OS 2260 factory default
we have OS 2260 switch it should be factory reset. earlier i made some configuration after that i have done some changes on it, its works after a month the switch going to the earlier configuration. is happens fourth time. i thing it should be reset. if iam going to cd/flash i have see two cfg file one is vcsetup.cfg another one vcboot.cfg. please guide me how to reset it.
Re: OS 2260 factory default
This is the same like for all switches with AOS release 8 (f.e. 6360, 6560, 6860/65, 6900 etc.). Delete all the *.cfg file within the working directory. Than da "reload from working no rollback-timeout".
BR Silvio
BR Silvio
sh log events
1970 Jan 9 2:33:54.50 : CMM : ChassisSupervisor : chassisTrapsAlert - Power supply is OK: PS 1
1970 Jan 9 2:33:54.50 : CMM : ChassisSupervisor : The switch was restarted by a power cycle or due to some type of failure
1970 Jan 9 2:33:54.50 : CMM : ChassisSupervisor : chassisTrapsAlert - CMM startup completed
1970 Jan 9 2:34:13.120 : CMM : stpCmm : STP instance 3: Bridge has become new Root
1970 Jan 9 2:34:20.410 : CMM : vcmCmm : Virtual Chassis: Chassis 1 Role changed to Master
1970 Jan 9 2:34:20.510 : CMM : vcmCmm : Virtual Chassis: Chassis 1 Status changed to Running
1970 Jan 9 2:34:21.270 : CMM : ChassisSupervisor : Sending VC Takeover to NIs and applications [L6]
1970 Jan 9 2:34:24.340 : CMM : ChassisSupervisor : System Ready
1970 Jan 9 2:34:31.310 : CMM : intfCmm : Link 1/1/23 operationally up
1970 Jan 9 2:35:12.410 : CMM : healthCmm : NI 1/1 rising above memory threshold.
1970 Jan 9 2:35:43.650 : CMM : healthCmm : CMMA chassis 1 rising above memory threshold.
1970 Jan 9 2:36:12.530 : CMM : healthCmm : NI 1/1 falling below memory threshold.
1970 Jan 9 2:36:43.710 : CMM : healthCmm : CMMA chassis 1 falling below memory threshold.
1970 Feb 10 22:45:53.910 : CMM : ChassisSupervisor : chassisTrapsAlert - Power supply is OK: PS 1
1970 Feb 10 22:45:53.910 : CMM : ChassisSupervisor : The switch was restarted by a power cycle or due to some type of failure
