Dear; i am in trouble in my PBX system. there are four ip-phones in our company, but they are always reboot,include working time,the time no general. it is a very critical problem. i use the "wireshark" but i can't find the cause.i try "ping", the network is reachable.no package loss,no time delay.it seems that network is very stable. here is the log.
can any one help me....
22/09/09 06:44:17 000004I|---/--/-/---|=4:2199=A4400 Version : R9.0-h1.301-28-b-cn-c0
22/09/09 06:44:17 000004I|---/--/-/---|=2:4351=Incoherent data: appli INITREM table FBC_DATA cause C1191 info 0 158 -1
22/09/09 06:44:17 000004I|---/--/-/---|=2:4351=Incoherent data: appli INITREM table ENTITY cause 1 info -1 -1 -1
22/09/09 06:44:17 000004I|---/--/-/---|=2:4351=Incoherent data: appli INITREM table ENTITY cause 2500 info -1 -1 -1
22/09/09 06:44:17 000004I|---/--/-/---|=2:4351=Incoherent data: appli INITREM table ENTITY cause 1191 info -1 -1 -1
22/09/09 06:44:17 000004I|---/--/-/---|=2:4351=Incoherent data: appli INITREM table ENTITY cause 1192 info -1 -1 -1
22/09/09 06:44:17 000004I|---/--/-/---|=2:4351=Incoherent data: appli INITREM table ENTITY cause 2508 info -1 -1 -1
22/09/09 06:44:17 000004I|---/--/-/---|=2:4351=Incoherent data: appli INITREM table ENTITY cause 2800 info -1 -1 -1
22/09/09 06:44:57 000004I|---/--/-/---|=2:2176=A dynamic patch has been installed for TEL
22/09/09 06:45:27 000004I|---/--/-/---|=2:2176=A dynamic patch has been installed for TEL
22/09/09 06:45:51 000004M|---/--/-/---|=5:2009=Initialisation CPU role MAIN
22/09/09 06:45:51 000004M|---/--/-/---|=5:2019=UA_FICTIF coupler commissioning
22/09/09 06:45:51 000004M|---/--/-/---|=5:1367=DECT network initialization
22/09/09 06:45:51 000004M|---/--/-/---|=5:5904=Remote extension network initialization
22/09/09 06:45:51 000004M|---/--/-/---|=4:0425=PRS related activity : Interface handler started
22/09/09 06:45:51 000004M|019/01/-/---|=5:2019=INTIPA coupler commissioning
22/09/09 06:45:59 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 1 PCS domain 119
22/09/09 06:45:59 000004M|---/--/-/---|=5:0430=PCS 10.30.0.21 is disabled
22/09/09 06:46:10 000004M|---/--/-/---|=2:0276=External accounting application 4760 : NO RECOVERY
22/09/09 06:46:14 000004M|000/00/-/---|=5:5800=402 SIP trunk group put into service
22/09/09 06:46:14 000004M|---/--/-/---|=4:4017=CSTA server : new creation 1 144.119.133.134
22/09/09 06:46:15 000004M|---/--/-/---|=0:5812=SIP external gateway 1 is in service
22/09/09 06:46:52 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
22/09/09 06:47:25 000004M|019/00/0/002|=5:2862=PH:Hybrid Access (3 1 Main) is up
22/09/09 06:47:25 000004M|019/00/0/002|=3:2866=PH:Estab Req for PLL 0 on Hybrid Access (3 1 Main)
22/09/09 06:47:25 000004M|019/00/0/002|=5:2864=PH:PLL 0 is up on Hybrid Access (3 1 Main)
22/09/09 06:47:33 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
22/09/09 06:47:40 000004M|3-4 |=5:2827=PH:Local link [4 3] is up
22/09/09 06:47:40 000004M|---/--/-/---|=5:2846=PH:Node 3 is reachable
22/09/09 06:48:25 000004M|---/--/-/---|=4:0425=PRS related activity : Link established
22/09/09 06:48:54 000004M|000/06/-/---|=5:2169=Main CPU initialization completed
22/09/09 06:53:30 000004S|---/--/-/---|=5:1367=DECT network initialization
22/09/09 06:53:30 000004S|---/--/-/---|=5:5904=Remote extension network initialization
22/09/09 06:53:30 000004S|---/--/-/---|=4:0425=PRS related activity : Interface handler started
22/09/09 06:53:40 000004S|---/--/-/---|=0:5812=SIP external gateway 1 is in service
22/09/09 06:53:40 000004S|000/00/-/---|=5:5800=402 SIP trunk group put into service
22/09/09 06:54:10 000004S|000/00/-/---|=5:5800=402 SIP trunk group put into service
22/09/09 06:54:44 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 0 PCS domain 119
22/09/09 06:54:44 000004M|---/--/-/---|=2:0429=PCS 10.30.0.21 is activated
22/09/09 06:54:52 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 1 PCS domain 119
22/09/09 06:54:52 000004M|---/--/-/---|=5:0430=PCS 10.30.0.21 is disabled
22/09/09 06:55:08 000004S|---/--/-/---|=3:1125=external alarm : "mtcl login"
22/09/09 06:56:39 000004M|000/10/-/---|=5:2059=St-by CPU put in service
22/09/09 07:02:33 000004M|001/00/0/229|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:76:ea,1198479
22/09/09 07:10:52 000004M|---/--/-/---|=2:2768=Network mgt : transfer of the file LOG.3.215 impossible
22/09/09 07:17:19 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
22/09/09 07:30:54 000004M|---/--/-/---|=2:2768=Network mgt : transfer of the file LOG.3.216 impossible
22/09/09 07:50:56 000004M|---/--/-/---|=2:2768=Network mgt : transfer of the file LOG.3.217 impossible
22/09/09 07:52:04 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 0 PCS domain 119
22/09/09 07:52:04 000004M|---/--/-/---|=2:0429=PCS 10.30.0.21 is activated
22/09/09 07:52:12 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 1 PCS domain 119
22/09/09 07:52:12 000004M|---/--/-/---|=5:0430=PCS 10.30.0.21 is disabled
22/09/09 07:55:32 000004M|019/00/0/002|=3:2867=PH:Hybrid Access (3 1 Main) goes down
22/09/09 07:55:32 000004M|3-4 |=2:2826=PH:Local link [4 3] is down
22/09/09 07:55:32 000004M|---/--/-/---|=3:2832=PH:Node 3 is unreachable
22/09/09 07:55:32 000004M|019/00/0/002|=3:2865=PH:PLL 0 is down on Hybrid Access (3 1 Main)
22/09/09 07:56:36 000004M|019/00/0/002|=5:2862=PH:Hybrid Access (3 1 Main) is up
22/09/09 07:56:36 000004M|019/00/0/002|=3:2866=PH:Estab Req for PLL 0 on Hybrid Access (3 1 Main)
22/09/09 07:56:36 000004M|019/00/0/002|=5:2864=PH:PLL 0 is up on Hybrid Access (3 1 Main)
22/09/09 07:56:50 000004M|3-4 |=5:2827=PH:Local link [4 3] is up
22/09/09 07:56:50 000004M|---/--/-/---|=5:2846=PH:Node 3 is reachable
22/09/09 08:11:57 000004M|---/--/-/---|=2:2768=Network mgt : transfer of the file LOG.3.218 impossible
22/09/09 08:15:35 000004M|001/00/0/024|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:77:16,1198003
22/09/09 08:16:33 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 0 PCS domain 119
22/09/09 08:16:33 000004M|---/--/-/---|=2:0429=PCS 10.30.0.21 is activated
22/09/09 08:16:41 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 1 PCS domain 119
22/09/09 08:16:41 000004M|---/--/-/---|=5:0430=PCS 10.30.0.21 is disabled
22/09/09 08:20:44 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 08:21:14 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 08:25:44 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 08:26:14 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 08:30:44 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 08:31:14 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 08:31:59 000004M|---/--/-/---|=2:2768=Network mgt : transfer of the file LOG.3.219 impossible
22/09/09 08:35:44 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 08:36:14 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 08:37:35 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 08:38:05 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 08:39:42 000004M|019/00/0/002|=3:2867=PH:Hybrid Access (3 1 Main) goes down
22/09/09 08:39:42 000004M|3-4 |=2:2826=PH:Local link [4 3] is down
22/09/09 08:39:42 000004M|---/--/-/---|=3:2832=PH:Node 3 is unreachable
22/09/09 08:39:42 000004M|019/00/0/002|=3:2865=PH:PLL 0 is down on Hybrid Access (3 1 Main)
22/09/09 08:40:24 000004M|---/--/-/---|=3:2813=PH: incident X25: diag=1520 apc=0 ap=34 lcn=46
22/09/09 08:40:46 000004M|019/00/0/002|=5:2862=PH:Hybrid Access (3 1 Main) is up
22/09/09 08:40:46 000004M|019/00/0/002|=3:2866=PH:Estab Req for PLL 0 on Hybrid Access (3 1 Main)
22/09/09 08:40:46 000004M|019/00/0/002|=5:2864=PH:PLL 0 is up on Hybrid Access (3 1 Main)
22/09/09 08:41:01 000004M|3-4 |=5:2827=PH:Local link [4 3] is up
22/09/09 08:41:01 000004M|---/--/-/---|=5:2846=PH:Node 3 is reachable
22/09/09 08:42:35 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 08:43:05 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 08:47:35 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 08:48:05 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 08:52:35 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 08:53:05 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 08:54:02 000004M|---/--/-/---|=2:2768=Network mgt : transfer of the file LOG.3.220 impossible
22/09/09 09:14:04 000004M|---/--/-/---|=2:2768=Network mgt : transfer of the file LOG.3.221 impossible
22/09/09 09:19:04 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
22/09/09 09:23:06 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
22/09/09 09:34:06 000004M|---/--/-/---|=2:2768=Network mgt : transfer of the file LOG.3.222 impossible
22/09/09 09:37:18 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 0 PCS domain 119
22/09/09 09:37:18 000004M|---/--/-/---|=2:0429=PCS 10.30.0.21 is activated
22/09/09 09:37:26 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 1 PCS domain 119
22/09/09 09:37:26 000004M|---/--/-/---|=5:0430=PCS 10.30.0.21 is disabled
22/09/09 09:54:08 000004M|---/--/-/---|=2:2768=Network mgt : transfer of the file LOG.3.223 impossible
22/09/09 09:55:01 000004M|---/--/-/---|=0:1603=IO1 driver error, wrong telephone msg received, line 8314, position (7,8,61)
22/09/09 09:55:01 000004M|---/--/-/---|=3:1607=00.00.17.00.0f.0f.ff.00.04.ff.9a.ff.ff.ff.ff
22/09/09 09:55:01 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.77.05.00.ff.ff.ff
22/09/09 09:55:01 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.77.06.00.ff.ff.ff
22/09/09 09:55:01 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.77.07.00.ff.ff.ff
22/09/09 09:55:01 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.77.08.00.ff.ff.ff
22/09/09 09:55:01 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.79.7b.08.00.ff.ff.ff
22/09/09 09:55:01 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.77.09.00.ff.ff.ff
22/09/09 09:55:01 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.79.7b.09.00.ff.ff.ff
22/09/09 09:55:01 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.77.0a.00.ff.ff.ff
22/09/09 09:55:01 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.77.0b.00.ff.ff.ff
22/09/09 09:55:01 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.77.0c.00.ff.ff.ff
22/09/09 09:55:01 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.77.0d.00.ff.ff.ff
22/09/09 09:55:01 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.79.7b.0d.00.ff.ff.ff
22/09/09 09:55:01 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.79.7b.0f.00.ff.ff.ff
22/09/09 09:55:01 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.79.7b.11.00.ff.ff.ff
22/09/09 09:55:01 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.7d.12.00.ff.ff.ff
22/09/09 09:55:01 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.77.15.00.ff.ff.ff
22/09/09 09:55:01 000004M|--WARNING---| INCIDENTS FLOW HAS BEEN REDIRECTED TO THE OUTFALL QUEUE
22/09/09 09:59:11 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 09:59:42 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 10:04:12 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 10:04:42 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 10:07:41 000004M|001/01/0/128|=4:0386=Sig. on IP set: No response from de set 00:80:9f:79:7b:24,1198180
22/09/09 10:09:02 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 10:09:33 000004M|019/00/0/000|=3:4099x003=B channel choice error No 0 link 402 out 1
22/09/09 10:14:02 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 10:14:10 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 10:14:10 000004M|---/--/-/---|=2:2768=Network mgt : transfer of the file LOG.3.224 impossible
22/09/09 10:14:12 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 10:14:42 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 10:16:27 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
22/09/09 10:17:03 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 10:17:33 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 10:19:02 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 10:19:32 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 10:22:06 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 10:22:23 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 10:22:23 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 0 PCS domain 119
22/09/09 10:22:23 000004M|---/--/-/---|=2:0429=PCS 10.30.0.21 is activated
22/09/09 10:22:31 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 1 PCS domain 119
22/09/09 10:22:31 000004M|---/--/-/---|=5:0430=PCS 10.30.0.21 is disabled
22/09/09 10:22:34 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 10:23:04 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 10:24:02 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 10:24:32 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 10:27:34 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 10:28:04 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 10:32:34 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 10:33:04 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 10:34:11 000004M|---/--/-/---|=2:2768=Network mgt : transfer of the file LOG.3.225 impossible
22/09/09 10:54:13 000004M|---/--/-/---|=2:2768=Network mgt : transfer of the file LOG.3.226 impossible
22/09/09 11:04:49 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 0 PCS domain 119
22/09/09 11:04:49 000004M|---/--/-/---|=2:0429=PCS 10.30.0.21 is activated
22/09/09 11:04:57 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 1 PCS domain 119
22/09/09 11:04:57 000004M|---/--/-/---|=5:0430=PCS 10.30.0.21 is disabled
22/09/09 11:08:16 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 11:08:46 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 11:09:49 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
22/09/09 11:13:16 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 11:13:46 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 11:14:15 000004M|---/--/-/---|=2:2768=Network mgt : transfer of the file LOG.3.227 impossible
22/09/09 11:18:17 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 11:18:47 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 11:23:17 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 11:23:37 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 11:23:37 000004M|---/--/-/---|=2:0276=External accounting application 4760 : NO RECOVERY
22/09/09 11:34:17 000004M|---/--/-/---|=2:2768=Network mgt : transfer of the file LOG.3.228 impossible
22/09/09 11:37:46 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 11:38:16 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 11:42:46 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 11:43:15 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 11:47:46 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 11:48:15 000004M|019/00/0/000|=3:4099x003=B channel choice error No 0 link 402 out 1
22/09/09 11:52:46 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 11:53:16 000004M|019/00/0/000|=3:4099x003=B channel choice error No 0 link 402 out 1
22/09/09 11:54:19 000004M|---/--/-/---|=2:2768=Network mgt : transfer of the file LOG.3.229 impossible
22/09/09 11:57:46 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 11:58:17 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 11:58:41 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 0 PCS domain 119
22/09/09 11:58:41 000004M|---/--/-/---|=2:0429=PCS 10.30.0.21 is activated
22/09/09 11:58:50 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 1 PCS domain 119
22/09/09 11:58:50 000004M|---/--/-/---|=5:0430=PCS 10.30.0.21 is disabled
22/09/09 12:02:47 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 12:03:11 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 12:03:11 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
22/09/09 12:14:20 000004M|---/--/-/---|=2:2768=Network mgt : transfer of the file LOG.3.230 impossible
22/09/09 12:34:22 000004M|---/--/-/---|=2:2768=Network mgt : transfer of the file LOG.3.231 impossible
22/09/09 12:52:42 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 0 PCS domain 119
22/09/09 12:52:42 000004M|---/--/-/---|=2:0429=PCS 10.30.0.21 is activated
22/09/09 12:52:50 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 1 PCS domain 119
22/09/09 12:52:50 000004M|---/--/-/---|=5:0430=PCS 10.30.0.21 is disabled
22/09/09 12:54:24 000004M|---/--/-/---|=2:2768=Network mgt : transfer of the file LOG.3.232 impossible
22/09/09 12:55:03 000004M|---/--/-/---|=0:1603=IO1 driver error, wrong telephone msg received, line 8314, position (7,8,61)
22/09/09 12:55:03 000004M|---/--/-/---|=3:1607=00.00.17.00.0f.0f.ff.00.04.ff.9a.ff.ff.ff.ff
22/09/09 12:55:03 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.79.7b.6d.00.ff.ff.ff
22/09/09 12:55:03 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.7d.6d.00.ff.ff.ff
22/09/09 12:55:03 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.7d.71.00.ff.ff.ff
22/09/09 12:55:03 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.7d.74.00.ff.ff.ff
22/09/09 12:55:03 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.76.76.00.ff.ff.ff
22/09/09 12:55:03 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.76.7c.00.ff.ff.ff
22/09/09 12:55:03 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.7d.86.00.ff.ff.ff
22/09/09 12:55:03 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.7d.88.00.ff.ff.ff
22/09/09 12:55:03 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.76.8a.00.ff.ff.ff
22/09/09 12:55:03 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.7d.8d.00.ff.ff.ff
22/09/09 12:55:03 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.76.91.00.ff.ff.ff
