combo mode deactivated after power failure
zepeki
Post by zepeki »
Do you know why when I use the copper mode on an OS6360-P24 on ports 1/1/25 or 1/1/26 after a reboot such as a power outage, the port does not turn on anymore and I have to switch the port to fiber mode and back to copper mode?
Thank you for your answers,
Zepeki
Re: combo mode deactivated after power failure
this isn't a normal behavior. If the issue with the newest release 8.9R1 (and necessary uboot) still exist you should open a ticket.
BR Silvio
Return to “OmniSwitch 6360”