1970 Feb 10 22:45:53.910 : CMM : ChassisSupervisor : chassisTrapsAlert - CMM startup completed
1970 Feb 10 22:46:12.740 : CMM : stpCmm : STP instance 3: Bridge has become new Root
1970 Feb 10 22:46:20.450 : CMM : ChassisSupervisor : Sending VC Takeover to NIs and applications [L6]
1970 Feb 10 22:46:20.560 : CMM : vcmCmm : Virtual Chassis: Chassis 1 Role changed to Master
1970 Feb 10 22:46:20.590 : CMM : vcmCmm : Virtual Chassis: Chassis 1 Status changed to Running
1970 Feb 10 22:46:23.390 : CMM : ChassisSupervisor : System Ready
1970 Feb 10 22:46:28.320 : CMM : intfCmm : Link 1/1/23 operationally up
1970 Feb 10 22:47:12.260 : CMM : healthCmm : NI 1/1 rising above memory threshold.
1970 Feb 10 22:47:43.230 : CMM : healthCmm : CMMA chassis 1 rising above memory threshold.
1970 Feb 10 22:48:53.710 : CMM : ChassisSupervisor : chassisTrapsAlert - Power supply is OK: PS 1
1970 Feb 10 22:48:53.710 : CMM : ChassisSupervisor : The switch was restarted by a power cycle or due to some type of failure
1970 Feb 10 22:48:53.710 : CMM : ChassisSupervisor : chassisTrapsAlert - CMM startup completed
1970 Feb 10 22:50:54.120 : CMM : ChassisSupervisor : chassisTrapsAlert - Power supply is OK: PS 1
1970 Feb 10 22:50:54.120 : CMM : ChassisSupervisor : The switch was restarted by a power cycle or due to some type of failure
1970 Feb 10 22:50:54.120 : CMM : ChassisSupervisor : chassisTrapsAlert - CMM startup completed
1970 Feb 10 22:51:12.730 : CMM : stpCmm : STP instance 3: Bridge has become new Root
1970 Feb 10 22:51:20.900 : CMM : vcmCmm : Virtual Chassis: Chassis 1 Role changed to Master
1970 Feb 10 22:51:20.980 : CMM : vcmCmm : Virtual Chassis: Chassis 1 Status changed to Running
1970 Feb 10 22:51:21.200 : CMM : ChassisSupervisor : Sending VC Takeover to NIs and applications [L6]
1970 Feb 10 22:51:24.440 : CMM : ChassisSupervisor : System Ready
1970 Feb 10 22:51:28.230 : CMM : intfCmm : Link 1/1/23 operationally up
1970 Feb 10 22:52:12.360 : CMM : healthCmm : NI 1/1 rising above memory threshold.
1970 Feb 10 22:52:43.290 : CMM : healthCmm : CMMA chassis 1 rising above memory threshold.
1970 Feb 10 22:56:12.840 : CMM : healthCmm : NI 1/1 falling below memory threshold.
1970 Feb 10 22:56:43.530 : CMM : healthCmm : CMMA chassis 1 falling below memory threshold.
1970 Feb 20 21:50:55.280 : CMM : intfCmm : Link 1/1/5 operationally up
1970 Feb 20 22:28:57.50 : CMM : intfCmm : Link 1/1/1 operationally up
1970 Feb 20 22:29: 4.20 : CMM : intfCmm : Link 1/1/1 operationally down
1970 Feb 20 22:29: 5.690 : CMM : intfCmm : Link 1/1/1 operationally up
1970 Feb 20 22:31: 3.140 : CMM : intfCmm : Link 1/1/1 operationally down
1970 Feb 20 22:31: 8.320 : CMM : intfCmm : Link 1/1/3 operationally up
1970 Feb 20 22:31:11.850 : CMM : intfCmm : Link 1/1/3 operationally down
1970 Feb 20 22:31:17.190 : CMM : intfCmm : Link 1/1/2 operationally up
1970 Feb 20 22:31:18.540 : CMM : intfCmm : Link 1/1/2 operationally down
1970 Feb 20 22:31:24.180 : CMM : intfCmm : Link 1/1/17 operationally up
1970 Feb 20 22:31:26.770 : CMM : intfCmm : Link 1/1/17 operationally down