22/09/09 12:55:03 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.76.92.00.ff.ff.ff
22/09/09 12:55:03 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.76.93.00.ff.ff.ff
22/09/09 12:55:03 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.76.94.00.ff.ff.ff
22/09/09 12:55:03 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.76.95.00.ff.ff.ff
22/09/09 12:55:03 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.76.96.00.ff.ff.ff
22/09/09 12:55:03 000004M|--WARNING---| INCIDENTS FLOW HAS BEEN REDIRECTED TO THE OUTFALL QUEUE
22/09/09 12:56:03 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 0 PCS domain 119
22/09/09 12:56:03 000004M|---/--/-/---|=2:0429=PCS 10.30.0.21 is activated
22/09/09 12:56:11 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 1 PCS domain 119
22/09/09 12:56:11 000004M|---/--/-/---|=5:0430=PCS 10.30.0.21 is disabled
22/09/09 12:56:32 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
22/09/09 13:01:07 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 0 PCS domain 119
22/09/09 13:01:07 000004M|---/--/-/---|=2:0429=PCS 10.30.0.21 is activated
22/09/09 13:01:16 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 1 PCS domain 119
22/09/09 13:01:16 000004M|---/--/-/---|=5:0430=PCS 10.30.0.21 is disabled
22/09/09 13:14:26 000004M|---/--/-/---|=2:2768=Network mgt : transfer of the file LOG.3.233 impossible
22/09/09 13:20:47 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 0 PCS domain 119
22/09/09 13:20:47 000004M|---/--/-/---|=2:0429=PCS 10.30.0.21 is activated
22/09/09 13:20:55 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 1 PCS domain 119
22/09/09 13:20:55 000004M|---/--/-/---|=5:0430=PCS 10.30.0.21 is disabled
22/09/09 13:34:28 000004M|---/--/-/---|=2:2768=Network mgt : transfer of the file LOG.3.234 impossible
22/09/09 13:35:40 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 0 PCS domain 119
22/09/09 13:35:40 000004M|---/--/-/---|=2:0429=PCS 10.30.0.21 is activated
22/09/09 13:35:48 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 1 PCS domain 119
22/09/09 13:35:48 000004M|---/--/-/---|=5:0430=PCS 10.30.0.21 is disabled
22/09/09 13:49:54 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
22/09/09 13:54:17 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 13:54:29 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 13:54:29 000004M|---/--/-/---|=2:2768=Network mgt : transfer of the file LOG.3.235 impossible
22/09/09 13:59:17 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 13:59:47 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 14:04:17 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 14:04:46 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 14:05:10 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 0 PCS domain 119
22/09/09 14:05:10 000004M|---/--/-/---|=2:0429=PCS 10.30.0.21 is activated
22/09/09 14:05:18 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 1 PCS domain 119
22/09/09 14:05:18 000004M|---/--/-/---|=5:0430=PCS 10.30.0.21 is disabled
22/09/09 14:09:17 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 14:09:47 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 14:12:22 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 14:12:51 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 14:14:31 000004M|---/--/-/---|=2:2768=Network mgt : transfer of the file LOG.3.236 impossible
22/09/09 14:17:22 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 14:17:52 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 14:22:23 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 14:22:53 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 14:27:23 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 14:27:53 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 14:43:16 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
22/09/09 14:43:58 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
22/09/09 15:21:05 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 15:21:35 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 15:26:05 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 15:26:35 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 15:31:06 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 15:31:36 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 15:36:06 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 15:36:36 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 15:36:37 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
22/09/09 15:44:40 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 15:45:10 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 15:49:40 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 15:50:10 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 15:53:37 000004M|---/--/-/---|=2:0276=External accounting application 4760 : NO RECOVERY
22/09/09 15:54:41 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 15:55:04 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 15:55:04 000004M|---/--/-/---|=0:1603=IO1 driver error, wrong telephone msg received, line 8314, position (7,8,61)
22/09/09 15:55:04 000004M|---/--/-/---|=3:1607=00.00.17.00.0f.0f.ff.00.04.ff.9a.ff.ff.ff.ff
22/09/09 15:55:04 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.76.c7.00.ff.ff.ff
22/09/09 15:55:04 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.76.c9.00.ff.ff.ff
22/09/09 15:55:04 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.76.cc.00.ff.ff.ff
22/09/09 15:55:04 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.76.cd.00.ff.ff.ff
22/09/09 15:55:04 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.75.ce.00.ff.ff.ff
22/09/09 15:55:04 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.76.ce.00.ff.ff.ff
22/09/09 15:55:04 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.79.7a.d3.00.ff.ff.ff
22/09/09 15:55:04 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.76.d4.00.ff.ff.ff
22/09/09 15:55:04 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.76.d5.00.ff.ff.ff
22/09/09 15:55:04 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.76.d6.00.ff.ff.ff
22/09/09 15:55:04 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.76.d7.00.ff.ff.ff
22/09/09 15:55:04 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.76.dd.00.ff.ff.ff
22/09/09 15:55:04 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.75.de.00.ff.ff.ff
22/09/09 15:55:04 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.76.de.00.ff.ff.ff
22/09/09 15:55:04 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.76.df.00.ff.ff.ff
22/09/09 15:55:04 000004M|---/--/-/---|=3:1607=0c.00.11.22.00.00.80.9f.80.75.e0.00.ff.ff.ff
22/09/09 15:55:04 000004M|--WARNING---| INCIDENTS FLOW HAS BEEN REDIRECTED TO THE OUTFALL QUEUE
22/09/09 15:59:41 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 16:00:11 000004M|019/00/0/000|=3:4099=B channel choice error No 0 link 402 out 1
22/09/09 16:29:59 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
22/09/09 16:35:25 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 0 PCS domain 119
22/09/09 16:35:25 000004M|---/--/-/---|=2:0429=PCS 10.30.0.21 is activated
22/09/09 16:35:34 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 1 PCS domain 119
22/09/09 16:35:34 000004M|---/--/-/---|=5:0430=PCS 10.30.0.21 is disabled
22/09/09 16:58:42 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 0 PCS domain 119
22/09/09 16:58:42 000004M|---/--/-/---|=2:0429=PCS 10.30.0.21 is activated
22/09/09 16:58:51 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 1 PCS domain 119
22/09/09 16:58:51 000004M|---/--/-/---|=5:0430=PCS 10.30.0.21 is disabled
22/09/09 17:05:57 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 0 PCS domain 119
22/09/09 17:05:57 000004M|---/--/-/---|=2:0429=PCS 10.30.0.21 is activated
22/09/09 17:06:06 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 1 PCS domain 119
22/09/09 17:06:06 000004M|---/--/-/---|=5:0430=PCS 10.30.0.21 is disabled
22/09/09 17:23:21 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
22/09/09 18:16:42 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
22/09/09 18:26:55 000004S|---/--/-/---|=3:1125=external alarm : "mtcl login"
22/09/09 18:27:42 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
22/09/09 18:28:24 000004S|---/--/-/---|=3:1125=external alarm : "mtcl login"
22/09/09 18:35:28 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 0 PCS domain 119
22/09/09 18:35:28 000004M|---/--/-/---|=2:0429=PCS 10.30.0.21 is activated
22/09/09 18:35:36 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 1 PCS domain 119
22/09/09 18:35:36 000004M|---/--/-/---|=5:0430=PCS 10.30.0.21 is disabled
22/09/09 18:52:40 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 0 PCS domain 119
22/09/09 18:52:40 000004M|---/--/-/---|=2:0429=PCS 10.30.0.21 is activated
22/09/09 18:52:48 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 1 PCS domain 119
22/09/09 18:52:48 000004M|---/--/-/---|=5:0430=PCS 10.30.0.21 is disabled
22/09/09 18:58:33 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
22/09/09 19:10:04 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
22/09/09 20:03:26 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
22/09/09 20:23:37 000004M|---/--/-/---|=2:0276=External accounting application 4760 : NO RECOVERY
22/09/09 20:27:59 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
22/09/09 20:45:03 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
22/09/09 20:56:47 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
22/09/09 21:50:09 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
22/09/09 22:00:24 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 0 PCS domain 119
22/09/09 22:00:24 000004M|---/--/-/---|=2:0429=PCS 10.30.0.21 is activated
22/09/09 22:00:27 000004M|002/06/-/---|=4:0740=Beginning of an INT/IP downloading @:00.80.9f.81.f6.05 (binintip)
22/09/09 22:00:27 000004M|002/06/-/---|=4:0740=Beginning of an INT/IP downloading @:00.80.9f.81.f6.05 (binintip_app
22/09/09 22:00:27 000004M|002/06/-/---|=5:0741=End of downloading of an INT/IP board @:00.80.9f.81.f6.05 (binintip_app
22/09/09 22:00:47 000004M|002/06/-/---|=5:0409=The inter-ACT link over IP from (19 1) is up
22/09/09 22:00:48 000004M|002/06/-/---|=0:5857=GD/GA/INTIP/RGD: reason of reboot 1
22/09/09 22:00:48 000004M|002/12/-/---|=4:0260=Beginning of downloading bnvdsp1gpa2
22/09/09 22:00:48 000004M|002/04/-/---|=4:0260=Beginning of downloading bnvdsp0z32
22/09/09 22:00:52 000004M|002/04/-/---|=5:0261=End of downloading bnvdsp0z32
22/09/09 22:00:52 000004M|002/04/-/---|=4:3501=Clock loss
22/09/09 22:01:03 000004M|002/12/-/---|=5:0261=End of downloading bnvdsp1gpa2
22/09/09 22:01:03 000004M|002/12/-/---|=4:0260=Beginning of downloading bnvdsp2gpa2
22/09/09 22:01:18 000004M|002/06/-/---|=5:2019=INTIPB coupler commissioning
22/09/09 22:01:23 000004M|002/12/-/---|=5:0261=End of downloading bnvdsp2gpa2
22/09/09 22:01:24 000004M|---/--/-/---|=0:1612=Protocol error on Alcatel 8&9 series, type 30 (neqt 575)
22/09/09 22:01:24 000004M|---/--/-/---|=3:1613=15.04.1e.00.02.02.06.00.06.6e.00.00.01.00.00
22/09/09 22:01:24 000004M|002/12/-/---|=4:3501=Clock loss
22/09/09 22:01:25 000004M|002/10/-/---|=4:0740=Beginning of an INT/IP downloading @:00.80.9f.81.f7.2b (binintip)
22/09/09 22:01:25 000004M|002/10/-/---|=4:0740=Beginning of an INT/IP downloading @:00.80.9f.81.f7.2b (binintip_app
22/09/09 22:01:25 000004M|002/10/-/---|=5:0741=End of downloading of an INT/IP board @:00.80.9f.81.f7.2b (binintip_app
22/09/09 22:01:26 000004M|001/01/0/128|=5:2053=Terminal 128 in service
22/09/09 22:01:28 000004M|---/--/-/---|=5:2141=SET resources quantity normal
22/09/09 22:01:31 000004M|001/00/0/024|=5:2053=Terminal 24 in service
22/09/09 22:01:35 000004M|001/00/0/229|=5:2053=Terminal 229 in service
22/09/09 22:01:54 000004M|002/04/-/---|=5:2019=Z coupler commissioning
22/09/09 22:02:03 000004M|002/12/-/---|=5:2019=GPA coupler commissioning
22/09/09 22:02:17 000004M|002/10/-/---|=0:5857=GD/GA/INTIP/RGD: reason of reboot 5
22/09/09 22:02:17 000004M|002/10/-/---|=3:3535=C1 incident, type 8, link 255, info1 0, info2 0, info3 0
22/09/09 22:02:17 000004M|002/10/-/---|=5:0409=The inter-ACT link over IP from (19 1) is up
22/09/09 22:02:18 000004M|002/02/0/000|=4:2113=T2 lapD not established still trying
22/09/09 22:02:18 000004M|002/02/0/001|=4:2113=T2 lapD not established still trying
22/09/09 22:02:18 000004M|002/08/0/000|=4:2113=T2 lapD not established still trying
22/09/09 22:02:33 000004M|002/02/0/000|=4:2080=T2 access is synchronizing on Board (2,2)
22/09/09 22:02:33 000004M|002/02/0/000|=5:2102=T2 access back to normal
22/09/09 22:02:33 000004M|002/02/0/000|=4:2113=T2 lapD not established still trying
22/09/09 22:02:33 000004M|002/02/0/001|=5:2102=T2 access back to normal
22/09/09 22:02:33 000004M|002/02/0/001|=4:2113=T2 lapD not established still trying
22/09/09 22:02:33 000004M|002/08/0/000|=5:2102=T2 access back to normal
22/09/09 22:02:33 000004M|002/08/0/000|=4:2113=T2 lapD not established still trying
22/09/09 22:02:33 000004M|002/02/0/000|=5:0311=T2 Dlap Established
22/09/09 22:02:33 000004M|002/02/0/001|=5:0311=T2 Dlap Established
22/09/09 22:02:33 000004M|002/08/0/000|=5:0311=T2 Dlap Established
22/09/09 22:02:41 000004M|002/00/-/---|=5:2019=VPU5 coupler commissioning
22/09/09 22:02:47 000004M|002/10/-/---|=5:2019=INTIPB coupler commissioning
22/09/09 22:02:48 000004M|002/02/-/---|=5:2019=NPRAE coupler commissioning
22/09/09 22:02:48 000004M|002/08/-/---|=5:2019=NPRAE coupler commissioning
22/09/09 22:03:24 000004M|---/--/-/---|=5:0903=VOCAL FACILITY starting link
22/09/09 22:05:29 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 1 PCS domain 119
22/09/09 22:05:29 000004M|---/--/-/---|=5:0430=PCS 10.30.0.21 is disabled
22/09/09 22:43:31 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
22/09/09 23:36:52 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
23/09/09 00:11:13 000004M|001/00/0/150|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b5:69,1198348
23/09/09 00:11:28 000004M|001/00/0/110|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b5:44,1196314
23/09/09 00:11:29 000004M|001/01/0/138|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b5:bf,1198191
23/09/09 00:11:29 000004M|001/01/0/037|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b6:07,1196189
23/09/09 00:11:44 000004M|001/00/0/164|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b5:66,1198100
23/09/09 00:11:44 000004M|001/01/0/041|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:bf:c3,1196195
23/09/09 00:11:44 000004M|001/01/0/178|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b6:54,1196138
23/09/09 00:11:59 000004M|001/00/0/198|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b5:29,1198471
23/09/09 00:11:59 000004M|001/00/0/208|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b6:4b,1198478
23/09/09 00:11:59 000004M|001/00/0/050|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b5:94,1196366
23/09/09 00:12:06 000004M|---/--/-/---|=0:0412=Lost set on IP domain : Domain number 0 pourcent of the set lost 3600
23/09/09 00:12:14 000004M|001/01/0/038|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:76:d6,1196192
23/09/09 00:12:35 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:b5:69,1198348
23/09/09 00:12:35 000004M|001/00/0/150|=5:2053=Terminal 150 in service
23/09/09 00:13:10 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:b6:54,1196138
23/09/09 00:13:11 000004M|001/01/0/178|=5:2053=Terminal 178 in service
23/09/09 00:13:15 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:b5:44,1196314
23/09/09 00:13:16 000004M|001/00/0/110|=5:2053=Terminal 110 in service
23/09/09 00:13:18 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:b6:07,1196189
23/09/09 00:13:19 000004M|001/01/0/037|=5:2053=Terminal 37 in service
23/09/09 00:13:20 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:b5:bf,1198191
23/09/09 00:13:21 000004M|001/01/0/138|=5:2053=Terminal 138 in service
23/09/09 00:13:33 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:b5:66,1198100
23/09/09 00:13:33 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:bf:c3,1196195
23/09/09 00:13:34 000004M|001/00/0/164|=5:2053=Terminal 164 in service
23/09/09 00:13:34 000004M|001/01/0/041|=5:2053=Terminal 41 in service
23/09/09 00:13:44 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:b5:29,1198471
23/09/09 00:13:44 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:b6:4b,1198478
23/09/09 00:13:45 000004M|001/00/0/208|=5:2053=Terminal 208 in service
23/09/09 00:13:45 000004M|001/00/0/198|=5:2053=Terminal 198 in service
23/09/09 00:13:46 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:b5:94,1196366
23/09/09 00:13:47 000004M|001/00/0/050|=5:2053=Terminal 50 in service
23/09/09 00:14:07 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:76:d6,1196192
23/09/09 00:14:11 000004M|001/01/0/038|=5:2053=Terminal 38 in service
23/09/09 00:30:14 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
23/09/09 00:30:21 000004M|001/01/0/045|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b6:60,1197606
23/09/09 00:32:11 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:b6:60,1197606
23/09/09 00:32:11 000004M|001/01/0/045|=5:2053=Terminal 45 in service
23/09/09 00:46:25 000004M|---/--/-/---|=2:0276=External accounting application 4760 : NO RECOVERY
23/09/09 00:46:42 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
23/09/09 01:07:51 000004M|001/00/0/156|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b3:0a,1198328
23/09/09 01:09:42 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:b3:0a,1198328
