I have 10 telephone centers located approximately 40 to 50 kilometers apart, all interconnected through a network. I want to set up monitoring via the network so that alarms from all centers are displayed in a software backend or one of the centers. What solution do you suggest?
Alarm Center
Re: Alarm Center
All of the , Alcatel Enterprise,
both of the Appliance server on Releases 12 , another on 7.2 .
- frank
Re: Alarm Center
Not very detailed.
Therefore, use SMTP.
It's in the documentation.
- frank
Re: Alarm Center
Good call.. I thought when he wrote "monitored by a software" that it had to be a 3rd party using SNMP traps.
But that works too!