1970 Feb 20 22:31:30.790 : CMM : intfCmm : Link 1/1/20 operationally up
1970 Feb 20 22:31:37.150 : CMM : intfCmm : Link 1/1/20 operationally down
1970 Feb 20 22:31:38.900 : CMM : intfCmm : Link 1/1/20 operationally up
1970 Feb 20 22:32:47.600 : CMM : intfCmm : Link 1/1/5 operationally down
1970 Feb 20 22:32:55.360 : CMM : intfCmm : Link 1/1/20 operationally down
1970 Feb 20 22:33:13.320 : CMM : intfCmm : Link 1/1/1 operationally up
1970 Feb 20 22:33:19.710 : CMM : intfCmm : Link 1/1/1 operationally down
1970 Feb 20 22:33:21.370 : CMM : intfCmm : Link 1/1/1 operationally up
1970 Feb 20 22:34: 6.740 : CMM : intfCmm : Link 1/1/2 operationally up
1970 Feb 20 22:34:12.920 : CMM : intfCmm : Link 1/1/2 operationally down
1970 Feb 20 22:34:14.620 : CMM : intfCmm : Link 1/1/2 operationally up
1970 Feb 20 22:38: 8.430 : CMM : intfCmm : Link 1/1/3 operationally up
1970 Feb 20 22:38:14.800 : CMM : intfCmm : Link 1/1/3 operationally down
1970 Feb 20 22:38:16.480 : CMM : intfCmm : Link 1/1/3 operationally up
1970 Feb 20 22:38:16.670 : CMM : intfCmm : Link 1/1/5 operationally up
1970 Feb 20 22:38:23.40 : CMM : intfCmm : Link 1/1/5 operationally down
1970 Feb 20 22:38:24.760 : CMM : intfCmm : Link 1/1/5 operationally up
1970 Feb 20 22:40: 3.720 : CMM : intfCmm : Link 1/1/5 operationally down
1970 Feb 20 23:19: 4.560 : CMM : intfCmm : Link 1/1/3 operationally down
1970 Feb 20 23:19:25.410 : CMM : intfCmm : Link 1/1/3 operationally up
1970 Feb 20 23:38:44.370 : CMM : intfCmm : Link 1/1/3 operationally down
1970 Feb 20 23:39:16.350 : CMM : intfCmm : Link 1/1/3 operationally up
1970 Feb 20 23:39:22.730 : CMM : intfCmm : Link 1/1/3 operationally down
1970 Feb 20 23:39:24.390 : CMM : intfCmm : Link 1/1/3 operationally up
1970 Feb 20 23:44:22.450 : CMM : intfCmm : Link 1/1/2 operationally down
1970 Feb 20 23:44:25.740 : CMM : intfCmm : Link 1/1/2 operationally up
1970 Feb 20 23:44:32.90 : CMM : intfCmm : Link 1/1/2 operationally down
1970 Feb 20 23:44:33.790 : CMM : intfCmm : Link 1/1/2 operationally up
1970 Feb 20 23:47: 7.880 : CMM : intfCmm : Link 1/1/2 operationally down
1970 Feb 20 23:51:23.90 : CMM : intfCmm : Link 1/1/3 operationally down
1970 Feb 20 23:52:30.460 : CMM : intfCmm : Link 1/1/1 operationally down
1970 Feb 21 0: 1:25.810 : CMM : intfCmm : Link 1/1/2 operationally up
1970 Feb 21 0: 1:32.170 : CMM : intfCmm : Link 1/1/2 operationally down
1970 Feb 21 0: 1:33.870 : CMM : intfCmm : Link 1/1/2 operationally up
1970 Feb 21 0: 2:44.630 : CMM : intfCmm : Link 1/1/2 operationally down
1970 Feb 21 0: 2:46.320 : CMM : intfCmm : Link 1/1/2 operationally up
1970 Feb 21 0: 7:12.820 : CMM : intfCmm : Link 1/1/2 operationally down
1970 Feb 21 0: 7:38.800 : CMM : intfCmm : Link 1/1/3 operationally up
1970 Feb 21 0: 7:43.650 : CMM : intfCmm : Link 1/1/2 operationally up
1970 Feb 21 0: 7:44.900 : CMM : intfCmm : Link 1/1/3 operationally down
1970 Feb 21 0: 7:46.660 : CMM : intfCmm : Link 1/1/3 operationally up
1970 Feb 21 0: 7:50.20 : CMM : intfCmm : Link 1/1/2 operationally down
1970 Feb 21 0: 7:51.730 : CMM : intfCmm : Link 1/1/2 operationally up
