6560 cirrus connection
selectt
Post by selectt »
Hi i have 38 switches connected to cloud cirrus for management with no issues.
Today i have tried to add 2 new switches, simply attaching switch straight from box to vlan to configure to cirrus.
The switch os6350 is recognised by cirrus and goes through the normal boot up to try and establish the vpn.
It then gets 'stuck' and wont get past vpn configuration.
i have added no new configuration, factory reset again, moved onto another network but still it wont connect to cirrus.
i have tried another new switch and get exactly the same.
Also tried reload working no roll back etc still no joy as well as deleted from cirrus and added again.
Error state Pre provision failed ?
show cloud-agent statu
Admin State : Enabled,
Activation Server State : completeOK,
Device State : PreprovisionFailed,
Error State : PreprovisionHelloOVFailure,
Cloud Group : qscv8mf0e5gldq,
DHCP Address : 192.168.90.63,
DHCP IP Address Mask : 255.255.255.0,
Gateway : 192.168.90.2,
Activation Server : activation.myovcloud.com:443,
Network ID : -,
NTP Server : clock2.ovcirrus.com, clock3.ovcirrus.com, clock1.ovcirrus.com,
clock0.ovcirrus.com,
DNS Server : 8.8.8.8, 8.8.4.4, 208.67.220.220,
DNS Domain : -,
Proxy Server : -,
VPN Server : qscv8mf0e5gldq.tenant.vpn.myovcloud.com:443,
Preprovision Server : qscv8mf0e5gldq.tenant.ovd.myovcloud.com:80,
OV tenant : ramside-hall-hotel.ov.ovcirrus.com:443,
VPN DPD Time (sec) : 0,
Image Server : -,
Image Download Retry Count : -,
Discovery Interval (min) : 30,
Time to next Call Home (sec) : 1535,
Call Home Timer Status : Running,
Discovery Retry Count : 1,
Certificate Status : Consistent
Thin Client : Disabled
Retry Call-Home time remaining : 999997
-> show cloud-agent vpn status
VPN status : Connected,
VPN Assigned IP : 128.251.3.251,
VPN DPD time (sec) : 0
Re: 6560 cirrus connection
Never seen this error. How is the device state in OVC? Maybe the help there gives you a hint.
BR Silvio
selectt
Post by selectt »
hi
Thanks for the reply, cirrus shows the following, see attachment, either connected to VPN or configuring VPN.
Network ID : -,
NTP Server : clock0.ovcirrus.com, clock1.ovcirrus.com, clock3.ovcirrus.com,
DNS Server : 88.215.61.255, 88.215.63.255,
DNS Domain : -,
Proxy Server : -,
Image Server : -,
Time to next Call Home (sec) : 1506,
Discovery Retry Count : 5,
Retry Call-Home time remaining : 999991
maybe in OVC you will find something in the activation log (open the line in the device catalog).
In help you see one line about your state (not very helpful): VPN Configuring - Device is in the process of configuring a secure transport channel for connecting to the OmniVista Cirrus Server.
Probably you have to open a ticket at ALE. Or you search in the KB in myportal for this issue - sometimes you find there a solution.
BR Silvio
selectt
Post by selectt »
ive reported to ALE cirrus expert couldn't resolve it and has had to escalate.
Thanks for responding.
san3
Post by san3 »
Hy there, have you found a solution for this issue?
I had the very same issue, after deleting the /switch/cloud directory and rebooted the switch, I have managed to get over this step. Now the vpn is configured and the switch shows "connected to ov" on OVC, however, the Device State is still PreprovisionFailed.
From 12 Switches, I have only with the OS6560 this Problem... All the OS6360 did just fine...
selectt
Post by selectt »
Hi I escalated to ALE and they deleted the user from CIRRUS for me. They then upgraded my CIRRUS sw and since i can delete modify switches/aps if they are 'stuck' and not communicating correctly on CIRRUS.
