OS-6360 P-10 - Topology Change Storm detected on port
frazerdsouza
Post by frazerdsouza »
Dear Team,
Received OS6360-P10 8.7.98.R03 GA.
Configured the switch as below
s-> show configuration snapshot
! Chassis:
system name "OS6360"
! Configuration:
configuration error-file-limit 2
! Capability Manager:
! Virtual Flow Control:
! LFP:
! Interface:
! Port_Manager:
! Link Aggregate:
! VLAN:
vlan 1 admin-state enable
vlan 35 admin-state enable
vlan 100 admin-state enable
vlan 100 members port 1/1/9 untagged
vlan 35 members port 1/1/9 tagged
! PVLAN:
! Spanning Tree:
spantree mode flat
spantree vlan 1 admin-state enable
spantree vlan 35 admin-state enable
spantree vlan 100 admin-state enable
When connected the Uplink on management port i get the below
Tue Dec 6 16:53:34 : stpCmm _STPt WARN message:
+++ Topology Change Storm detected on port 1/1/9
Can you please help me on the same?
Gleylancer
Re: OS-6360 P-10 - Topology Change Storm detected on port
Post by Gleylancer »
This is a network design issue. What is connected on Port 1/1/9 and what's the port/spantree configuration there?
frazerdsouza
Port 1/1/9 is the uplink..Vlan 100 as untagged and rest of the VLAN as tagged. I do have OS6350 switch on the network. Where I dont have this type of issues..
Gleylancer
Something on the uplink is causing this. Consider configuring spanning tree with correct priorities on all connected devices.
What is the stp-mode at the other switches (f.e. 6350): flat or 1x1
All switches need to have the same mode - your 6360 has flat.
frazerdsouza
I have installed many other model switches on network without any issues on this model has the problem.
This is my core switch Spanning Tree config
show spantree mode
Spanning Tree Global Parameters
Current Running Mode : 1x1,
Current Protocol : N/A (Per VLAN),
Path Cost Mode : AUTO,
Auto Vlan Containment : N/A
Cisco PVST+ mode : Disabled
Vlan Consistency check: Disabled
Gleylancer
The mode differs, change the configuration to the correct mode.
frazerdsouza wrote: 20 Dec 2022 23:47 I have installed many other model switches on network without any issues on this model has the problem.
show spantree mode
this f.e. is AOS R6 - your 6360 is AOS R8. Are you realy sure about the same STP-mode? In R8 you need to disable auto-fabric.
frazerdsouza
By default switch is on flat mode. My network is on per-vlan
the changes must be globally. Hence I followed below command
-> show spantree mode
Current Running Mode : Flat,
Current Protocol : RSTP,
Auto Vlan Containment : Disabled
auto-fabric admin-state disable
Save Configuration:-
show spantree mode
Current Running Mode : Per VLAN,
This solved the issue
Return to “OmniSwitch 6360”