1970 Feb 21 0: 9:23.870 : CMM : intfCmm : Link 1/1/2 operationally down
1970 Feb 21 0:10: 6.280 : CMM : intfCmm : Link 1/1/2 operationally up
1970 Feb 21 0:10:13.410 : CMM : intfCmm : Link 1/1/2 operationally down
1970 Feb 21 0:10:15.110 : CMM : intfCmm : Link 1/1/2 operationally up
1970 Feb 21 0:11:55.180 : CMM : intfCmm : Link 1/1/2 operationally down
1970 Feb 21 0:14:35.590 : CMM : intfCmm : Link 1/1/1 operationally up
1970 Feb 21 0:14:41.920 : CMM : intfCmm : Link 1/1/1 operationally down
1970 Feb 21 0:14:43.620 : CMM : intfCmm : Link 1/1/1 operationally up
1970 Feb 21 0:15: 3.910 : CMM : intfCmm : Link 1/1/3 operationally down
1970 Feb 21 0:15:12.530 : CMM : intfCmm : Link 1/1/3 operationally up
1970 Feb 21 0:15:18.830 : CMM : intfCmm : Link 1/1/3 operationally down
1970 Feb 21 0:15:20.580 : CMM : intfCmm : Link 1/1/3 operationally up
1970 Feb 21 0:19:28.720 : CMM : intfCmm : Link 1/1/1 operationally down
1970 Feb 21 0:19:33.560 : CMM : intfCmm : Link 1/1/1 operationally up
1970 Feb 21 0:19:39.930 : CMM : intfCmm : Link 1/1/1 operationally down
1970 Feb 21 0:19:41.770 : CMM : intfCmm : Link 1/1/1 operationally up
1970 Feb 21 0:22: 2.940 : CMM : intfCmm : Link 1/1/1 operationally down
1970 Feb 21 0:23:18.0 : CMM : intfCmm : Link 1/1/3 operationally down
1970 Feb 21 0:23:43.710 : CMM : intfCmm : Link 1/1/3 operationally up
1970 Feb 21 0:23:50.80 : CMM : intfCmm : Link 1/1/3 operationally down
1970 Feb 21 0:23:51.800 : CMM : intfCmm : Link 1/1/3 operationally up
1970 Feb 21 0:24: 9.160 : CMM : intfCmm : Link 1/1/1 operationally up
1970 Feb 21 0:24:15.540 : CMM : intfCmm : Link 1/1/1 operationally down
1970 Feb 21 0:24:17.170 : CMM : intfCmm : Link 1/1/1 operationally up
1970 Feb 21 0:24:38.800 : CMM : intfCmm : Link 1/1/2 operationally up
1970 Feb 21 0:24:45.60 : CMM : intfCmm : Link 1/1/2 operationally down
1970 Feb 21 0:24:46.740 : CMM : intfCmm : Link 1/1/2 operationally up
1970 Feb 21 0:27:50.410 : CMM : intfCmm : Link 1/1/3 operationally down
1970 Feb 21 0:31:14.640 : CMM : intfCmm : Link 1/1/1 operationally down
1970 Feb 21 0:31:18.40 : CMM : intfCmm : Link 1/1/1 operationally up
1970 Feb 21 0:31:24.410 : CMM : intfCmm : Link 1/1/1 operationally down
1970 Feb 21 0:31:26.100 : CMM : intfCmm : Link 1/1/1 operationally up
1970 Feb 21 0:32:20.850 : CMM : intfCmm : Link 1/1/1 operationally down
1970 Feb 21 0:37:52.60 : CMM : intfCmm : Link 1/1/1 operationally up
1970 Feb 21 0:37:58.450 : CMM : intfCmm : Link 1/1/1 operationally down
1970 Feb 21 0:38: 0.160 : CMM : intfCmm : Link 1/1/1 operationally up
1970 Feb 21 0:38: 9.60 : CMM : intfCmm : Link 1/1/3 operationally up
1970 Feb 21 0:38:15.400 : CMM : intfCmm : Link 1/1/3 operationally down
1970 Feb 21 0:38:17.100 : CMM : intfCmm : Link 1/1/3 operationally up
1970 Feb 21 0:38:29.250 : CMM : intfCmm : Link 1/1/2 operationally down
1970 Feb 21 0:40:27.550 : CMM : intfCmm : Link 1/1/2 operationally up
1970 Feb 21 0:40:33.900 : CMM : intfCmm : Link 1/1/2 operationally down
1970 Feb 21 0:40:35.610 : CMM : intfCmm : Link 1/1/2 operationally up
