AP61 - Factory Default
Locked
tincho.rn
Post by tincho.rn »
Hi. Is it possible to reset the AP to factory default with the Ethernet-to-Serial cable?. Thanks in advance. Regards
ACSE R11
OT R2.0
annabelle
Re: AP61 - Factory Default
Post by annabelle »
Yes it's possible
First check that soe (serial over ethernet) is activated in your controller.
When your AP is connected to the APC throught your cable, you will see the autoboot sequence. Follow this sequence :
apboot > purge
apboot > save
Erasing ...
Programming ...
Verifying ...
apboot > boot
tincho.rn
Post by tincho.rn »
Thanks for your help. Regards.
ACSE R11
OT R2.0
nperalta
Post by nperalta »
Hi , I have 70 ap (ap60,61) provisioned and working. but i have a Ap where the controller no see the ap o the ap fails now i need factory default the AP to verify the ap is good.
if I still the steps. lost the others ap configured ??
apboot> purge
apboot> save
Erasing....
Programming...
Verifying....
apboot>boot
help (I'm sorry the wording of chile)
bye
Locked
Return to “OmniAccess Wireless Access Points 60/61/70”
