Single login in guest services
Locked
burleydad
Post by burleydad »
Hello all. I've scoured the user guide for 3.1 and can find no answer on how to keep multiple people from using the same guest login. Anyone have any suggestions?
Donnobo_DUP
Re: Single login in guest services
Post by Donnobo_DUP »
Hey,
i know the problem of the internal Database of OAW. Ive asked an onsite-technician from ALU about this, and got the answer that this is not a failure. But I dont got an answer if this will be changed. I think it is for creating usualy logins like "guestaccount" for a waiting room by example. Regards
Locked
Return to “OmniAccess WLAN Switching Systems”