1970 Feb 21 0:46:52.900 : CMM : intfCmm : Link 1/1/1 operationally down
1970 Feb 21 0:48:52.750 : CMM : intfCmm : Link 1/1/3 operationally down
1970 Feb 21 0:52:12.950 : CMM : intfCmm : Link 1/1/2 operationally down
1970 Feb 21 0:52:43.600 : CMM : intfCmm : Link 1/1/1 operationally up
1970 Feb 21 0:52:49.950 : CMM : intfCmm : Link 1/1/1 operationally down
1970 Feb 21 0:52:51.650 : CMM : intfCmm : Link 1/1/1 operationally up
1970 Feb 21 0:52:59.470 : CMM : intfCmm : Link 1/1/3 operationally up
1970 Feb 21 0:53: 5.680 : CMM : intfCmm : Link 1/1/3 operationally down
1970 Feb 21 0:53: 7.560 : CMM : intfCmm : Link 1/1/3 operationally up
1970 Feb 21 0:53:14.440 : CMM : intfCmm : Link 1/1/2 operationally up
1970 Feb 21 0:53:20.740 : CMM : intfCmm : Link 1/1/2 operationally down
1970 Feb 21 0:53:22.460 : CMM : intfCmm : Link 1/1/2 operationally up
1970 Feb 21 0:59:16.230 : CMM : intfCmm : Link 1/1/1 operationally down
1970 Feb 21 0:59:20.210 : CMM : intfCmm : Link 1/1/1 operationally up
1970 Feb 21 0:59:26.500 : CMM : intfCmm : Link 1/1/1 operationally down
1970 Feb 21 0:59:28.180 : CMM : intfCmm : Link 1/1/1 operationally up
1970 Feb 21 1: 0:23.700 : CMM : intfCmm : Link 1/1/1 operationally down
1970 Feb 21 1: 0:40.40 : CMM : intfCmm : Link 1/1/1 operationally up
1970 Feb 21 1: 0:46.310 : CMM : intfCmm : Link 1/1/1 operationally down
1970 Feb 21 1: 0:48.0 : CMM : intfCmm : Link 1/1/1 operationally up
1970 Feb 21 1: 0:48.920 : CMM : intfCmm : Link 1/1/3 operationally down
1970 Feb 21 1: 1:34.830 : CMM : intfCmm : Link 1/1/1 operationally down
1970 Feb 21 1: 2:49.190 : CMM : intfCmm : Link 1/1/3 operationally up
1970 Feb 21 1: 2:55.540 : CMM : intfCmm : Link 1/1/3 operationally down
1970 Feb 21 1: 2:57.240 : CMM : intfCmm : Link 1/1/3 operationally up
1970 Feb 21 1: 3: 3.820 : CMM : intfCmm : Link 1/1/1 operationally up
1970 Feb 21 1: 3:10.970 : CMM : intfCmm : Link 1/1/1 operationally down
1970 Feb 21 1: 3:11.10 : CMM : intfCmm : Link 1/1/2 operationally down
1970 Feb 21 1: 3:12.640 : CMM : intfCmm : Link 1/1/1 operationally up
1970 Feb 21 1: 5:58.810 : CMM : intfCmm : Link 1/1/2 operationally up
1970 Feb 21 1: 6: 5.180 : CMM : intfCmm : Link 1/1/2 operationally down
1970 Feb 21 1: 6: 6.900 : CMM : intfCmm : Link 1/1/2 operationally up
1970 Feb 21 1: 8:49.710 : CMM : intfCmm : Link 1/1/3 operationally down
1970 Feb 21 1: 9: 9.500 : CMM : intfCmm : Link 1/1/3 operationally up
1970 Feb 21 1: 9:15.870 : CMM : intfCmm : Link 1/1/3 operationally down
1970 Feb 21 1: 9:17.570 : CMM : intfCmm : Link 1/1/3 operationally up
1970 Feb 21 1:10:20.900 : CMM : intfCmm : Link 1/1/3 operationally down
1970 Feb 21 1:10:58.20 : CMM : intfCmm : Link 1/1/1 operationally down
1970 Feb 21 1:41:17.700 : CMM : intfCmm : Link 1/1/2 operationally down
1970 Feb 21 1:44:34.240 : CMM : intfCmm : Link 1/1/3 operationally up
1970 Feb 21 1:44:40.540 : CMM : intfCmm : Link 1/1/3 operationally down
1970 Feb 21 1:44:42.330 : CMM : intfCmm : Link 1/1/3 operationally up
1970 Feb 21 1:45:11.260 : CMM : intfCmm : Link 1/1/2 operationally up
