to system.
2) Two external connection (Eth0 AND Eth1 from CBRMA). In this case you need to forbid second Ethernet port on CPU (for loop disable - external switch-CPU1-CPU2-external switch).
jumper X900 used for enable (case 1) or disable (case 2) on-board/embedded/interCPU Ethernet access.
I had this issue recently. The cause was associated with ethernet switch port configuration. The network switch had the ethernet port configured as autonegotiated instead of 100M Full as we had defined in the oXE board (in this case, the incident was related to INTIP boards of an IPMG). I think because network switch try to negotiate there are sent some broadcast (?) and then the alarm rose .
