OAW4302 and AP65
Locked
screamphoenix
OAW4302 and AP65
Post by screamphoenix »
Hello erverbody,
I tried to configure the Remote AP, but i made something wrong. My controller could not find the AP anymore. I made a factory reset with the OAW, but nothing happens, the AP still is not there. How can I reset the AP? Or what can I do?
Greetings
Re: OAW4302 and AP65
You need SOE-connect to the AP - serial other ethernet.
For this you have two ways: via telnet port 2500 if the AP is direct connected at an OAW 4304/8 or 4324 (but not 4302)
or with a Y-cable "OAW-AP-SOE" at the ethernet port. If you have connect you must interrupt the boot process of the AP. With the commands purge and save you can reset the config to factory default.
regards Silvio
screamphoenix
Works perfect!! Thanx!! :D
Locked
Return to “OmniAccess WLAN 4302”