1970 Feb 21 1:46:33.540 : CMM : intfCmm : Link 1/1/1 operationally up
1970 Feb 21 1:46:40.710 : CMM : intfCmm : Link 1/1/1 operationally down
1970 Feb 21 1:46:42.400 : CMM : intfCmm : Link 1/1/1 operationally up
1970 Feb 21 1:55:12.890 : CMM : intfCmm : Link 1/1/3 operationally down
1970 Feb 21 1:55:29.390 : CMM : intfCmm : Link 1/1/3 operationally up
1970 Feb 21 1:55:36.450 : CMM : intfCmm : Link 1/1/3 operationally down
1970 Feb 21 1:55:38.370 : CMM : intfCmm : Link 1/1/3 operationally up
1970 Feb 21 2: 0:54.390 : CMM : intfCmm : Link 1/1/3 operationally down
1970 Feb 21 2: 1: 8.240 : CMM : intfCmm : Link 1/1/3 operationally up
1970 Feb 21 2: 1:14.420 : CMM : intfCmm : Link 1/1/3 operationally down
1970 Feb 21 2: 1:16.120 : CMM : intfCmm : Link 1/1/3 operationally up
1970 Feb 21 2: 2:17.980 : CMM : intfCmm : Link 1/1/1 operationally down
1970 Feb 21 2: 2:56.690 : CMM : intfCmm : Link 1/1/3 operationally down
1970 Feb 21 2:22:51.410 : CMM : intfCmm : Link 1/1/3 operationally up
1970 Feb 21 2:22:58.600 : CMM : intfCmm : Link 1/1/3 operationally down
1970 Feb 21 2:23: 1.40 : CMM : intfCmm : Link 1/1/3 operationally up
1970 Feb 21 2:28:44.200 : CMM : intfCmm : Link 1/1/3 operationally down
1970 Feb 21 2:28:51.980 : CMM : intfCmm : Link 1/1/3 operationally up
1970 Feb 21 2:28:59.370 : CMM : intfCmm : Link 1/1/3 operationally down
1970 Feb 21 2:29: 1.780 : CMM : intfCmm : Link 1/1/3 operationally up
1970 Feb 21 2:29:47.950 : CMM : intfCmm : Link 1/1/3 operationally down
1970 Feb 21 2:34:58.130 : CMM : intfCmm : Link 1/1/2 operationally down
1970 Mar 2 2: 0:54.970 : CMM : intfCmm : Link 1/1/6 operationally up
1970 Mar 2 2: 3: 0.720 : CMM : intfCmm : Link 1/1/6 operationally down
1970 Mar 2 2: 3:23.40 : CMM : intfCmm : Link 1/1/23 operationally down
1970 Mar 2 2: 3:25.710 : CMM : intfCmm : Link 1/1/23 operationally up
1970 Mar 2 2:15:20.120 : CMM : intfCmm : Link 1/1/15 operationally up
1970 Mar 2 3:12:49.370 : CMM : intfCmm : Link 1/1/1 operationally up
1970 Mar 2 3:12:55.740 : CMM : intfCmm : Link 1/1/1 operationally down
1970 Mar 2 3:12:57.480 : CMM : intfCmm : Link 1/1/1 operationally up
1970 Mar 2 3:19:18.630 : CMM : intfCmm : Link 1/1/1 operationally down
1970 Mar 2 3:22:52.450 : CMM : intfCmm : Link 1/1/12 operationally up
1970 Mar 2 3:22:58.620 : CMM : intfCmm : Link 1/1/12 operationally down
1970 Mar 2 3:23: 0.320 : CMM : intfCmm : Link 1/1/12 operationally up
1970 Mar 2 3:23: 2.370 : CMM : intfCmm : Link 1/1/13 operationally up
1970 Mar 2 3:23: 8.580 : CMM : intfCmm : Link 1/1/13 operationally down
1970 Mar 2 3:23:10.300 : CMM : intfCmm : Link 1/1/13 operationally up
1970 Mar 2 3:23:42.440 : CMM : intfCmm : Link 1/1/15 operationally down
1970 Mar 2 3:23:59.440 : CMM : intfCmm : Link 1/1/16 operationally up
1970 Mar 2 3:24: 5.520 : CMM : intfCmm : Link 1/1/16 operationally down
1970 Mar 2 3:24: 7.280 : CMM : intfCmm : Link 1/1/16 operationally up
1970 Mar 2 20:36:56.170 : CMM : intfCmm : Link 1/1/12 operationally down
1970 Mar 2 20:37:13.220 : CMM : intfCmm : Link 1/1/13 operationally down
