I have problem with install of omnivista 8770. Because upgrade from version 4.0.7 to 5.1.14 fail during installation process because of Insert Disk 1 error (install from .iso file opened in windows, and not copy to disk directly, I know my fail...)
Now I cleaned all filles and registry from computer and try to install Omnivista 5.1.14 and everytime have error : bin_dsadm.exe stop working
and installation stuck. I found that is some part on SUN ONE server part a try to install all prerequisities like visual c++ 2010 and 2008. But nothing work.
OS: Win SRV2012 R2 std
Is there any solution how to solve this problem?
OV8770 ExecuteActions 09:13:09: install_ldap:
OV8770 ExecuteActions 09:13:09: install_ldap: 7-Zip (a) 18.05 (x86) : Copyright (c) 1999-2018 Igor Pavlov : 2018-04-30
OV8770 ExecuteActions 09:13:09: install_ldap: Scanning the drive for archives:
OV8770 ExecuteActions 09:13:09: install_ldap: 1 file, 74381245 bytes (71 MiB)
OV8770 ExecuteActions 09:13:09: install_ldap: Extracting archive: C:\UPGRADE 2022 - pbx + OV\8770.5.1.14.00.a\Setup\SunONE_11_1_1_7_170717.zip
OV8770 ExecuteActions 09:13:48: install_ldap: --
OV8770 ExecuteActions 09:13:48: install_ldap: Path = C:\UPGRADE 2022 - pbx + OV\8770.5.1.14.00.a\Setup\SunONE_11_1_1_7_170717.zip
OV8770 ExecuteActions 09:13:48: install_ldap: Type = zip
OV8770 ExecuteActions 09:13:48: install_ldap: Physical Size = 74381245
OV8770 ExecuteActions 09:13:48: install_ldap: Everything is Ok
OV8770 ExecuteActions 09:13:48: install_ldap: Folders: 83
OV8770 ExecuteActions 09:13:48: install_ldap: Files: 1133
OV8770 ExecuteActions 09:13:48: install_ldap: Size: 171397774
OV8770 ExecuteActions 09:13:48: install_ldap: Compressed: 74381245
OV8770 ExecuteActions 09:13:48: install_ldap: C:\UPGRADE 2022 - pbx + OV\8770.5.1.14.00.a\Setup>rem Windows firewall
OV8770 ExecuteActions 09:13:48: install_ldap: C:\UPGRADE 2022 - pbx + OV\8770.5.1.14.00.a\Setup>C:\Users\Ustredna\AppData\Local\Temp\{ED25DF56-9ECA-4ECF-AD07-48394B831309}\firewall_allow.vbs "C:\8770\SunONE"
OV8770 ExecuteActions 09:13:50: install_ldap:
OV8770 ExecuteActions 09:13:50: install_ldap: C:\UPGRADE 2022 - pbx + OV\8770.5.1.14.00.a\Setup>set "INSTANCE_DIR=C:\8770\SunONE\bin"
OV8770 ExecuteActions 09:13:50: install_ldap: C:\UPGRADE 2022 - pbx + OV\8770.5.1.14.00.a\Setup>cd /d "C:\8770\SunONE\bin"
OV8770 ExecuteActions 09:13:50: install_ldap: C:\8770\SunONE\bin>echo off
OV8770 ExecuteActions 09:13:50: install_ldap: C:\8770\SunONE\bin>dsadm create -h "TU" -p "389" -P 0 -D "cn=directory manager" -w "C:\Users\Ustredna\AppData\Local\Temp\{ED25DF56-9ECA-4ECF-AD07-48394B831309}\pass.txt" "C:\8770\SunONE\slapd-8770"
OV8770 ExecuteActions 09:14:01: install_ldap: Warning: 389 is a privileged port ; make sure that user 'Ustredna' has right to use it before running start subcommand
OV8770 ExecuteActions 09:14:01: install_ldap: Use command 'dsadm start 'C:\8770\SunONE\slapd-8770'' to start the instance
OV8770 ExecuteActions 09:14:01: install_ldap: C:\8770\SunONE\bin>dsadm enable-service "C:\8770\SunONE\slapd-8770"
MSI (c) (FC:28) [09:33:44:120]: Doing action: NmShowLogFile
Akce 9:33:44: NmShowLogFile.
Začátek akce 9:33:44: NmShowLogFile.
Akce ukončena 9:33:44: NmShowLogFile. Vrácená hodnota: 0.
TY
OV8770 - unable to install
Re: OV8770 - unable to install
Are u using a local Admin account ???
Doesnt look like it, cannot use a domain account
we try to use account Administrato which is in same group Administrators like account Ustredna and installaion gone normal. So there will be some Windows strangeness.
- frank
We have a ton of the same issue here too, installed 8770 5.0 or 5.1 which stays stuck for hours on "Installation of directory server".
We're using admin account.
Anyone else?
Anyone else?
- frank
The install file shows it's stuck here
OV8770 ExecuteActions 10:08:49: install_ldap: C:\8770\SunONE\lib\bin>copy /Y "C:\8770\SunONE\lib\private\ssl3.dll" "C:\Windows\system32"
OV8770 ExecuteActions 10:08:49: install_ldap: 1 file(s) copied.
OV8770 ExecuteActions 10:08:49: install_ldap: C:\8770\SunONE\lib\bin>C:\Users\optel\AppData\Local\Temp\{ED25DF56-9ECA-4ECF-AD07-48394B831309}\firewall_delete.vbs "C:\8770\SunONE"
OV8770 ExecuteActions 10:08:50: install_ldap:
OV8770 ExecuteActions 10:08:50: install_ldap: C:\8770\SunONE\lib\bin>exit 0
it has been about 40 minutes at this last line.