23/09/09 01:09:43 000004M|001/00/0/156|=5:2053=Terminal 156 in service
23/09/09 01:23:36 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
23/09/09 01:26:28 000004M|001/00/0/217|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b5:91,1197642
23/09/09 01:28:17 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:b5:91,1197642
23/09/09 01:28:18 000004M|001/00/0/217|=5:2053=Terminal 217 in service
23/09/09 02:16:57 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
23/09/09 03:10:19 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
23/09/09 04:03:41 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
23/09/09 04:57:02 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
23/09/09 05:00:02 000004M|---/--/-/---|=2:0275=ACCOUNTING: Appli ACCOUNTING : feature incident 77 0
23/09/09 05:00:02 000004S|---/--/-/---|=2:0275=ACCOUNTING: Appli ACCOUNTING : feature incident 77 0
23/09/09 05:00:04 000004M|---/--/-/---|=2:0275=ACCOUNTING: Appli ACCOUNTING : feature incident 77 1
23/09/09 05:00:04 000004S|---/--/-/---|=2:0275=ACCOUNTING: Appli ACCOUNTING : feature incident 77 1
23/09/09 05:00:38 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 0 PCS domain 119
23/09/09 05:00:38 000004M|---/--/-/---|=2:0429=PCS 10.30.0.21 is activated
23/09/09 05:05:36 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 1 PCS domain 119
23/09/09 05:05:36 000004M|---/--/-/---|=5:0430=PCS 10.30.0.21 is disabled
23/09/09 05:50:24 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
23/09/09 06:30:11 000004M|---/--/-/---|=3:4019=CSTA server : 1 exit
23/09/09 06:30:11 000004M|---/--/-/---|=4:4018=CSTA server : 1 connection closed
23/09/09 06:30:14 000004M|---/--/-/---|=4:4017=CSTA server : new creation 1 144.119.133.134
23/09/09 06:43:46 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
23/09/09 07:37:07 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
23/09/09 08:03:10 000004M|001/00/0/008|=4:0389=Sig. on IP set: set demand a reset 00:19:b9:18:af:39:02,C1191
23/09/09 08:05:36 000004M|---/--/-/---|=3:1405=ABCA rout src 0 .1.-1
23/09/09 08:22:21 000004M|001/01/0/041|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:bf:c3,1196195
23/09/09 08:22:54 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:bf:c3,1196195
23/09/09 08:22:55 000004M|001/01/0/041|=5:2053=Terminal 41 in service
23/09/09 08:30:29 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
23/09/09 09:23:51 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
23/09/09 09:37:05 000004M|001/00/0/208|=2:0435=Security alert: ARP spoofing detected by 00:80:9f:80:b6:4b
23/09/09 09:45:19 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
23/09/09 09:54:26 000004S|---/--/-/---|=3:2051=Std By CPU. wrong message 46 on neqt 779 info -1
23/09/09 09:55:56 000004M|002/02/0/001|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
23/09/09 09:56:26 000004M|002/02/0/001|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
23/09/09 10:09:45 000004M|---/--/-/---|=3:1405=ABCA rout src 0 .1.-1
23/09/09 10:17:12 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
23/09/09 10:22:17 000004M|---/--/-/---|=4:0274=DTMF receiver release error
23/09/09 10:31:42 000004M|002/02/0/001|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
23/09/09 10:32:12 000004M|002/02/0/001|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
23/09/09 10:37:08 000004M|002/08/0/000|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
23/09/09 10:37:38 000004M|002/08/0/000|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
23/09/09 10:53:07 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
23/09/09 10:53:46 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
23/09/09 10:58:31 000004M|001/01/0/012|=4:0386=Sig. on IP set: No response from de set 00:80:9f:5f:32:b8,1197644
23/09/09 11:00:10 000004M|---/--/-/---|=4:0274=DTMF receiver release error
23/09/09 11:03:08 000004M|---/--/-/---|=4:0274=DTMF receiver release error
23/09/09 11:03:21 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:5f:32:b8,1197644
23/09/09 11:03:22 000004M|001/01/0/012|=5:2053=Terminal 12 in service
23/09/09 11:06:48 000004M|001/00/0/065|=4:0386=Sig. on IP set: No response from de set 00:80:9f:5f:32:d1,1197637
23/09/09 11:07:34 000004M|001/01/0/012|=4:0386=Sig. on IP set: No response from de set 00:80:9f:5f:32:b8,1197644
23/09/09 11:08:17 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:5f:32:d1,1197637
23/09/09 11:08:18 000004M|001/00/0/065|=5:2053=Terminal 65 in service
23/09/09 11:08:47 000004M|---/--/-/---|=4:0274=DTMF receiver release error
23/09/09 11:10:34 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
23/09/09 11:11:31 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
23/09/09 11:13:23 000004M|---/--/-/---|=4:0274=DTMF receiver release error
23/09/09 11:15:21 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
23/09/09 12:03:56 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
23/09/09 12:56:14 000004S|---/--/-/---|=3:2051=Std By CPU. wrong message 46 on neqt 668 info -1
23/09/09 12:57:17 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
23/09/09 12:57:19 000004S|---/--/-/---|=3:2051=Std By CPU. wrong message 46 on neqt 668 info -1
23/09/09 12:57:49 000004S|---/--/-/---|=3:2051=Std By CPU. wrong message 46 on neqt 668 info -1
23/09/09 13:00:20 000004M|002/02/0/001|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
23/09/09 13:00:50 000004M|002/02/0/001|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
23/09/09 13:01:56 000004S|---/--/-/---|=3:2051=Std By CPU. wrong message 46 on neqt 668 info -1
23/09/09 13:06:24 000004S|---/--/-/---|=3:2051=Std By CPU. wrong message 46 on neqt 668 info -1
23/09/09 13:10:42 000004M|001/00/0/065|=4:0386=Sig. on IP set: No response from de set 00:80:9f:5f:32:d1,1197637
23/09/09 13:11:13 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:5f:32:b8,1197644
23/09/09 13:11:14 000004M|001/01/0/012|=5:2053=Terminal 12 in service
23/09/09 13:12:52 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:5f:32:d1,1197637
23/09/09 13:12:53 000004M|001/00/0/065|=5:2053=Terminal 65 in service
23/09/09 13:15:29 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
23/09/09 13:20:55 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
23/09/09 13:26:43 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
23/09/09 13:37:51 000004M|001/00/0/117|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b5:2b,1197634
23/09/09 13:38:45 000004M|001/00/0/186|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:77:08,1198022
23/09/09 13:38:59 000004M|001/01/0/197|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:7d:4e,1195849
23/09/09 13:39:06 000004M|001/00/0/144|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:76:de,1197660
23/09/09 13:39:06 000004M|002/08/0/000|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
23/09/09 13:39:21 000004M|002/08/0/000|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
23/09/09 13:39:21 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:77:08,1198022
23/09/09 13:39:24 000004M|001/00/0/186|=5:2053=Terminal 186 in service
23/09/09 13:39:25 000004M|001/00/0/206|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b5:6d,1198033
23/09/09 13:39:27 000004M|001/00/0/162|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b5:7b,1197661
23/09/09 13:39:35 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:7d:4e,1195849
23/09/09 13:39:38 000004M|001/01/0/197|=5:2053=Terminal 197 in service
23/09/09 13:39:39 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:76:de,1197660
23/09/09 13:39:41 000004M|001/00/0/144|=5:2053=Terminal 144 in service
23/09/09 13:39:55 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:b5:6d,1198033
23/09/09 13:39:56 000004M|001/00/0/206|=5:2053=Terminal 206 in service
23/09/09 13:40:08 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:b5:7b,1197661
23/09/09 13:40:09 000004M|001/00/0/162|=5:2053=Terminal 162 in service
23/09/09 13:41:27 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:b5:2b,1197634
23/09/09 13:41:28 000004M|001/00/0/117|=5:2053=Terminal 117 in service
23/09/09 13:50:39 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
23/09/09 14:02:55 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
23/09/09 14:03:25 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
23/09/09 14:08:45 000004M|---/--/-/---|=4:0274=DTMF receiver release error
23/09/09 14:18:47 000004M|---/--/-/---|=4:0274=DTMF receiver release error
23/09/09 14:33:13 000004M|001/01/0/099|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:76:ee,1198140
23/09/09 14:39:37 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:76:ee,1198140
23/09/09 14:39:40 000004M|001/01/0/099|=5:2053=Terminal 99 in service
23/09/09 14:44:01 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
23/09/09 14:53:10 000004M|002/08/0/000|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
23/09/09 14:53:40 000004M|002/08/0/000|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
23/09/09 15:04:16 000004M|---/--/-/---|=4:0274=DTMF receiver release error
23/09/09 15:06:59 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
23/09/09 15:08:37 000004S|---/--/-/---|=3:2051=Std By CPU. wrong message 46 on neqt 832 info -1
23/09/09 15:10:10 000004S|---/--/-/---|=3:2051=Std By CPU. wrong message 46 on neqt 668 info -1
23/09/09 15:14:46 000004M|---/--/-/---|=4:0274=DTMF receiver release error
23/09/09 15:37:22 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
23/09/09 15:42:53 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
23/09/09 15:47:14 000004S|---/--/-/---|=3:2051=Std By CPU. wrong message 46 on neqt 668 info -1
23/09/09 15:51:32 000004M|---/--/-/---|=4:0274=DTMF receiver release error
23/09/09 15:59:55 000004M|001/01/0/010|=2:0435=Security alert: ARP spoofing detected by 00:80:9f:80:b5:3f
23/09/09 16:30:44 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
23/09/09 16:31:08 000004S|---/--/-/---|=3:2051=Std By CPU. wrong message 46 on neqt 699 info -1
23/09/09 16:53:08 000004M|---/--/-/---|=4:0274=DTMF receiver release error
23/09/09 17:17:30 000004S|---/--/-/---|=3:2051=Std By CPU. wrong message 46 on neqt 668 info -1
23/09/09 17:24:06 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
23/09/09 18:17:27 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
23/09/09 18:22:47 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
23/09/09 18:26:23 000004M|---/--/-/---|=0:1603=IO1 driver error, wrong telephone msg received, line 8314, position (7,8,61)
23/09/09 18:26:23 000004M|---/--/-/---|=3:1607=00.00.1d.00.0f.0f.ff.00.04.ff.9a.ff.ff.ff.ff
23/09/09 18:26:23 000004M|---/--/-/---|=3:1607=12.00.11.0b.00.00.00.00.00.00.00.00.ff.ff.ff
23/09/09 18:27:08 000004M|---/--/-/---|=0:1603=IO1 driver error, wrong telephone msg received, line 8314, position (7,8,61)
23/09/09 18:27:08 000004M|---/--/-/---|=3:1607=00.00.1d.00.0f.0f.ff.00.04.ff.9a.ff.ff.ff.ff
23/09/09 18:27:08 000004M|---/--/-/---|=3:1607=12.00.11.0b.00.00.00.00.00.00.00.00.ff.ff.ff
23/09/09 18:56:27 000004M|001/00/0/152|=4:0389=Sig. on IP set: set demand a reset 00:0f:1f:8e:ed:94:02,C1192
23/09/09 19:10:49 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
23/09/09 20:04:11 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
23/09/09 20:57:32 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
23/09/09 21:50:54 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
23/09/09 21:53:15 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
23/09/09 21:54:13 000004S|---/--/-/---|=3:1125=external alarm : "mtcl login"
23/09/09 22:00:38 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
23/09/09 22:44:16 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
23/09/09 23:15:04 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
23/09/09 23:37:37 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
24/09/09 00:30:59 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
24/09/09 00:42:12 000004M|001/00/0/228|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:77:18,1198122
24/09/09 00:42:12 000004M|001/00/0/231|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b2:82,1195852
24/09/09 00:42:12 000004M|001/00/0/208|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b6:4b,1198478
24/09/09 00:42:12 000004M|001/01/0/012|=4:0386=Sig. on IP set: No response from de set 00:80:9f:5f:32:b8,1197644
24/09/09 00:42:12 000004M|001/00/0/095|=4:0386=Sig. on IP set: No response from de set 00:80:9f:5f:32:b7,1196382
24/09/09 00:42:12 000004M|001/01/0/026|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b6:33,1196178
24/09/09 00:42:12 000004M|001/01/0/025|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b5:12,1196177
24/09/09 00:42:12 000004M|001/00/0/216|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b2:6d,1197600
24/09/09 00:42:12 000004M|001/00/0/242|=4:0386=Sig. on IP set: No response from de set 00:80:9f:79:7b:0d,1196100
24/09/09 00:42:34 000004M|---/--/-/---|=0:0412=Lost set on IP domain : Domain number 0 pourcent of the set lost 4600
24/09/09 00:43:15 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:5f:32:b8,1197644
24/09/09 00:43:16 000004M|001/01/0/012|=5:2053=Terminal 12 in service
24/09/09 00:43:17 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:b6:33,1196178
24/09/09 00:43:18 000004M|001/01/0/026|=5:2053=Terminal 26 in service
24/09/09 00:43:36 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:b6:4b,1198478
24/09/09 00:43:36 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:b2:6d,1197600
24/09/09 00:43:37 000004M|001/00/0/208|=5:2053=Terminal 208 in service
24/09/09 00:43:37 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:79:7b:0d,1196100
24/09/09 00:43:37 000004M|001/00/0/216|=5:2053=Terminal 216 in service
24/09/09 00:43:40 000004M|001/00/0/242|=5:2053=Terminal 242 in service
24/09/09 00:43:40 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:5f:32:b7,1196382
24/09/09 00:43:41 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:77:18,1198122
24/09/09 00:43:41 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:b5:12,1196177
24/09/09 00:43:42 000004M|001/00/0/095|=5:2053=Terminal 95 in service
24/09/09 00:43:42 000004M|001/01/0/025|=5:2053=Terminal 25 in service
24/09/09 00:43:44 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:b2:82,1195852
24/09/09 00:43:44 000004M|001/00/0/228|=5:2053=Terminal 228 in service
24/09/09 00:43:45 000004M|001/00/0/231|=5:2053=Terminal 231 in service
24/09/09 00:46:50 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
24/09/09 01:24:21 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
24/09/09 02:12:50 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
24/09/09 02:17:42 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
24/09/09 03:11:04 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
24/09/09 04:04:26 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
24/09/09 04:57:47 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
24/09/09 05:00:02 000004M|---/--/-/---|=2:0275=ACCOUNTING: Appli ACCOUNTING : feature incident 77 0
24/09/09 05:00:02 000004S|---/--/-/---|=2:0275=ACCOUNTING: Appli ACCOUNTING : feature incident 77 0
24/09/09 05:00:03 000004M|---/--/-/---|=2:0275=ACCOUNTING: Appli ACCOUNTING : feature incident 77 1
24/09/09 05:00:03 000004S|---/--/-/---|=2:0275=ACCOUNTING: Appli ACCOUNTING : feature incident 77 1
24/09/09 05:00:29 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 0 PCS domain 119
24/09/09 05:00:29 000004M|---/--/-/---|=2:0429=PCS 10.30.0.21 is activated
24/09/09 05:05:07 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 1 PCS domain 119
24/09/09 05:05:07 000004M|---/--/-/---|=5:0430=PCS 10.30.0.21 is disabled
24/09/09 05:51:09 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
24/09/09 06:30:30 000004M|---/--/-/---|=3:4019=CSTA server : 1 exit
24/09/09 06:30:30 000004M|---/--/-/---|=4:4018=CSTA server : 1 connection closed
24/09/09 06:30:34 000004M|---/--/-/---|=4:4017=CSTA server : new creation 1 144.119.133.134
24/09/09 06:44:31 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
24/09/09 07:37:52 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
24/09/09 08:31:14 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
24/09/09 08:46:31 000004M|001/00/0/186|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:77:08,1198022
24/09/09 08:47:07 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:77:08,1198022
24/09/09 08:47:11 000004M|001/00/0/186|=5:2053=Terminal 186 in service
24/09/09 09:10:36 000004M|---/--/-/---|=3:5816=Minor failure in SIP component
24/09/09 09:24:36 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
24/09/09 09:33:01 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
24/09/09 09:33:48 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
24/09/09 10:00:58 000004M|---/--/-/---|=4:0274=DTMF receiver release error
24/09/09 10:17:57 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
24/09/09 10:19:04 000004M|002/02/0/000|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
24/09/09 10:19:34 000004M|002/02/0/000|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
24/09/09 10:29:04 000004M|---/--/-/---|=4:0274=DTMF receiver release error
24/09/09 10:52:57 000004M|---/--/-/---|=4:0274=DTMF receiver release error
24/09/09 10:55:14 000004M|---/--/-/---|=4:0274=DTMF receiver release error
24/09/09 11:07:09 000004M|000/00/0/000|=4:2617=Obstraf redirected 1 0 0
24/09/09 11:11:19 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
24/09/09 11:32:08 000004M|---/--/-/---|=0:1612=Protocol error on Alcatel 8&9 series, type 30 (neqt 577)
24/09/09 11:32:08 000004M|---/--/-/---|=3:1613=15.04.1e.00.02.02.06.00.06.6e.00.00.01.00.00