1970 Mar 2 20:37:13.900 : CMM : intfCmm : Link 1/1/12 operationally up
1970 Mar 2 20:37:20.260 : CMM : intfCmm : Link 1/1/12 operationally down
1970 Mar 2 20:37:21.930 : CMM : intfCmm : Link 1/1/12 operationally up
1970 Mar 2 20:37:32.630 : CMM : intfCmm : Link 1/1/13 operationally up
1970 Mar 2 20:37:39.10 : CMM : intfCmm : Link 1/1/13 operationally down
1970 Mar 2 20:37:40.690 : CMM : intfCmm : Link 1/1/13 operationally up
1970 Mar 2 20:38:30.570 : CMM : intfCmm : Link 1/1/16 operationally down
1970 Mar 2 20:38:49.730 : CMM : intfCmm : Link 1/1/16 operationally up
1970 Mar 2 20:38:56.70 : CMM : intfCmm : Link 1/1/16 operationally down
1970 Mar 2 20:38:57.820 : CMM : intfCmm : Link 1/1/16 operationally up
1970 Mar 2 20:46:10.220 : CMM : intfCmm : Link 1/1/12 operationally down
1970 Mar 2 20:46:26.650 : CMM : intfCmm : Link 1/1/13 operationally down
1970 Mar 2 20:46:28.220 : CMM : intfCmm : Link 1/1/12 operationally up
1970 Mar 2 20:46:34.590 : CMM : intfCmm : Link 1/1/12 operationally down
1970 Mar 2 20:46:36.250 : CMM : intfCmm : Link 1/1/12 operationally up
1970 Mar 2 20:46:58.280 : CMM : intfCmm : Link 1/1/13 operationally up
1970 Mar 2 20:47: 4.650 : CMM : intfCmm : Link 1/1/13 operationally down
1970 Mar 2 20:47: 6.360 : CMM : intfCmm : Link 1/1/13 operationally up
1970 Mar 2 20:47:48.910 : CMM : intfCmm : Link 1/1/16 operationally down
1970 Mar 2 20:48:12.820 : CMM : intfCmm : Link 1/1/16 operationally up
1970 Mar 2 20:48:19.200 : CMM : intfCmm : Link 1/1/16 operationally down
1970 Mar 2 20:48:20.860 : CMM : intfCmm : Link 1/1/16 operationally up
1970 Mar 2 21:40:37.900 : CMM : intfCmm : Link 1/1/24 operationally up
1970 Mar 2 21:40:44.270 : CMM : intfCmm : Link 1/1/24 operationally down
1970 Mar 2 21:40:46.100 : CMM : intfCmm : Link 1/1/24 operationally up
1970 Mar 2 21:42:15.960 : CMM : intfCmm : Link 1/1/19 operationally up
1970 Mar 2 21:42:22.140 : CMM : intfCmm : Link 1/1/19 operationally down
1970 Mar 2 21:42:23.820 : CMM : intfCmm : Link 1/1/19 operationally up
1970 Mar 2 23: 4:43.730 : CMM : intfCmm : Link 1/1/22 operationally up
1970 Mar 2 23: 4:49.940 : CMM : intfCmm : Link 1/1/22 operationally down
1970 Mar 2 23: 4:51.650 : CMM : intfCmm : Link 1/1/22 operationally up
1970 Mar 3 0: 0: 7.350 : CMM : intfCmm : Link 1/1/24 operationally down
1970 Mar 3 0: 0:26.680 : CMM : intfCmm : Link 1/1/24 operationally up
1970 Mar 3 0: 0:42.230 : CMM : intfCmm : Link 1/1/24 operationally down
1970 Mar 3 0: 0:48.80 : CMM : intfCmm : Link 1/1/24 operationally up
1970 Mar 3 0: 0:54.440 : CMM : intfCmm : Link 1/1/24 operationally down
1970 Mar 3 0: 0:56.170 : CMM : intfCmm : Link 1/1/24 operationally up
1970 Mar 3 0: 4:21.850 : CMM : intfCmm : Link 1/1/24 operationally down
1970 Mar 3 0: 6:20.840 : CMM : intfCmm : Link 1/1/22 operationally down
1970 Mar 3 0: 7:12.720 : CMM : intfCmm : Link 1/1/16 operationally down
1970 Mar 3 0: 8:50.50 : CMM : intfCmm : Link 1/1/16 operationally up
1970 Mar 3 0: 8:56.410 : CMM : intfCmm : Link 1/1/16 operationally down
1970 Mar 3 0: 8:58.90 : CMM : intfCmm : Link 1/1/16 operationally up
