GD3 out
DjeSan
GD3 out
Post by DjeSan »
Hello
we have an oxe under R9.1 and at the moment I don't know what's going on.
Cr | cpl| cpl type | hw type | cpl state | coupler ID |
| 0 | 6 | CPU_CS2|---------- | IN SERVICE | BAD PCMS CODE |
> Reference rack not set
Crystal 1 :
| 1 | 0 | UA_FICTIF| | IN SERVICE | NO PCMS CODE |
Crystal 2 :
| 2 | 0 | GD3|---------- | REG NOT INIT | BAD PCMS CODE |
| 2 | 1 | SLI2 16(Z)|---------- | REG NOT INIT | BAD PCMS CODE |
| 2 | 2 | UAI 16|---------- | REG NOT INIT | BAD PCMS CODE |
| 2 | 3 | SLI2 16(Z)|---------- | REG NOT INIT | BAD PCMS CODE |
| 2 | 4 | SLI2 16(Z)|---------- | REG NOT INIT | BAD PCMS CODE |
| 2 | 5 | SLI2 16(Z)|---------- | REG NOT INIT | BAD PCMS CODE |
| 2 | 6 | PRA T2|---------- | REG NOT INIT | BAD PCMS CODE |
| 2 | 7 | APA 8|---------- | REG NOT INIT | BAD PCMS CODE |
| 2 | 8 | CS2|---------- | CALL SERVER | BAD PCMS CODE |
this is what I get in my ethernet settings
│ Node Number (reserved) : 3 │
│ Shelf Address : 2 │
│ Board Address : 0 │
│ Shelf - Board Address : 2-0 │
│ Interface Type + GD3 │
│ Board IP Address : 0.0.0.0 │
│ IP NetMask : 0.0.0.0 │
│ Default Gateway IP Address : 0.0.0.0 │
│ IP Quality of service : 0 │
│ Cryptographic box address : ----------------------------------------------- │
│ Board Ethernet Address : 00:80:9F:B5:7B:64 │
│ Interworking with Gatekeeper + NO │
│ Gatekeeper ID : -1 │
│ Numb. of sig. channels IP Phones : 0 │
│ Numb. of sig. channels inter-ACT : 0 │
│ IP Domain Number : 0 │
│ E164 Number List Index : -1 │
│ Gateway H323 name : -------------------------------- │
and when I try a reset on the GD3 I get an error message "SendCpl procedure error".
DjeSan
Re: GD3 out
Post by DjeSan »
hey nothing
oldboy
Re: GD3 out
Post by oldboy »
DjeSan wrote: 10 Oct 2023 07:49hey nothing
do you think everyone sits on this board just waiting on questions from yourself ??? we dont get paid for advice and knowledge so calm down!!!!
Anyway have you actually plugged a cable onto the GD to see what is going on during boot, has the config been lost as it appears when you do a check on 2-0 there is no config on the GD
Re: GD3 out
The first question - this is new added shelf or shelf 2 works before and now not working?
Check (as written before) - "what is going on during boot" with console cable plugged in GD.
Can you ping GD from CPU?
DjeSan
Re: GD3 out
Post by DjeSan »
oldboy wrote: 10 Oct 2023 15:30
hello and sorry sirs
we're currently connected in console mode and we're trying to restore the lost ip address
vad wrote: 10 Oct 2023 23:12 The first question - this is new added shelf or shelf 2 works before and now not working?
no, it's not an oxe 4400 but an oxe small
Re: GD3 out
VAD voulait te dire est ce que l'alveaole 2 est une nouvelle adjonction ou elle fonctionnait avant et s'est mise en arret?
verifier ce qui ne va pas' pendant le boot de la gd comme la suggérée oldboy
Return to “Shelf”