24/09/09 11:41:45 000004M|---/--/-/---|=4:0274=DTMF receiver release error
24/09/09 12:04:41 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
24/09/09 12:58:02 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
24/09/09 13:17:57 000004M|---/--/-/---|=0:1612=Protocol error on Alcatel 8&9 series, type 30 (neqt 578)
24/09/09 13:17:57 000004M|---/--/-/---|=3:1613=15.04.1e.00.02.02.06.00.06.6e.00.00.01.00.00
24/09/09 13:31:40 000004M|---/--/-/---|=4:0274=DTMF receiver release error
24/09/09 13:47:30 000004M|001/01/0/012|=4:0386=Sig. on IP set: No response from de set 00:80:9f:5f:32:b8,1197644
24/09/09 13:50:28 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:5f:32:b8,1197644
24/09/09 13:50:29 000004M|001/01/0/012|=5:2053=Terminal 12 in service
24/09/09 13:51:24 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
24/09/09 13:58:26 000004M|---/--/-/---|=4:0274=DTMF receiver release error
24/09/09 14:34:26 000004M|---/--/-/---|=4:0274=DTMF receiver release error
24/09/09 14:43:58 000004M|---/--/-/---|=4:0274=DTMF receiver release error
24/09/09 14:44:46 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
24/09/09 14:55:12 000004M|002/08/0/000|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
24/09/09 14:55:42 000004M|002/08/0/000|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
24/09/09 15:24:45 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
24/09/09 15:34:57 000004M|002/02/0/001|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
24/09/09 15:35:27 000004M|002/02/0/001|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
24/09/09 15:36:04 000004M|002/02/0/000|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
24/09/09 15:36:34 000004M|002/02/0/000|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
24/09/09 15:38:07 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
24/09/09 15:39:33 000004M|---/--/-/---|=4:0274=DTMF receiver release error
24/09/09 15:55:11 000004M|002/08/0/000|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
24/09/09 15:55:41 000004M|002/08/0/000|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
24/09/09 15:59:28 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
24/09/09 16:15:25 000004M|---/--/-/---|=4:0274=DTMF receiver release error
24/09/09 16:21:23 000004M|001/00/0/152|=4:0389=Sig. on IP set: set demand a reset 00:0f:1f:8e:ed:94:02,C1192
24/09/09 16:25:53 000004M|---/--/-/---|=3:1405=ABCA rout src 0 .1.-1
24/09/09 16:31:29 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
24/09/09 16:32:36 000004M|---/--/-/---|=4:0274=DTMF receiver release error
24/09/09 16:52:58 000004M|002/02/0/000|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
24/09/09 16:53:28 000004M|002/02/0/000|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
24/09/09 16:54:15 000004M|---/--/-/---|=4:0274=DTMF receiver release error
24/09/09 17:11:31 000004M|---/--/-/---|=4:0274=DTMF receiver release error
24/09/09 17:24:51 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
24/09/09 18:13:27 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
24/09/09 18:18:12 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
24/09/09 18:54:37 000004M|001/00/0/008|=4:0389=Sig. on IP set: set demand a reset 00:19:b9:18:af:39:02,C1191
24/09/09 19:11:34 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
24/09/09 19:26:58 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
24/09/09 20:04:56 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
24/09/09 20:58:17 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
24/09/09 21:51:39 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
24/09/09 22:45:01 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
24/09/09 23:38:22 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
25/09/09 00:31:44 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
25/09/09 00:46:50 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
25/09/09 01:25:06 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
25/09/09 02:18:27 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
25/09/09 02:59:50 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
25/09/09 03:11:49 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
25/09/09 04:05:11 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
25/09/09 04:58:32 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
25/09/09 05:00:02 000004M|---/--/-/---|=2:0275=ACCOUNTING: Appli ACCOUNTING : feature incident 77 0
25/09/09 05:00:02 000004S|---/--/-/---|=2:0275=ACCOUNTING: Appli ACCOUNTING : feature incident 77 0
25/09/09 05:00:03 000004M|---/--/-/---|=2:0275=ACCOUNTING: Appli ACCOUNTING : feature incident 77 1
25/09/09 05:00:03 000004S|---/--/-/---|=2:0275=ACCOUNTING: Appli ACCOUNTING : feature incident 77 1
25/09/09 05:00:39 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 0 PCS domain 119
25/09/09 05:00:39 000004M|---/--/-/---|=2:0429=PCS 10.30.0.21 is activated
25/09/09 05:05:08 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 1 PCS domain 119
25/09/09 05:05:08 000004M|---/--/-/---|=5:0430=PCS 10.30.0.21 is disabled
25/09/09 05:51:54 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
25/09/09 06:30:50 000004M|---/--/-/---|=3:4019=CSTA server : 1 exit
25/09/09 06:30:50 000004M|---/--/-/---|=4:4018=CSTA server : 1 connection closed
25/09/09 06:30:53 000004M|---/--/-/---|=4:4017=CSTA server : new creation 1 144.119.133.134
25/09/09 06:45:16 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
25/09/09 07:38:37 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
25/09/09 07:50:38 000004M|001/00/0/008|=4:0389=Sig. on IP set: set demand a reset 00:19:b9:18:af:39:02,C1191
25/09/09 07:59:12 000004M|---/--/-/---|=3:1405=ABCA rout src 0 .1.-1
25/09/09 08:31:59 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
25/09/09 09:22:48 000004M|---/--/-/---|=4:0274=DTMF receiver release error
25/09/09 09:24:53 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
25/09/09 09:25:21 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
25/09/09 09:26:13 000004M|001/00/0/235|=2:0435=Security alert: ARP spoofing detected by 00:80:9f:80:b5:43
25/09/09 09:30:53 000004M|---/--/-/---|=4:0274=DTMF receiver release error
25/09/09 09:34:30 000004M|---/--/-/---|=4:0274=DTMF receiver release error
25/09/09 09:39:26 000004M|001/01/0/192|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:79:99,1195844
25/09/09 09:41:10 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 33,00:80:9f:80:79:99,1195844
25/09/09 09:41:12 000004M|001/01/0/192|=5:2053=Terminal 192 in service
25/09/09 09:44:21 000004M|001/00/0/187|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b5:78,1198068
25/09/09 09:46:44 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:b5:78,1198068
25/09/09 09:46:45 000004M|001/00/0/187|=5:2053=Terminal 187 in service
25/09/09 09:47:58 000004M|---/--/-/---|=4:0274=DTMF receiver release error
25/09/09 10:15:44 000004M|001/00/0/186|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:77:08,1198022
25/09/09 10:16:06 000004M|001/01/0/197|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:7d:4e,1195849
25/09/09 10:16:20 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:77:08,1198022
25/09/09 10:16:21 000004M|001/00/0/144|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:76:de,1197660
25/09/09 10:16:23 000004M|001/00/0/186|=5:2053=Terminal 186 in service
25/09/09 10:16:36 000004M|001/00/0/206|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b5:6d,1198033
25/09/09 10:16:39 000004M|002/08/0/000|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
25/09/09 10:16:41 000004M|002/08/0/000|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
25/09/09 10:16:41 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:7d:4e,1195849
25/09/09 10:16:44 000004M|001/01/0/197|=5:2053=Terminal 197 in service
25/09/09 10:16:52 000004M|001/00/0/162|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b5:7b,1197661
25/09/09 10:16:54 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:76:de,1197660
25/09/09 10:16:56 000004M|001/00/0/144|=5:2053=Terminal 144 in service
25/09/09 10:17:07 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:b5:6d,1198033
25/09/09 10:17:08 000004M|001/00/0/206|=5:2053=Terminal 206 in service
25/09/09 10:17:09 000004M|001/00/0/131|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:77:19,1198053
25/09/09 10:17:22 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:b5:7b,1197661
25/09/09 10:17:24 000004M|001/00/0/162|=5:2053=Terminal 162 in service
25/09/09 10:17:34 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:77:19,1198053
25/09/09 10:17:36 000004M|001/00/0/131|=5:2053=Terminal 131 in service
25/09/09 10:18:42 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
25/09/09 10:22:08 000004M|---/--/-/---|=4:0391=IP set Inci.: Update of IP sets by Tftp
25/09/09 10:24:33 000004M|---/--/-/---|=4:0392=IP set Inci.: Update of IP sets by Tftp ended
25/09/09 10:25:10 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
25/09/09 10:28:27 000004M|001/00/0/247|=4:0386=Sig. on IP set: No response from de set 00:80:9f:85:7a:75,1198338
25/09/09 10:38:25 000004M|002/02/0/001|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
25/09/09 10:38:55 000004M|002/02/0/001|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
25/09/09 10:55:23 000004M|001/01/0/105|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:76:dd,1198146
25/09/09 11:12:04 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
25/09/09 11:24:41 000004M|---/--/-/---|=4:0274=DTMF receiver release error
25/09/09 11:29:05 000004M|001/00/0/019|=2:0435=Security alert: ARP spoofing detected by 00:80:9f:80:b5:2f
25/09/09 12:05:26 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
25/09/09 12:29:23 000004M|001/01/0/043|=2:0435=Security alert: ARP spoofing detected by 00:80:9f:80:b6:1c
25/09/09 12:58:47 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
25/09/09 13:30:30 000004M|---/--/-/---|=4:0274=DTMF receiver release error
25/09/09 13:32:51 000004M|---/--/-/---|=4:0274=DTMF receiver release error
25/09/09 13:52:09 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
25/09/09 13:52:51 000004M|001/01/0/049|=2:0435=Security alert: ARP spoofing detected by 00:80:9f:80:b6:71
25/09/09 13:52:59 000004M|---/--/-/---|=4:0274=DTMF receiver release error
25/09/09 14:08:00 000004M|---/--/-/---|=4:0274=DTMF receiver release error
25/09/09 14:17:39 000004M|---/--/-/---|=4:0274=DTMF receiver release error
25/09/09 14:31:48 000004M|001/01/0/195|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:75:a1,1195847
25/09/09 14:32:07 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:75:a1,1195847
25/09/09 14:32:09 000004M|001/01/0/195|=5:2053=Terminal 195 in service
25/09/09 14:37:13 000004M|---/--/-/---|=4:0274=DTMF receiver release error
25/09/09 14:45:31 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
25/09/09 14:48:05 000004M|---/--/-/---|=4:0274=DTMF receiver release error
25/09/09 14:54:22 000004M|---/--/-/---|=4:0274=DTMF receiver release error
25/09/09 15:05:57 000004M|002/02/0/000|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
25/09/09 15:06:27 000004M|002/02/0/000|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
25/09/09 15:09:36 000004M|001/01/0/124|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:76:f5,1198171
25/09/09 15:10:51 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:76:f5,1198171
25/09/09 15:10:54 000004M|001/01/0/124|=5:2053=Terminal 124 in service
25/09/09 15:11:07 000004M|001/01/0/143|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:77:2f,1198196
25/09/09 15:14:30 000004M|001/01/0/022|=2:0435=Security alert: ARP spoofing detected by 00:80:9f:80:b2:fb
25/09/09 15:16:59 000004M|001/01/0/174|=2:0435=Security alert: ARP spoofing detected by 00:80:9f:80:b2:8c
25/09/09 15:22:17 000004M|001/00/0/041|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:77:33,1198164
25/09/09 15:23:12 000004M|001/01/0/099|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:76:ee,1198140
25/09/09 15:27:51 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:76:ee,1198140
25/09/09 15:27:54 000004M|001/01/0/099|=5:2053=Terminal 99 in service
25/09/09 15:38:16 000004M|001/01/0/039|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:bf:43,1196193
25/09/09 15:38:52 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
25/09/09 15:40:00 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:bf:43,1196193
25/09/09 15:40:02 000004M|001/01/0/039|=5:2053=Terminal 39 in service
25/09/09 15:41:16 000004M|001/01/0/039|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:bf:43,1196193
25/09/09 15:44:21 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:bf:43,1196193
25/09/09 15:44:23 000004M|001/01/0/039|=5:2053=Terminal 39 in service
25/09/09 15:44:48 000004M|001/01/0/039|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:bf:43,1196193
25/09/09 15:45:51 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:bf:43,1196193
25/09/09 15:45:52 000004M|001/01/0/039|=5:2053=Terminal 39 in service
25/09/09 15:46:17 000004M|001/01/0/039|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:bf:43,1196193
25/09/09 15:46:31 000004M|---/--/-/---|=4:0274=DTMF receiver release error
25/09/09 15:51:35 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:bf:43,1196193
25/09/09 15:51:36 000004M|001/01/0/039|=5:2053=Terminal 39 in service
25/09/09 15:52:03 000004M|001/01/0/039|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:bf:43,1196193
25/09/09 15:53:04 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:bf:43,1196193
25/09/09 15:53:05 000004M|001/01/0/039|=5:2053=Terminal 39 in service
25/09/09 15:58:28 000004M|---/--/-/---|=4:0274=DTMF receiver release error
25/09/09 16:03:09 000004S|---/--/-/---|=3:2051=Std By CPU. wrong message 46 on neqt 975 info -1
25/09/09 16:08:54 000004M|---/--/-/---|=4:0274=DTMF receiver release error
25/09/09 16:17:38 000004M|---/--/-/---|=4:0274=DTMF receiver release error
25/09/09 16:28:14 000004M|---/--/-/---|=4:0274=DTMF receiver release error
25/09/09 16:32:14 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
25/09/09 16:38:59 000004M|---/--/-/---|=0:1612=Protocol error on Alcatel 8&9 series, type 11 (neqt 984)
25/09/09 16:38:59 000004M|---/--/-/---|=3:1613=15.04.0b.00.00.00.97.20.20.ff.00.00.00.00.00
25/09/09 16:38:59 000004M|---/--/-/---|=3:1613=15.04.0b.00.00.00.89.20.70.ff.00.00.00.00.00
25/09/09 16:44:33 000004M|002/08/0/000|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
25/09/09 16:45:03 000004M|002/08/0/000|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
25/09/09 16:46:15 000004M|---/--/-/---|=4:0274=DTMF receiver release error
25/09/09 16:48:33 000004M|---/--/-/---|=4:0274=DTMF receiver release error
25/09/09 16:51:26 000004M|000/00/0/000|=4:2617=Obstraf redirected 1 0 0
25/09/09 17:04:08 000004M|---/--/-/---|=4:0274=DTMF receiver release error
25/09/09 17:09:54 000004M|001/01/0/124|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:76:f5,1198171
25/09/09 17:13:02 000004M|---/--/-/---|=4:0274=DTMF receiver release error
25/09/09 17:18:00 000004M|001/01/0/120|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:76:69,1198167
25/09/09 17:25:36 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
25/09/09 17:26:22 000004M|001/01/0/132|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:76:c9,1198184
25/09/09 17:28:29 000004M|001/01/0/094|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:bf:b7,1198135
25/09/09 17:31:23 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:bf:b7,1198135
25/09/09 17:31:24 000004M|001/01/0/094|=5:2053=Terminal 94 in service
25/09/09 17:44:47 000004M|001/00/0/225|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:76:bc,1198178
25/09/09 17:50:05 000004M|001/01/0/126|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:7d:98,1198176
25/09/09 17:54:22 000004M|001/01/0/125|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:7d:29,1198175
25/09/09 18:04:16 000004M|002/02/0/001|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
25/09/09 18:04:46 000004M|002/02/0/001|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
25/09/09 18:18:57 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
25/09/09 18:28:15 000004M|001/01/0/144|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:76:d5,1198198
25/09/09 18:43:59 000004M|001/00/0/008|=4:0389=Sig. on IP set: set demand a reset 00:19:b9:18:af:39:02,C1191
25/09/09 18:46:54 000004M|001/00/0/152|=4:0389=Sig. on IP set: set demand a reset 00:0f:1f:8e:ed:94:02,C1192
25/09/09 19:12:19 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
25/09/09 20:05:41 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
25/09/09 20:59:02 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
25/09/09 21:52:24 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
25/09/09 22:45:46 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
25/09/09 23:39:07 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
26/09/09 00:32:29 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
26/09/09 00:46:48 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
26/09/09 01:25:51 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
26/09/09 02:19:12 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
26/09/09 03:12:34 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
26/09/09 03:38:29 000004M|001/00/0/122|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b2:87,1198104
26/09/09 03:42:30 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:b2:87,1198104
26/09/09 03:42:31 000004M|001/00/0/122|=5:2053=Terminal 122 in service
26/09/09 04:05:56 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
