Have the solution for auto answer the external call
andenm
Post by andenm »
hello
Did anyone had try to configration the solution for set can auto answer the external call,
Just used the headset funtion.
thanks for reply.
Krusty65
Re: Have the solution for auto answer the external call
Post by Krusty65 »
What Set type? If it is a 4010 then this is a bug in the firmware for the 4010 which is a cut down from the 4020.
The problem with the auto headset in the 4010 is that the only way to switch of AA is to switch off the headset mode.
mopo
Post by mopo »
I have a 4019 which is auto answering when headset mode is enabled is this related?
I haven't found where or how to turn this off.
murraya
Post by murraya »
Hi, check the headset key config and see if interphony is set to yes. set to no to stop auto answer.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
This feature is enabled just from R7.1 (latest).
Return to “MAIN”