26/09/09 04:59:17 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
26/09/09 05:00:02 000004M|---/--/-/---|=2:0275=ACCOUNTING: Appli ACCOUNTING : feature incident 77 0
26/09/09 05:00:02 000004S|---/--/-/---|=2:0275=ACCOUNTING: Appli ACCOUNTING : feature incident 77 0
26/09/09 05:00:03 000004M|---/--/-/---|=2:0275=ACCOUNTING: Appli ACCOUNTING : feature incident 77 1
26/09/09 05:00:03 000004S|---/--/-/---|=2:0275=ACCOUNTING: Appli ACCOUNTING : feature incident 77 1
26/09/09 05:00:39 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 0 PCS domain 119
26/09/09 05:00:39 000004M|---/--/-/---|=2:0429=PCS 10.30.0.21 is activated
26/09/09 05:05:07 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 1 PCS domain 119
26/09/09 05:05:07 000004M|---/--/-/---|=5:0430=PCS 10.30.0.21 is disabled
26/09/09 05:52:39 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
26/09/09 06:30:39 000004M|---/--/-/---|=3:4019=CSTA server : 1 exit
26/09/09 06:30:39 000004M|---/--/-/---|=4:4018=CSTA server : 1 connection closed
26/09/09 06:30:42 000004M|---/--/-/---|=4:4017=CSTA server : new creation 1 144.119.133.134
26/09/09 06:46:01 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
26/09/09 07:03:11 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
26/09/09 07:39:22 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
26/09/09 08:32:44 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
26/09/09 08:37:32 000004M|002/02/0/001|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
26/09/09 08:38:02 000004M|002/02/0/001|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
26/09/09 09:06:55 000004M|002/02/0/001|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
26/09/09 09:07:25 000004M|002/02/0/001|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
26/09/09 09:26:06 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
26/09/09 10:02:41 000004M|002/02/0/001|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
26/09/09 10:03:11 000004M|002/02/0/001|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
26/09/09 10:19:27 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
26/09/09 11:12:49 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
26/09/09 12:06:11 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
26/09/09 12:59:32 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
26/09/09 13:22:06 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:76:f5,1198171
26/09/09 13:22:09 000004M|001/01/0/124|=5:2053=Terminal 124 in service
26/09/09 13:52:54 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
26/09/09 14:46:16 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
26/09/09 15:39:37 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
26/09/09 16:32:59 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
26/09/09 17:26:21 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
26/09/09 17:31:57 000004M|002/08/0/000|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
26/09/09 17:32:27 000004M|002/08/0/000|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
26/09/09 18:19:42 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
26/09/09 19:13:04 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
26/09/09 20:06:26 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
26/09/09 20:59:47 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
26/09/09 21:53:09 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
26/09/09 22:46:31 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
26/09/09 23:39:52 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
27/09/09 00:33:14 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
27/09/09 00:50:37 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
27/09/09 01:26:36 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
27/09/09 02:19:57 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
27/09/09 03:13:19 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
27/09/09 04:06:41 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
27/09/09 05:00:02 000004M|---/--/-/---|=2:0275=ACCOUNTING: Appli ACCOUNTING : feature incident 77 0
27/09/09 05:00:02 000004S|---/--/-/---|=2:0275=ACCOUNTING: Appli ACCOUNTING : feature incident 77 0
27/09/09 05:00:02 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
27/09/09 05:00:03 000004M|---/--/-/---|=2:0275=ACCOUNTING: Appli ACCOUNTING : feature incident 77 1
27/09/09 05:00:03 000004S|---/--/-/---|=2:0275=ACCOUNTING: Appli ACCOUNTING : feature incident 77 1
27/09/09 05:00:32 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 0 PCS domain 119
27/09/09 05:00:32 000004M|---/--/-/---|=2:0429=PCS 10.30.0.21 is activated
27/09/09 05:05:08 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 1 PCS domain 119
27/09/09 05:05:08 000004M|---/--/-/---|=5:0430=PCS 10.30.0.21 is disabled
27/09/09 05:53:24 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
27/09/09 06:30:55 000004M|---/--/-/---|=3:4019=CSTA server : 1 exit
27/09/09 06:30:55 000004M|---/--/-/---|=4:4018=CSTA server : 1 connection closed
27/09/09 06:30:59 000004M|---/--/-/---|=4:4017=CSTA server : new creation 1 144.119.133.134
27/09/09 06:46:46 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
27/09/09 07:40:07 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
27/09/09 07:54:17 000004M|---/--/-/---|=3:1405=ABCA rout src 0 .1.-1
27/09/09 08:11:43 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:77:2f,1198196
27/09/09 08:11:46 000004M|001/01/0/143|=5:2053=Terminal 143 in service
27/09/09 08:17:53 000004M|001/01/0/124|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:76:f5,1198171
27/09/09 08:18:47 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:76:f5,1198171
27/09/09 08:18:50 000004M|001/01/0/124|=5:2053=Terminal 124 in service
27/09/09 08:21:46 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:76:c9,1198184
27/09/09 08:21:48 000004M|001/01/0/132|=5:2053=Terminal 132 in service
27/09/09 08:33:29 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
27/09/09 09:13:35 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:7d:98,1198176
27/09/09 09:13:38 000004M|001/01/0/126|=5:2053=Terminal 126 in service
27/09/09 09:14:03 000004M|002/02/0/000|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
27/09/09 09:14:33 000004M|002/02/0/000|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
27/09/09 09:17:27 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:76:bc,1198178
27/09/09 09:17:29 000004M|001/00/0/225|=5:2053=Terminal 225 in service
27/09/09 09:26:51 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
27/09/09 09:28:29 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:76:dd,1198146
27/09/09 09:28:31 000004M|001/01/0/105|=5:2053=Terminal 105 in service
27/09/09 09:37:02 000004M|001/01/0/105|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:76:dd,1198146
27/09/09 09:37:34 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:76:dd,1198146
27/09/09 09:37:37 000004M|001/01/0/105|=5:2053=Terminal 105 in service
27/09/09 09:41:50 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:76:d5,1198198
27/09/09 09:41:53 000004M|001/01/0/144|=5:2053=Terminal 144 in service
27/09/09 09:57:00 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
27/09/09 09:59:57 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
27/09/09 10:02:37 000004M|001/01/0/144|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:76:d5,1198198
27/09/09 10:03:15 000004M|001/01/0/105|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:76:dd,1198146
27/09/09 10:05:18 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:76:d5,1198198
27/09/09 10:05:21 000004M|001/01/0/144|=5:2053=Terminal 144 in service
27/09/09 10:07:22 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:76:dd,1198146
27/09/09 10:07:24 000004M|001/01/0/105|=5:2053=Terminal 105 in service
27/09/09 10:10:18 000004M|001/00/0/186|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:77:08,1198022
27/09/09 10:10:22 000004M|001/01/0/197|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:7d:4e,1195849
27/09/09 10:10:43 000004M|001/00/0/144|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:76:de,1197660
27/09/09 10:10:54 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:77:08,1198022
27/09/09 10:10:57 000004M|001/00/0/186|=5:2053=Terminal 186 in service
27/09/09 10:10:58 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:7d:4e,1195849
27/09/09 10:11:01 000004M|001/01/0/197|=5:2053=Terminal 197 in service
27/09/09 10:11:01 000004M|001/00/0/206|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b5:6d,1198033
27/09/09 10:11:09 000004M|001/00/0/162|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b5:7b,1197661
27/09/09 10:11:16 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:76:de,1197660
27/09/09 10:11:17 000004M|001/00/0/144|=5:2053=Terminal 144 in service
27/09/09 10:11:32 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:b5:6d,1198033
27/09/09 10:11:32 000004M|001/00/0/206|=5:2053=Terminal 206 in service
27/09/09 10:11:40 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:b5:7b,1197661
27/09/09 10:11:41 000004M|001/00/0/162|=5:2053=Terminal 162 in service
27/09/09 10:12:17 000004M|001/00/0/128|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b2:bf,1198173
27/09/09 10:20:12 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
27/09/09 10:21:20 000004M|001/01/0/116|=2:0435=Security alert: ARP spoofing detected by 00:80:9f:80:b5:1c
27/09/09 10:21:53 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:7d:29,1198175
27/09/09 10:21:57 000004M|001/01/0/125|=5:2053=Terminal 125 in service
27/09/09 10:23:05 000004S|---/--/-/---|=3:2051=Std By CPU. wrong message 46 on neqt 779 info -1
27/09/09 10:24:57 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:b2:bf,1198173
27/09/09 10:24:58 000004M|001/00/0/128|=5:2053=Terminal 128 in service
27/09/09 10:27:42 000004M|001/00/0/128|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b2:bf,1198173
27/09/09 10:30:14 000004M|001/00/0/128|=4:0389=Sig. on IP set: set demand a reset 00:80:9f:80:76:f6,1198173
27/09/09 10:30:50 000004M|001/00/0/128|=4:0385=Init of IP set: Wrong type of NOE set 00:80:9f:80:76:f6,1198173
27/09/09 10:30:50 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 10,00:80:9f:80:76:f6,1198173
27/09/09 10:30:53 000004M|001/00/0/128|=5:2053=Terminal 128 in service
27/09/09 10:30:53 000004M|---/--/-/---|=0:1612=Protocol error on Alcatel 8&9 series, type 11 (neqt 703)
27/09/09 10:30:53 000004M|---/--/-/---|=3:1613=15.04.0b.00.00.00.82.12.40.ff.00.00.00.00.00
27/09/09 10:30:53 000004M|---/--/-/---|=3:1613=15.04.0b.00.00.00.82.12.10.ff.00.00.00.00.00
27/09/09 10:30:53 000004M|---/--/-/---|=0:1612=Protocol error on Alcatel 8&9 series, type 18 (neqt 703)
27/09/09 10:30:53 000004M|---/--/-/---|=3:1613=15.04.12.00.06.06.82.12.10.ff.00.00.00.00.00
27/09/09 10:30:53 000004M|---/--/-/---|=3:1613=15.04.0b.00.00.00.82.20.80.ff.00.00.00.00.00
27/09/09 10:31:14 000004M|---/--/-/---|=3:1505=Rout: eqt number erroneous 557785376 with desti 230 type 0
27/09/09 10:31:15 000004S|---/--/-/---|=3:1505=Rout: eqt number erroneous 557785376 with desti 230 type 0
27/09/09 10:31:20 000004M|001/00/0/128|=4:0389=Sig. on IP set: set demand a reset 00:80:9f:80:76:f6,1198173
27/09/09 10:32:00 000004M|001/00/0/128|=5:2053=Terminal 128 in service
27/09/09 10:32:27 000004M|001/00/0/128|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:76:f6,1198173
27/09/09 10:33:12 000004M|---/--/-/---|=0:1612=Protocol error on Alcatel 8&9 series, type 30 (neqt 578)
27/09/09 10:33:12 000004M|---/--/-/---|=3:1613=15.04.1e.00.02.02.06.00.06.6e.00.00.01.00.00
27/09/09 10:33:19 000004M|001/00/0/070|=4:0389=Sig. on IP set: set demand a reset 00:80:9f:80:b2:bf,1196371
27/09/09 10:33:59 000004M|001/00/0/070|=5:2053=Terminal 70 in service
27/09/09 10:34:27 000004M|001/00/0/070|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b2:bf,1196371
27/09/09 10:34:52 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:76:69,1198167
27/09/09 10:34:55 000004M|001/01/0/120|=5:2053=Terminal 120 in service
27/09/09 10:36:25 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:76:f6,1198173
27/09/09 10:36:28 000004M|001/00/0/128|=5:2053=Terminal 128 in service
27/09/09 10:53:01 000004S|---/--/-/---|=3:2051=Std By CPU. wrong message 46 on neqt 779 info -1
27/09/09 10:58:59 000004M|001/00/0/158|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b2:59,1198332
27/09/09 10:59:03 000004M|001/00/0/156|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b3:0a,1198328
27/09/09 10:59:05 000004M|001/00/0/153|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b3:10,1198330
27/09/09 11:01:47 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:b3:10,1198330
27/09/09 11:01:48 000004M|001/00/0/153|=5:2053=Terminal 153 in service
27/09/09 11:01:52 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:b3:0a,1198328
27/09/09 11:01:53 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:b2:59,1198332
27/09/09 11:01:53 000004M|001/00/0/156|=5:2053=Terminal 156 in service
27/09/09 11:01:54 000004M|001/00/0/158|=5:2053=Terminal 158 in service
27/09/09 11:02:06 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:b2:bf,1196371
27/09/09 11:02:07 000004M|001/00/0/070|=5:2053=Terminal 70 in service
27/09/09 11:13:34 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
27/09/09 11:31:58 000004M|002/08/0/000|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
27/09/09 11:32:28 000004M|002/08/0/000|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
27/09/09 11:54:24 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
27/09/09 12:06:56 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
27/09/09 12:23:12 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
27/09/09 12:23:39 000004M|001/00/0/117|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b5:2b,1197634
27/09/09 12:24:20 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:b5:2b,1197634
27/09/09 12:24:21 000004M|001/00/0/117|=5:2053=Terminal 117 in service
27/09/09 12:24:37 000004M|001/00/0/247|=5:2053=Terminal 247 in service
27/09/09 12:24:48 000004M|001/00/0/117|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b5:2b,1197634
27/09/09 12:25:56 000004M|001/00/0/076|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:76:67,1198402
27/09/09 12:26:34 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:b5:2b,1197634
27/09/09 12:26:35 000004M|001/00/0/117|=5:2053=Terminal 117 in service
27/09/09 13:00:17 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
27/09/09 13:03:42 000004M|001/01/0/060|=2:0435=Security alert: ARP spoofing detected by 00:80:9f:80:b5:e6
27/09/09 13:09:09 000004M|001/00/0/247|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:76:8b,1198338
27/09/09 13:53:39 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
27/09/09 14:14:36 000004M|---/--/-/---|=4:0274=DTMF receiver release error
27/09/09 14:32:31 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
27/09/09 14:47:01 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
27/09/09 14:48:49 000004M|---/--/-/---|=4:0274=DTMF receiver release error
27/09/09 14:49:05 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
27/09/09 15:24:33 000004M|---/--/-/---|=3:5816=Minor failure in SIP component
27/09/09 15:29:57 000004M|001/01/0/138|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b5:bf,1198191
27/09/09 15:30:15 000004M|---/--/-/---|=3:5816=Minor failure in SIP component
27/09/09 15:40:22 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
27/09/09 15:42:47 000004M|---/--/-/---|=4:0274=DTMF receiver release error
27/09/09 15:43:18 000004M|---/--/-/---|=4:0274=DTMF receiver release error
27/09/09 15:51:02 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
27/09/09 15:55:30 000004M|---/--/-/---|=4:0274=DTMF receiver release error
27/09/09 16:02:29 000004M|---/--/-/---|=4:0274=DTMF receiver release error
27/09/09 16:14:52 000004M|002/08/0/000|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
27/09/09 16:15:22 000004M|002/08/0/000|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
27/09/09 16:19:58 000004M|---/--/-/---|=4:0274=DTMF receiver release error
27/09/09 16:28:16 000004M|001/00/0/152|=4:0389=Sig. on IP set: set demand a reset 00:0f:1f:8e:ed:94:02,C1192
27/09/09 16:33:44 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
27/09/09 16:42:21 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:b5:bf,1198191
27/09/09 16:42:22 000004M|001/01/0/138|=5:2053=Terminal 138 in service
27/09/09 17:27:06 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
27/09/09 18:20:27 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
27/09/09 18:55:00 000004M|001/00/0/008|=4:0389=Sig. on IP set: set demand a reset 00:19:b9:18:af:39:02,C1191
27/09/09 19:13:49 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
27/09/09 20:00:22 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
27/09/09 20:00:34 000004M|---/--/-/---|=2:0275=ACCOUNTING: Appli ACCOUNTING : feature incident 77 0
27/09/09 20:00:34 000004S|---/--/-/---|=2:0275=ACCOUNTING: Appli ACCOUNTING : feature incident 77 0
27/09/09 20:00:39 000004M|---/--/-/---|=2:0275=ACCOUNTING: Appli ACCOUNTING : feature incident 77 1
27/09/09 20:00:39 000004S|---/--/-/---|=2:0275=ACCOUNTING: Appli ACCOUNTING : feature incident 77 1
27/09/09 20:07:11 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
27/09/09 21:00:32 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
27/09/09 21:53:54 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
27/09/09 22:47:16 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
27/09/09 23:40:37 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
28/09/09 00:33:59 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
28/09/09 00:46:59 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
28/09/09 01:27:21 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
28/09/09 02:20:42 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
28/09/09 03:14:04 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
28/09/09 04:07:26 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
28/09/09 05:00:02 000004M|---/--/-/---|=2:0275=ACCOUNTING: Appli ACCOUNTING : feature incident 77 0
28/09/09 05:00:02 000004S|---/--/-/---|=2:0275=ACCOUNTING: Appli ACCOUNTING : feature incident 77 0
28/09/09 05:00:03 000004M|---/--/-/---|=2:0275=ACCOUNTING: Appli ACCOUNTING : feature incident 77 1
28/09/09 05:00:03 000004S|---/--/-/---|=2:0275=ACCOUNTING: Appli ACCOUNTING : feature incident 77 1
28/09/09 05:00:25 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 0 PCS domain 119
28/09/09 05:00:25 000004M|---/--/-/---|=2:0429=PCS 10.30.0.21 is activated
28/09/09 05:00:47 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
28/09/09 05:05:08 000004M|---/--/-/---|=4:0428=CS->PCS: @IP 10.30.0.21 error 1 PCS domain 119
28/09/09 05:05:08 000004M|---/--/-/---|=5:0430=PCS 10.30.0.21 is disabled
28/09/09 05:54:09 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
28/09/09 06:31:16 000004M|---/--/-/---|=3:4019=CSTA server : 1 exit
28/09/09 06:31:16 000004M|---/--/-/---|=4:4018=CSTA server : 1 connection closed
28/09/09 06:31:19 000004M|---/--/-/---|=4:4017=CSTA server : new creation 1 144.119.133.134
28/09/09 06:47:31 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
28/09/09 07:40:52 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
28/09/09 08:05:50 000004M|---/--/-/---|=3:1405=ABCA rout src 0 .1.-1
28/09/09 08:34:14 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
28/09/09 09:04:40 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
28/09/09 09:04:56 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:77:33,1198164
28/09/09 09:05:00 000004M|001/00/0/041|=5:2053=Terminal 41 in service
28/09/09 09:14:07 000004M|---/--/-/---|=4:0274=DTMF receiver release error
28/09/09 09:27:36 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
28/09/09 09:49:14 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
28/09/09 10:05:43 000004M|001/00/0/186|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:77:08,1198022
28/09/09 10:05:43 000004M|002/02/0/001|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
28/09/09 10:05:57 000004M|002/02/0/001|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
28/09/09 10:05:57 000004M|001/01/0/197|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:7d:4e,1195849
28/09/09 10:06:11 000004M|001/00/0/144|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:76:de,1197660
28/09/09 10:06:20 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:77:08,1198022
28/09/09 10:06:22 000004M|001/00/0/162|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b5:7b,1197661
28/09/09 10:06:22 000004M|001/00/0/206|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b5:6d,1198033
28/09/09 10:06:23 000004M|001/00/0/186|=5:2053=Terminal 186 in service
28/09/09 10:06:33 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:7d:4e,1195849
28/09/09 10:06:35 000004M|001/01/0/197|=5:2053=Terminal 197 in service
28/09/09 10:06:36 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
28/09/09 10:06:44 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:76:de,1197660
28/09/09 10:06:46 000004M|001/00/0/144|=5:2053=Terminal 144 in service
28/09/09 10:06:52 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:b5:6d,1198033
28/09/09 10:06:53 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:b5:7b,1197661
28/09/09 10:06:54 000004M|001/00/0/206|=5:2053=Terminal 206 in service
28/09/09 10:06:54 000004M|001/00/0/162|=5:2053=Terminal 162 in service
28/09/09 10:08:21 000004M|---/--/-/---|=4:0274=DTMF receiver release error
28/09/09 10:20:57 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
28/09/09 10:23:51 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:76:8b,1198338
28/09/09 10:23:54 000004M|001/00/0/247|=5:2053=Terminal 247 in service
28/09/09 10:27:17 000004M|001/01/0/102|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:bf:1a,1198143
28/09/09 10:28:01 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
28/09/09 10:30:52 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:bf:1a,1198143
28/09/09 10:30:53 000004M|001/01/0/102|=5:2053=Terminal 102 in service
28/09/09 10:45:37 000004M|001/00/0/247|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:76:8b,1198338
28/09/09 10:48:46 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:76:8b,1198338
28/09/09 10:48:48 000004M|001/00/0/247|=5:2053=Terminal 247 in service
28/09/09 10:50:35 000004M|002/02/0/000|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
28/09/09 10:51:05 000004M|002/02/0/000|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
28/09/09 10:55:08 000004M|001/01/0/143|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:77:2f,1198196
28/09/09 10:57:32 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:77:2f,1198196
28/09/09 10:57:35 000004M|001/01/0/143|=5:2053=Terminal 143 in service
28/09/09 10:57:42 000004M|001/01/0/120|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:76:69,1198167
28/09/09 10:58:39 000004M|001/01/0/126|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:7d:98,1198176
28/09/09 10:58:44 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:76:69,1198167
28/09/09 10:58:47 000004M|001/01/0/120|=5:2053=Terminal 120 in service
28/09/09 11:00:09 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:7d:98,1198176
28/09/09 11:00:12 000004M|001/01/0/126|=5:2053=Terminal 126 in service
28/09/09 11:01:56 000004M|001/01/0/144|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:76:d5,1198198
28/09/09 11:03:17 000004M|001/00/0/152|=4:0389=Sig. on IP set: set demand a reset 00:0f:1f:8e:ed:94:02,C1192
28/09/09 11:03:18 000004M|001/01/0/001|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:75:e1,1196151
28/09/09 11:03:18 000004M|001/00/0/224|=4:0386=Sig. on IP set: No response from de set 00:80:9f:5f:32:ca,1198489
28/09/09 11:03:18 000004M|001/00/0/246|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:7c:f9,1196111
28/09/09 11:03:18 000004M|001/01/0/190|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:75:a0,1196198
28/09/09 11:03:18 000004M|001/01/0/165|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b5:1a,1198292
28/09/09 11:03:19 000004M|002/02/0/000|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
28/09/09 11:03:24 000004M|002/02/0/000|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
28/09/09 11:03:24 000004M|001/00/0/152|=4:0389=Sig. on IP set: set demand a reset 00:0f:1f:8e:ed:94:02,C1192
28/09/09 11:03:30 000004M|002/10/-/---|=3:2047=State = 1 for Cpl 2,0 on CPU and 0 on INTB
28/09/09 11:03:30 000004M|002/10/-/---|=2:2166=CPU requires Reset CPL VPU5 (2,0) Cause 5
28/09/09 11:03:30 000004M|002/10/-/---|=3:2047=State = 1 for Cpl 2,6 on CPU and 0 on INTB
28/09/09 11:03:30 000004M|002/10/-/---|=2:2166=CPU requires Reset CPL INTIPB (2,6) Cause 5
28/09/09 11:03:30 000004M|002/00/-/---|=2:2042=Loss of a VPU5 type cpl
28/09/09 11:03:30 000004M|002/06/-/---|=2:2042=Loss of a INTIPB type cpl
28/09/09 11:03:31 000004M|002/08/0/000|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
28/09/09 11:03:31 000004M|002/02/0/001|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
28/09/09 11:03:31 000004M|002/02/0/001|=3:1307x003=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
28/09/09 11:03:31 000004M|002/02/0/000|=3:1307=MCDU in distri tab entity 1192, col Night , line 4 incorrect or missing
28/09/09 11:03:31 000004M|002/10/-/---|=3:3535=C1 incident, type 2, link 0, info1 0, info2 0, info3 0
28/09/09 11:03:31 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:76:d5,1198198
28/09/09 11:03:34 000004M|001/01/0/144|=5:2053=Terminal 144 in service
28/09/09 11:03:35 000004M|---/--/-/---|=3:1405=ABCA rout src 0 .1.-1
28/09/09 11:03:40 000004M|---/--/-/---|=0:0412=Lost set on IP domain : Domain number 0 pourcent of the set lost 1700
28/09/09 11:03:44 000004M|001/01/-/---|=4:2615=Voice Guide channel lack for VG No 102
28/09/09 11:03:45 000004M|001/01/-/---|=4:2615=Voice Guide channel lack for VG No 5
28/09/09 11:03:52 000004M|002/10/0/254|=2:0379=Inter ACT link HS: 23,(19,1),10.30.0.23,00:80:9f:81:f7:2b
28/09/09 11:03:52 000004M|002/--/-/---|=2:2043=Loss of the 2 CRYSTAL
28/09/09 11:03:52 000004M|002/02/-/---|=2:2042=Loss of a NPRAE type cpl
28/09/09 11:03:52 000004M|002/02/0/000|=4:2085=Access T2, board (2,2) : synchronization stopped
28/09/09 11:03:52 000004M|002/02/0/000|=4:2080=T2 access is synchronizing on Board (2,2)
28/09/09 11:03:52 000004M|002/02/0/001|=4:2085=Access T2, board (2,2) : synchronization stopped
28/09/09 11:03:52 000004M|002/02/0/001|=4:2080=T2 access is synchronizing on Board (2,8)
28/09/09 11:03:52 000004M|002/04/-/---|=2:2042=Loss of a Z type cpl
28/09/09 11:03:52 000004M|002/08/-/---|=2:2042=Loss of a NPRAE type cpl
28/09/09 11:03:52 000004M|002/08/0/000|=4:2085=Access T2, board (2,8) : synchronization stopped
28/09/09 11:03:52 000004M|---/--/-/---|=2:1660=Monitel: Lack of resource type 4
28/09/09 11:03:52 000004M|002/10/-/---|=2:2042=Loss of a INTIPB type cpl
28/09/09 11:03:52 000004M|002/12/-/---|=2:2042=Loss of a GPA type cpl
28/09/09 11:03:53 000004M|002/06/-/---|=4:0740=Beginning of an INT/IP downloading @:00.80.9f.81.f6.05 (binintip)
28/09/09 11:03:54 000004M|002/06/-/---|=4:0740=Beginning of an INT/IP downloading @:00.80.9f.81.f6.05 (binintip_app
28/09/09 11:03:54 000004M|002/06/-/---|=5:0741=End of downloading of an INT/IP board @:00.80.9f.81.f6.05 (binintip_app
28/09/09 11:03:55 000004M|001/00/0/180|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b3:0c,1198064
28/09/09 11:03:55 000004M|001/00/0/142|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b6:af,1198324
28/09/09 11:03:55 000004M|001/01/0/145|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:76:ae,1198199
28/09/09 11:03:55 000004M|001/01/0/021|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b2:16,1196173
28/09/09 11:03:56 000004M|001/00/0/152|=4:0386=Sig. on IP set: No response from de set 00:0f:1f:8e:ed:94:02,C1192
28/09/09 11:03:56 000004M|001/00/0/153|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b3:10,1198330
28/09/09 11:03:56 000004M|001/00/0/105|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:b5:ee,1197618
28/09/09 11:03:56 000004M|001/00/0/024|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:77:16,1198003
28/09/09 11:03:56 000004M|001/00/0/125|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:7d:21,1198050
28/09/09 11:03:56 000004M|---/--/-/---|=2:2140=Alarm : SET resources quantity critical
28/09/09 11:03:56 000004M|001/00/0/241|=4:0386=Sig. on IP set: No response from de set 00:80:9f:78:68:9e,1195863
28/09/09 11:04:09 000004M|001/00/0/152|=3:1404=ABCA Wrong MSG 0 IE 1 24 : 0
28/09/09 11:04:10 000004M|001/00/0/152|=4:0389=Sig. on IP set: set demand a reset 00:0f:1f:8e:ed:94:02,C1192
28/09/09 11:04:10 000004M|001/00/0/152|=3:1405=ABCA rout src 0 .1.727
28/09/09 11:04:14 000004M|002/06/-/---|=5:0409=The inter-ACT link over IP from (19 1) is up
28/09/09 11:04:15 000004M|002/06/-/---|=0:5857=GD/GA/INTIP/RGD: reason of reboot 5
28/09/09 11:04:15 000004M|002/12/-/---|=4:0260=Beginning of downloading bnvdsp1gpa2
28/09/09 11:04:15 000004M|002/04/-/---|=4:0260=Beginning of downloading bnvdsp0z32
28/09/09 11:04:17 000004M|---/--/-/---|=0:0412=Lost set on IP domain : Domain number 0 pourcent of the set lost 12300
28/09/09 11:04:18 000004M|---/--/-/---|=0:0412=Lost set on IP domain : Domain number 119 pourcent of the set lost 6
28/09/09 11:04:21 000004M|002/04/-/---|=5:0261=End of downloading bnvdsp0z32
28/09/09 11:04:21 000004M|002/04/-/---|=4:3501=Clock loss
28/09/09 11:04:24 000004M|---/--/-/---|=3:1405=ABCA rout src 0 .1.-1
28/09/09 11:04:36 000004M|002/12/-/---|=5:0261=End of downloading bnvdsp1gpa2
28/09/09 11:04:36 000004M|002/12/-/---|=4:0260=Beginning of downloading bnvdsp2gpa2
28/09/09 11:04:43 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:5f:32:ca,1198489
28/09/09 11:04:43 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:7c:f9,1196111
28/09/09 11:04:44 000004M|001/00/0/224|=5:2053=Terminal 224 in service
28/09/09 11:04:45 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:b5:1a,1198292
28/09/09 11:04:45 000004M|002/06/-/---|=5:2019=INTIPB coupler commissioning
28/09/09 11:04:45 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:75:a0,1196198
28/09/09 11:04:45 000004M|001/00/0/246|=5:2053=Terminal 246 in service
28/09/09 11:04:46 000004M|001/01/0/165|=5:2053=Terminal 165 in service
28/09/09 11:04:48 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:75:e1,1196151
28/09/09 11:04:48 000004M|001/01/0/190|=5:2053=Terminal 190 in service
28/09/09 11:04:50 000004M|001/01/0/001|=5:2053=Terminal 1 in service
28/09/09 11:04:58 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:b6:af,1198324
28/09/09 11:04:58 000004M|002/12/-/---|=5:0261=End of downloading bnvdsp2gpa2
28/09/09 11:04:58 000004M|002/12/-/---|=4:3501=Clock loss
28/09/09 11:04:58 000004M|001/00/0/142|=5:2053=Terminal 142 in service
28/09/09 11:04:59 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:b3:0c,1198064
28/09/09 11:05:00 000004M|001/00/0/180|=5:2053=Terminal 180 in service
28/09/09 11:05:01 000004M|002/10/-/---|=4:0740=Beginning of an INT/IP downloading @:00.80.9f.81.f7.2b (binintip)
28/09/09 11:05:01 000004M|002/10/-/---|=4:0740=Beginning of an INT/IP downloading @:00.80.9f.81.f7.2b (binintip_app
28/09/09 11:05:01 000004M|002/10/-/---|=5:0741=End of downloading of an INT/IP board @:00.80.9f.81.f7.2b (binintip_app
28/09/09 11:05:19 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:b5:ee,1197618
28/09/09 11:05:19 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:78:68:9e,1195863
28/09/09 11:05:19 000004M|001/00/0/105|=5:2053=Terminal 105 in service
28/09/09 11:05:20 000004M|001/00/0/241|=5:2053=Terminal 241 in service
28/09/09 11:05:21 000004M|---/--/-/---|=5:2141=SET resources quantity normal
28/09/09 11:05:21 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:b3:10,1198330
28/09/09 11:05:22 000004M|001/00/0/153|=5:2053=Terminal 153 in service
28/09/09 11:05:23 000004M|002/04/-/---|=5:2019=Z coupler commissioning
28/09/09 11:05:27 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:b2:16,1196173
28/09/09 11:05:28 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:77:16,1198003
28/09/09 11:05:28 000004M|001/01/0/021|=5:2053=Terminal 21 in service
28/09/09 11:05:29 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:76:ae,1198199
28/09/09 11:05:32 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:80:7d:21,1198050
28/09/09 11:05:32 000004M|001/01/0/145|=5:2053=Terminal 145 in service
28/09/09 11:05:33 000004M|001/00/0/024|=5:2053=Terminal 24 in service
28/09/09 11:05:33 000004M|001/01/0/125|=4:0386=Sig. on IP set: No response from de set 00:80:9f:80:7d:29,1198175
28/09/09 11:05:34 000004M|001/00/0/125|=5:2053=Terminal 125 in service
28/09/09 11:05:35 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
28/09/09 11:05:40 000004M|002/12/-/---|=5:2019=GPA coupler commissioning
28/09/09 11:05:45 000004M|002/02/0/000|=4:2113=T2 lapD not established still trying
28/09/09 11:05:45 000004M|002/02/0/001|=4:2113=T2 lapD not established still trying
28/09/09 11:05:45 000004M|002/08/0/000|=4:2113=T2 lapD not established still trying
28/09/09 11:05:50 000004M|002/02/0/000|=4:2080=T2 access is synchronizing on Board (2,2)
28/09/09 11:05:53 000004M|002/10/-/---|=0:5857=GD/GA/INTIP/RGD: reason of reboot 5
28/09/09 11:05:53 000004M|002/10/-/---|=5:0409=The inter-ACT link over IP from (19 1) is up
28/09/09 11:06:00 000004M|002/02/0/001|=5:2102=T2 access back to normal
28/09/09 11:06:00 000004M|002/02/0/001|=4:2113=T2 lapD not established still trying
28/09/09 11:06:00 000004M|002/02/0/001|=5:0311=T2 Dlap Established
28/09/09 11:06:00 000004M|002/08/0/000|=5:2102=T2 access back to normal
28/09/09 11:06:00 000004M|002/08/0/000|=4:2113=T2 lapD not established still trying
28/09/09 11:06:00 000004M|002/08/0/000|=5:0311=T2 Dlap Established
28/09/09 11:06:03 000004M|002/00/-/---|=5:2019=VPU5 coupler commissioning
28/09/09 11:06:03 000004M|---/--/-/---|=2:0908=VOICE MAIL. Impossible starting link
28/09/09 11:06:15 000004M|002/02/-/---|=5:2019=NPRAE coupler commissioning
28/09/09 11:06:15 000004M|002/08/-/---|=5:2019=NPRAE coupler commissioning
28/09/09 11:06:23 000004M|002/10/-/---|=5:2019=INTIPB coupler commissioning
28/09/09 11:06:46 000004M|---/--/-/---|=5:0903=VOCAL FACILITY starting link
28/09/09 11:06:59 000004M|000/00/0/000|=4:0426=IPTOUCH terminal reset 1,00:80:9f:80:7d:29,1198175
28/09/09 11:07:02 000004M|001/01/0/125|=5:2053=Terminal 125 in service
28/09/09 11:14:19 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
28/09/09 11:18:44 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
28/09/09 11:20:11 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
28/09/09 11:22:29 000004M|001/00/0/018|=2:0435=Security alert: ARP spoofing detected by 00:80:9f:80:b2:88
28/09/09 11:36:34 000004S|---/--/-/---|=3:2051=Std By CPU. wrong message 46 on neqt 760 info -1
28/09/09 11:58:52 000004M|---/--/-/---|=3:1125=external alarm : "mtcl login"
28/09/09 12:07:41 000004M|---/--/-/---|=3:2873=PH:Update seq synchro:Src=3 #(exp=8 rcv=0) waitDelay=400 s
IP phone reboot problem
Re: IP phone reboot problem
Has the problem suddenly started ore has it come after an upgrade ore modification?
Try to do an upgrade to new patch. There seems also been a problem on 19 and domains.
Have you the right resources ore have the domains been modified?
try to change Reset For Update Authorized + no
Reset For Update Authorized <<----- what does it mean?
- tot3nkopf
mgr-->Users-->TSC/IP user-->Reset for update authorized yes/no
hi all
after i configured this parameter i still gett this issue of reboot
any thing als to do?
thank you
=4:0425=PRS related activity : Loss of link
23/12/12 06:33:03 000001M|---/--/-/---|=4:0425=PRS related activity : Link established
23/12/12 06:33:26 000001M|---/--/-/---|=4:0425=PRS related activity : Loss of link
23/12/12 06:33:28 000001M|---/--/-/---|=4:0425=PRS related activity : Link established
23/12/12 08:34:53 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 08:35:23 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 10:00:20 000001M|---/--/-/---|=0:1721=Phone exc 5, PC 0x08b92472 neqt 697
23/12/12 10:31:09 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 10:31:39 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 10:41:36 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 10:42:06 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 10:53:07 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 10:53:37 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 11:10:39 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
23/12/12 11:35:22 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 11:35:52 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 11:58:13 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 11:58:43 000001M|002/06/0/000|=3:1307x003=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 12:07:48 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 12:08:18 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 12:15:30 000001M|002/07/0/000|=3:1307=MCDU in distri tab entity 20, col Day , line 4 incorrect or missing
23/12/12 12:16:00 000001M|002/07/0/000|=3:1307=MCDU in distri tab entity 20, col Day , line 4 incorrect or missing
23/12/12 12:16:30 000001M|002/07/0/000|=3:1307x002=MCDU in distri tab entity 20, col Day , line 4 incorrect or missing
23/12/12 12:17:08 000001M|002/07/0/000|=3:1307=MCDU in distri tab entity 20, col Day , line 4 incorrect or missing
23/12/12 12:17:38 000001M|002/07/0/000|=3:1307=MCDU in distri tab entity 20, col Day , line 4 incorrect or missing
23/12/12 12:23:16 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 12:23:46 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 12:32:38 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 12:33:08 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 12:38:30 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 12:39:00 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 12:40:13 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 12:40:43 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 12:41:13 000001M|002/06/0/000|=3:1307x002=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 12:42:24 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 12:42:54 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 12:48:25 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 12:48:55 000001M|002/06/0/000|=3:1307x003=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 12:50:17 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 12:50:47 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 12:54:25 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 12:54:55 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 13:38:41 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 13:39:11 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 13:41:19 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 13:41:49 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 13:55:07 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 13:55:37 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 13:58:12 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 13:58:42 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 14:19:12 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 14:19:42 000001M|002/06/0/000|=3:1307x003=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 14:46:56 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 14:47:26 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 14:47:55 000001M|002/06/0/000|=3:1307x002=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 15:00:08 000001M|---/--/-/---|=4:0425=PRS related activity : Loss of link
23/12/12 15:00:08 000001M|---/--/-/---|=4:0425=PRS related activity : Link established
23/12/12 15:00:15 000001M|001/00/0/055|=4:0386=Sig. on IP set: No response from de set 00:80:9f:97:b1:cc,4047
23/12/12 15:00:15 000001M|001/00/0/159|=4:0386=Sig. on IP set: No response from de set 00:80:9f:97:ae:15,5532
23/12/12 15:00:15 000001M|001/00/0/158|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a9:fb:57,5527
23/12/12 15:00:15 000001M|001/00/0/135|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a9:fb:33,4042
23/12/12 15:00:15 000001M|001/00/0/057|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a9:fb:12,5524
23/12/12 15:00:15 000001M|001/00/0/149|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a6:46:58,4103
23/12/12 15:00:15 000001M|001/00/0/080|=4:0386=Sig. on IP set: No response from de set 00:80:9f:97:b1:a3,4074
23/12/12 15:00:15 000001M|001/00/0/042|=4:0386=Sig. on IP set: No response from de set 00:80:9f:aa:26:20,4040
23/12/12 15:00:16 000001M|001/00/0/122|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a8:dc:c9,5573
23/12/12 15:00:16 000001M|001/00/0/110|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a9:fb:0a,5545
23/12/12 15:00:16 000001M|001/00/0/108|=4:0386=Sig. on IP set: No response from de set 00:80:9f:aa:25:fc,5540
23/12/12 15:00:16 000001M|001/00/0/105|=4:0386=Sig. on IP set: No response from de set 00:80:9f:97:af:16,5536
23/12/12 15:00:16 000001M|001/00/0/102|=4:0386=Sig. on IP set: No response from de set 00:80:9f:97:b6:24,5531
23/12/12 15:00:16 000001M|001/00/0/101|=4:0386=Sig. on IP set: No response from de set 00:80:9f:aa:26:0f,5530
23/12/12 15:00:16 000001M|001/00/0/140|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a8:dc:c1,5526
23/12/12 15:00:16 000001M|001/00/0/095|=4:0386=Sig. on IP set: No response from de set 00:80:9f:97:bf:e8,5521
23/12/12 15:00:16 000001M|001/00/0/090|=4:0386=Sig. on IP set: No response from de set 00:80:9f:97:b1:b6,5514
23/12/12 15:00:16 000001M|001/00/0/084|=4:0386=Sig. on IP set: No response from de set 00:80:9f:aa:25:6d,5501
23/12/12 15:00:16 000001M|001/00/0/070|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a9:fb:29,5538
23/12/12 15:00:16 000001M|001/00/0/123|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a9:fb:43,4147
23/12/12 15:00:16 000001M|001/00/0/056|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a9:fb:a6,4085
23/12/12 15:00:16 000001M|001/00/0/146|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a9:66:83,4069
23/12/12 15:00:16 000001M|001/00/0/069|=4:0386=Sig. on IP set: No response from de set 00:80:9f:b2:7d:1c,4066
23/12/12 15:00:16 000001M|001/00/0/072|=4:0386=Sig. on IP set: No response from de set 00:80:9f:aa:26:03,4063
23/12/12 15:00:16 000001M|001/00/0/043|=4:0386=Sig. on IP set: No response from de set 00:80:9f:b2:7a:9a,4062
23/12/12 15:00:16 000001M|001/00/0/041|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a9:fb:4a,4059
23/12/12 15:00:16 000001M|001/00/0/036|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a9:fb:4b,4051
23/12/12 15:00:16 000001M|001/00/0/035|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a6:10:5a,4050
23/12/12 15:00:16 000001M|001/00/0/023|=4:0386=Sig. on IP set: No response from de set 00:80:9f:97:b1:a7,4024
23/12/12 15:00:16 000001M|001/00/0/018|=4:0386=Sig. on IP set: No response from de set 00:80:9f:97:b1:e7,4016
23/12/12 15:00:35 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 15:01:05 000001M|002/06/0/000|=3:1307x003=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 15:01:18 000001M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:b2:7a:9a,4062
23/12/12 15:01:19 000001M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:97:b1:cc,4047
23/12/12 15:01:21 000001M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:b2:7d:1c,4066
23/12/12 15:01:21 000001M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:aa:25:fc,5540
23/12/12 15:01:21 000001M|001/00/0/055|=5:2053=Terminal 55 in service
23/12/12 15:01:22 000001M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:a8:dc:c9,5573
23/12/12 15:01:22 000001M|001/00/0/122|=5:2053=Terminal 122 in service
23/12/12 15:01:23 000001M|001/00/0/069|=5:2053=Terminal 69 in service
23/12/12 15:01:23 000001M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:aa:26:20,4040
23/12/12 15:01:23 000001M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:aa:26:0f,5530
23/12/12 15:01:23 000001M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:a9:66:83,4069
23/12/12 15:01:24 000001M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:97:ae:15,5532
23/12/12 15:01:24 000001M|001/00/0/146|=5:2053=Terminal 146 in service
23/12/12 15:01:24 000001M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:97:b1:a7,4024
23/12/12 15:01:24 000001M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:aa:26:03,4063
23/12/12 15:01:24 000001M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:97:b1:b6,5514
23/12/12 15:01:25 000001M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:97:bf:e8,5521
23/12/12 15:01:25 000001M|001/00/0/101|=5:2053=Terminal 101 in service
23/12/12 15:01:25 000001M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:a9:fb:4a,4059
23/12/12 15:01:25 000001M|001/00/0/159|=5:2053=Terminal 159 in service
23/12/12 15:01:25 000001M|001/00/0/041|=5:2053=Terminal 41 in service
23/12/12 15:01:25 000001M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:a9:fb:0a,5545
23/12/12 15:01:25 000001M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:a9:fb:43,4147
23/12/12 15:01:25 000001M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:a6:46:58,4103
23/12/12 15:01:25 000001M|001/00/0/110|=5:2053=Terminal 110 in service
23/12/12 15:01:25 000001M|001/00/0/123|=5:2053=Terminal 123 in service
23/12/12 15:01:26 000001M|001/00/0/149|=5:2053=Terminal 149 in service
23/12/12 15:01:26 000001M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:a8:dc:c1,5526
23/12/12 15:01:26 000001M|001/00/0/140|=5:2053=Terminal 140 in service
23/12/12 15:01:26 000001M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:97:af:16,5536
23/12/12 15:01:26 000001M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:97:b1:a3,4074
23/12/12 15:01:26 000001M|001/00/0/023|=5:2053=Terminal 23 in service
23/12/12 15:01:27 000001M|001/00/0/043|=5:2053=Terminal 43 in service
23/12/12 15:01:27 000001M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:a9:fb:57,5527
23/12/12 15:01:27 000001M|001/00/0/158|=5:2053=Terminal 158 in service
23/12/12 15:01:27 000001M|001/00/0/090|=5:2053=Terminal 90 in service
23/12/12 15:01:27 000001M|001/00/0/095|=5:2053=Terminal 95 in service
23/12/12 15:01:27 000001M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:a9:fb:12,5524
23/12/12 15:01:27 000001M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:a9:fb:4b,4051
23/12/12 15:01:27 000001M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:a9:fb:a6,4085
23/12/12 15:01:27 000001M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:a9:fb:33,4042
23/12/12 15:01:28 000001M|001/00/0/080|=5:2053=Terminal 80 in service
23/12/12 15:01:28 000001M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:aa:25:6d,5501
23/12/12 15:01:28 000001M|001/00/0/056|=5:2053=Terminal 56 in service
23/12/12 15:01:28 000001M|001/00/0/057|=5:2053=Terminal 57 in service
23/12/12 15:01:28 000001M|001/00/0/135|=5:2053=Terminal 135 in service
23/12/12 15:01:28 000001M|001/00/0/036|=5:2053=Terminal 36 in service
23/12/12 15:01:28 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 15:01:28 000001M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:97:b6:24,5531
23/12/12 15:01:28 000001M|001/00/0/084|=5:2053=Terminal 84 in service
23/12/12 15:01:29 000001M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:97:b1:e7,4016
23/12/12 15:01:29 000001M|001/00/0/105|=5:2053=Terminal 105 in service
23/12/12 15:01:29 000001M|001/00/0/108|=5:2053=Terminal 108 in service
23/12/12 15:01:29 000001M|001/00/0/102|=5:2053=Terminal 102 in service
23/12/12 15:01:30 000001M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:a6:10:5a,4050
23/12/12 15:01:31 000001M|001/00/0/018|=5:2053=Terminal 18 in service
23/12/12 15:01:32 000001M|001/00/0/072|=5:2053=Terminal 72 in service
23/12/12 15:01:32 000001M|001/00/0/035|=5:2053=Terminal 35 in service
23/12/12 15:01:32 000001M|001/00/0/042|=5:2053=Terminal 42 in service
23/12/12 15:01:40 000001M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:a9:fb:29,5538
23/12/12 15:01:40 000001M|001/00/0/070|=5:2053=Terminal 70 in service
23/12/12 15:01:48 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 15:02:18 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 15:14:48 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
23/12/12 15:15:18 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
24/12/12 01:33:00 000001M|---/--/-/---|=4:0425=PRS related activity : Loss of link
24/12/12 01:33:05 000001M|---/--/-/---|=4:0425=PRS related activity : Link established
24/12/12 01:33:13 000001M|---/--/-/---|=4:0425=PRS related activity : Loss of link
24/12/12 01:33:18 000001M|---/--/-/---|=4:0425=PRS related activity : Link established
24/12/12 02:01:19 000001M|---/--/-/---|=4:0425=PRS related activity : Loss of link
24/12/12 02:01:29 000001M|---/--/-/---|=4:0425=PRS related activity : Link established
24/12/12 02:01:37 000001M|---/--/-/---|=4:0425=PRS related activity : Loss of link
24/12/12 02:01:39 000001M|---/--/-/---|=4:0425=PRS related activity : Link established
24/12/12 08:22:33 000001M|001/00/0/087|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a6:10:36,5510
24/12/12 08:22:57 000001M|000/00/0/000|=4:0426=IPTOUCH terminal reset 32,00:80:9f:a6:10:36,5510
24/12/12 08:23:00 000001M|001/00/0/087|=5:2053=Terminal 87 in service
24/12/12 08:27:09 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
24/12/12 08:27:39 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
24/12/12 08:58:55 000001M|001/00/0/087|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a6:10:36,5510
24/12/12 08:59:19 000001M|000/00/0/000|=4:0426=IPTOUCH terminal reset 32,00:80:9f:a6:10:36,5510
24/12/12 08:59:22 000001M|001/00/0/087|=5:2053=Terminal 87 in service
24/12/12 09:17:33 000001M|001/00/0/087|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a6:10:36,5510
24/12/12 09:17:57 000001M|000/00/0/000|=4:0426=IPTOUCH terminal reset 32,00:80:9f:a6:10:36,5510
24/12/12 09:17:59 000001M|001/00/0/087|=5:2053=Terminal 87 in service
24/12/12 09:22:15 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
24/12/12 09:22:45 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
24/12/12 09:39:44 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
24/12/12 09:40:14 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
24/12/12 09:52:16 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
24/12/12 09:52:46 000001M|002/06/0/000|=3:1307x003=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
24/12/12 10:27:48 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
24/12/12 10:28:18 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
24/12/12 10:49:18 000001M|---/--/-/---|=0:1721=Phone exc 5, PC 0x08b92472 neqt 693
24/12/12 10:49:48 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
24/12/12 10:49:48 000001M|002/07/0/000|=3:1307=MCDU in distri tab entity 20, col Day , line 4 incorrect or missing
24/12/12 10:50:18 000001M|002/07/0/000|=3:1307=MCDU in distri tab entity 20, col Day , line 4 incorrect or missing
24/12/12 11:00:13 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
24/12/12 11:00:43 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
24/12/12 11:18:33 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
24/12/12 11:27:47 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
24/12/12 11:27:47 000001M|002/06/0/000|=3:1307x002=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
24/12/12 11:27:47 000001M|---/--/-/---|=0:1721=Phone exc 5, PC 0x08b92472 neqt 612
24/12/12 11:54:34 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
24/12/12 11:55:04 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
24/12/12 11:58:18 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
24/12/12 11:58:48 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
24/12/12 12:02:52 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
24/12/12 12:03:22 000001M|002/06/0/000|=3:1307x003=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
24/12/12 12:17:37 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
24/12/12 12:18:07 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
24/12/12 12:38:37 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
24/12/12 12:39:07 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
24/12/12 12:55:24 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
24/12/12 12:55:54 000001M|002/06/0/000|=3:1307x002=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
24/12/12 12:57:03 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
24/12/12 12:57:33 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
24/12/12 12:59:37 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
24/12/12 13:00:07 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
24/12/12 14:44:48 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
24/12/12 14:45:18 000001M|002/06/0/000|=3:1307=MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
24/12/12 14:54:54 000001M|018/01/-/---|=4:5400=4645 Software Error: Error Code 0x 0. 0 Module 0x 0. 0 Line 0x 0. 0
24/12/12 14:54:54 000001M|018/01/-/---|=4:5402=4645 Error Data: 0x0016 0x0000 0x0003 0x0000 0x0000
24/12/12 14:54:54 000001M|018/01/-/---|=4:5400=4645 Software Error: Error Code 0x 0.2e Module 0x 0. 0 Line 0x 0.13
24/12/12 14:54:54 000001M|018/01/-/---|=4:5400=4645 Software Error: Error Code 0x 0.1e Module 0x 0. 0 Line 0x 0.21
24/12/12 14:54:54 000001M|018/01/-/---|=4:5402=4645 Error Data: 0x0069 0x0000 0x44a0 0x0000 0x0089
24/12/12 14:56:52 000001M|018/01/0/009|=3:1404=ABCA Wrong MSG 0 IE 3 12 : 0
24/12/12 14:57:42 000001M|018/01/-/---|=4:5400=4645 Software Error: Error Code 0x 0. 0 Module 0x 0. 0 Line 0x 0. 0
24/12/12 14:57:42 000001M|018/01/-/---|=4:5402=4645 Error Data: 0x0016 0x0000 0x0003 0x0000 0x0000
24/12/12 14:57:42 000001M|018/01/-/---|=4:5400=4645 Software Error: Error Code 0x 0.2e Module 0x 0. 0 Line 0x 0.13
24/12/12 14:57:42 000001M|018/01/-/---|=4:5400=4645 Software Error: Error Code 0x 0.1e Module 0x 0. 0 Line 0x 0.21
24/12/12 14:57:42 000001M|018/01/-/---|=4:5402=4645 Error Data: 0x0070 0x0000 0x4250 0x0000 0x008d
24/12/12 14:59:40 000001M|018/01/0/013|=3:1404=ABCA Wrong MSG 0 IE 3 16 : 0
24/12/12 15:00:05 000001M|---/--/-/---|=4:0425=PRS related activity : Loss of link
24/12/12 15:00:05 000001M|---/--/-/---|=4:0425=PRS related activity : Link established
24/12/12 15:00:09 000001M|002/00/0/254|=2:0379=Inter ACT link HS: 23,(19,1),192.168.71.10,00:80:9f:8d:a7:08
24/12/12 15:00:09 000001M|002/--/-/---|=2:2043=Loss of the 2 CRYSTAL
24/12/12 15:00:09 000001M|002/00/-/---|=2:2042=Loss of a GD/GD3 type cpl
24/12/12 15:00:10 000001M|002/01/-/---|=2:2042=Loss of a GA/GA3 type cpl
24/12/12 15:00:10 000001M|002/03/-/---|=2:2042=Loss of a GA/GA3 type cpl
24/12/12 15:00:10 000001M|002/04/-/---|=2:2042=Loss of a Z type cpl
24/12/12 15:00:10 000001M|002/05/-/---|=2:2042=Loss of a Z type cpl
24/12/12 15:00:10 000001M|002/06/-/---|=2:2042=Loss of a PRA type cpl
24/12/12 15:00:10 000001M|002/06/0/000|=4:2085=Access T2, board (2,6) : synchronization stopped
24/12/12 15:00:10 000001M|002/06/0/000|=4:2080=T2 access is synchronizing on Board (2,7)
24/12/12 15:00:10 000001M|002/07/-/---|=2:2042=Loss of a PRA type cpl
24/12/12 15:00:10 000001M|002/07/0/000|=4:2085=Access T2, board (2,7) : synchronization stopped
24/12/12 15:00:10 000001M|002/09/-/---|=3:2490=Loss of a virtual coupler GPA (2,9) of the associated coupler GA/GA3 (2,1)
24/12/12 15:00:10 000001M|002/10/-/---|=3:2490=Loss of a virtual coupler GPA (2,10) of the associated coupler GA/GA3 (2,3)
24/12/12 15:00:10 000001M|002/27/-/---|=3:2490=Loss of a virtual coupler GPA (2,27) of the associated coupler GD/GD3 (2,0)
24/12/12 15:00:12 000001M|001/00/0/096|=4:0386=Sig. on IP set: No response from de set 00:80:9f:97:b1:bb,5522
24/12/12 15:00:12 000001M|001/00/0/069|=4:0386=Sig. on IP set: No response from de set 00:80:9f:b2:7d:1c,4066
24/12/12 15:00:12 000001M|001/00/0/044|=4:0386=Sig. on IP set: No response from de set 00:80:9f:b2:7a:b3,4017
24/12/12 15:00:12 000001M|001/00/0/090|=4:0386=Sig. on IP set: No response from de set 00:80:9f:97:b1:b6,5514
24/12/12 15:00:12 000001M|001/00/0/047|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a9:fb:25,4123
24/12/12 15:00:12 000001M|001/00/0/052|=4:0386=Sig. on IP set: No response from de set 00:80:9f:aa:26:23,4081
24/12/12 15:00:12 000001M|001/00/0/048|=4:0386=Sig. on IP set: No response from de set 00:80:9f:b2:7a:a0,4056
24/12/12 15:00:12 000001M|001/00/0/147|=4:0386=Sig. on IP set: No response from de set 00:80:9f:97:b1:c1,4030
24/12/12 15:00:12 000001M|001/00/0/042|=4:0386=Sig. on IP set: No response from de set 00:80:9f:aa:26:20,4040
24/12/12 15:00:15 000001M|001/00/0/081|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a9:66:66,4003
24/12/12 15:00:15 000001M|001/00/0/011|=4:0386=Sig. on IP set: No response from de set 00:80:9f:97:b1:bf,4004
24/12/12 15:00:15 000001M|001/00/0/012|=4:0386=Sig. on IP set: No response from de set 00:80:9f:97:b1:8f,4005
24/12/12 15:00:15 000001M|001/00/0/150|=4:0386=Sig. on IP set: No response from de set 00:80:9f:97:b1:a8,4013
24/12/12 15:00:15 000001M|001/00/0/017|=4:0386=Sig. on IP set: No response from de set 00:80:9f:97:b1:ff,4015
24/12/12 15:00:15 000001M|001/00/0/018|=4:0386=Sig. on IP set: No response from de set 00:80:9f:97:b1:e7,4016
24/12/12 15:00:15 000001M|001/00/0/019|=4:0386=Sig. on IP set: No response from de set 00:80:9f:b2:7a:9e,4018
24/12/12 15:00:15 000001M|001/00/0/144|=4:0386=Sig. on IP set: No response from de set 00:80:9f:97:bf:f0,4020
24/12/12 15:00:15 000001M|001/00/0/022|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a9:66:6a,4022
24/12/12 15:00:15 000001M|001/00/0/024|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a9:fa:fb,4025
24/12/12 15:00:15 000001M|001/00/0/026|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a9:fb:3f,4029
24/12/12 15:00:15 000001M|001/00/0/028|=4:0386=Sig. on IP set: No response from de set 00:80:9f:97:b1:a2,4034
24/12/12 15:00:15 000001M|001/00/0/031|=4:0386=Sig. on IP set: No response from de set 00:80:9f:b2:7a:93,4043
24/12/12 15:00:15 000001M|001/00/0/032|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a9:fb:18,4046
24/12/12 15:00:15 000001M|001/00/0/033|=4:0386=Sig. on IP set: No response from de set 00:80:9f:97:b1:af,4048
24/12/12 15:00:15 000001M|001/00/0/035|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a6:10:5a,4050
24/12/12 15:00:15 000001M|001/00/0/036|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a9:fb:4b,4051
24/12/12 15:00:15 000001M|001/00/0/037|=4:0386=Sig. on IP set: No response from de set 00:80:9f:97:bf:fa,4052
24/12/12 15:00:15 000001M|001/00/0/063|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a9:fb:36,4055
24/12/12 15:00:15 000001M|001/00/0/041|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a9:fb:4a,4059
24/12/12 15:00:15 000001M|001/00/0/072|=4:0386=Sig. on IP set: No response from de set 00:80:9f:aa:26:03,4063
24/12/12 15:00:15 000001M|001/00/0/146|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a9:66:83,4069
24/12/12 15:00:15 000001M|001/00/0/049|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a9:fb:1d,4072
24/12/12 15:00:15 000001M|001/00/0/039|=4:0386=Sig. on IP set: No response from de set 00:80:9f:b2:7d:14,4073
24/12/12 15:00:15 000001M|001/00/0/046|=4:0386=Sig. on IP set: No response from de set 00:80:9f:97:b1:85,4075
24/12/12 15:00:15 000001M|001/00/0/051|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a7:bb:c7,4079
24/12/12 15:00:15 000001M|001/00/0/038|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a6:46:46,4083
24/12/12 15:00:15 000001M|001/00/0/154|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a6:46:6b,4084
24/12/12 15:00:15 000001M|001/00/0/056|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a9:fb:a6,4085
24/12/12 15:00:15 000001M|001/00/0/061|=4:0386=Sig. on IP set: No response from de set 00:80:9f:97:bf:da,4107
24/12/12 15:00:15 000001M|001/00/0/029|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a8:dc:b2,4118
24/12/12 15:00:15 000001M|001/00/0/164|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a9:fb:56,4122
24/12/12 15:00:15 000001M|001/00/0/165|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a9:fb:2f,4124
24/12/12 15:00:15 000001M|001/00/0/066|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a9:66:7f,4135
24/12/12 15:00:15 000001M|001/00/0/123|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a9:fb:43,4147
24/12/12 15:00:15 000001M|001/00/0/070|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a9:fb:29,5538
24/12/12 15:00:15 000001M|001/00/0/054|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a9:66:7e,5512
24/12/12 15:00:15 000001M|001/00/0/089|=4:0386=Sig. on IP set: No response from de set 00:80:9f:aa:26:22,5513
24/12/12 15:00:15 000001M|001/00/0/091|=4:0386=Sig. on IP set: No response from de set 00:80:9f:aa:26:27,5515
24/12/12 15:00:15 000001M|001/00/0/093|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a6:46:48,5517
24/12/12 15:00:15 000001M|001/00/0/095|=4:0386=Sig. on IP set: No response from de set 00:80:9f:97:bf:e8,5521
24/12/12 15:00:15 000001M|001/00/0/097|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a7:bb:9a,5523
24/12/12 15:00:15 000001M|001/00/0/098|=4:0386=Sig. on IP set: No response from de set 00:80:9f:97:bf:fc,5525
24/12/12 15:00:15 000001M|001/00/0/140|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a8:dc:c1,5526
24/12/12 15:00:15 000001M|001/00/0/101|=4:0386=Sig. on IP set: No response from de set 00:80:9f:aa:26:0f,5530
24/12/12 15:00:15 000001M|001/00/0/102|=4:0386=Sig. on IP set: No response from de set 00:80:9f:97:b6:24,5531
24/12/12 15:00:15 000001M|001/00/0/148|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a9:66:80,5533
24/12/12 15:00:15 000001M|001/00/0/103|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a9:fb:3d,5534
24/12/12 15:00:15 000001M|001/00/0/105|=4:0386=Sig. on IP set: No response from de set 00:80:9f:97:af:16,5536
24/12/12 15:00:15 000001M|001/00/0/106|=4:0386=Sig. on IP set: No response from de set 00:80:9f:a9:fb:4e,5537
24/12/12 15:00:15 000001M|--WARNING---| INCIDENTS FLOW HAS BEEN REDIRECTED TO THE OUTFALL QUEUE
24/12/12 15:00:23 000001M|---/--/-/---|=4:0425=PRS related activity : Loss of link
24/12/12 15:00:53 000001M|---/--/-/---|=4:0425=PRS related activity : Link established
24/12/12 15:01:01 000001M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:aa:26:20,4040
thank you
How did you manage to solve your problem? It be great if a solution was posted if resolved and the thread closed. Seems like a network problem to me.
SWINSTU
ACSE OXE R12.1
ACSE 8770 R3.2(4760 R5.x)
ACSE OT R2.3 IP/SIP and UC&C
ACSE OXE R12.1
- frank
GembuL wrote:Reset For Update Authorized <<----- what does it mean?
Authorize (true) or prohibit (false) the reset of the IP terminal by the call server to update its binary files.
This parameter can be used to keep a set of specific binary files on an IP terminal.
it looks like you have lot of IP phones not 4 of them ..
and you have network issues.
check with continuous ping to one of the IPphone's IP address, to confirm
./regards
fegy
./regards
fegy