1970 Mar 3 0:22:56.720 : CMM : intfCmm : Link 1/1/24 operationally up
1970 Mar 3 0:23: 2.850 : CMM : intfCmm : Link 1/1/24 operationally down
1970 Mar 3 0:23: 4.800 : CMM : intfCmm : Link 1/1/24 operationally up
1970 Mar 3 0:34:32.490 : CMM : intfCmm : Link 1/1/15 operationally up
1970 Mar 3 0:34:38.620 : CMM : intfCmm : Link 1/1/15 operationally down
1970 Mar 3 0:34:40.280 : CMM : intfCmm : Link 1/1/15 operationally up
1970 Mar 3 0:38:30.60 : CMM : intfCmm : Link 1/1/14 operationally up
1970 Mar 3 0:38:36.240 : CMM : intfCmm : Link 1/1/14 operationally down
1970 Mar 3 0:38:37.960 : CMM : intfCmm : Link 1/1/14 operationally up
1970 Mar 3 0:41: 2.400 : CMM : intfCmm : Link 1/1/19 operationally down
1970 Mar 3 2:29:31.170 : CMM : intfCmm : Link 1/1/21 operationally up
1970 Mar 3 2:34:26.350 : CMM : intfCmm : Link 1/1/21 operationally down
1970 Mar 3 2:34:30.560 : CMM : intfCmm : Link 1/1/21 operationally up
1970 Mar 3 2:35:57.860 : CMM : SES : Authentication failure detected: user admin
1970 Mar 3 2:36: 5.320 : CMM : SES : Authentication failure detected: user admin
1970 Mar 3 2:44:54.970 : CMM : intfCmm : Link 1/1/21 operationally down
1970 Mar 3 2:45:22.760 : CMM : intfCmm : Link 1/1/21 operationally up
1970 Mar 3 3: 1:32.120 : CMM : intfCmm : Link 1/1/21 operationally down
1970 Mar 3 3: 1:36.840 : CMM : intfCmm : Link 1/1/21 operationally up
1970 Mar 3 3:23:22.950 : CMM : intfCmm : Link 1/1/21 operationally down
1970 Mar 3 3:23:26.710 : CMM : intfCmm : Link 1/1/21 operationally up
1970 Mar 3 3:30:21.760 : CMM : intfCmm : Link 1/1/21 operationally down
1970 Mar 3 3:30:24.900 : CMM : intfCmm : Link 1/1/21 operationally up
1970 Mar 3 3:32:11.660 : CMM : intfCmm : Link 1/1/21 operationally down
1970 Mar 3 4: 1: 5.730 : CMM : intfCmm : Link 1/1/21 operationally up
1970 Mar 3 4:27:46.970 : CMM : intfCmm : Link 1/1/21 operationally down
1970 Mar 3 4:29: 4.570 : CMM : intfCmm : Link 1/1/21 operationally up
1970 Mar 3 4:29:28.480 : CMM : intfCmm : Link 1/1/21 operationally down
1970 Mar 5 20:46:43.450 : CMM : intfCmm : Link 1/1/12 operationally down
1970 Mar 5 20:46:48.590 : CMM : intfCmm : Link 1/1/12 operationally up
1970 Mar 5 20:46:54.960 : CMM : intfCmm : Link 1/1/12 operationally down
1970 Mar 5 20:46:56.690 : CMM : intfCmm : Link 1/1/12 operationally up
1970 Mar 5 20:47:41.830 : CMM : intfCmm : Link 1/1/12 operationally down
1970 Mar 5 20:47:50.360 : CMM : intfCmm : Link 1/1/12 operationally up
1970 Mar 5 20:47:56.540 : CMM : intfCmm : Link 1/1/12 operationally down
1970 Mar 5 20:47:58.200 : CMM : intfCmm : Link 1/1/12 operationally up
1970 Mar 5 20:49: 2.920 : CMM : intfCmm : Link 1/1/24 operationally down
1970 Mar 5 20:49: 3.20 : CMM : intfCmm : Link 1/1/12 operationally down
1970 Mar 5 20:49: 3.50 : CMM : intfCmm : Link 1/1/14 operationally down
1970 Mar 5 20:49: 3.70 : CMM : intfCmm : Link 1/1/13 operationally down
1970 Mar 5 20:49: 3.90 : CMM : intfCmm : Link 1/1/16 operationally down
1970 Mar 5 20:49: 3.110 : CMM : intfCmm : Link 1/1/15 operationally down
1970 Mar 5 20:47:53.820 : CMM : ChassisSupervisor : chassisTrapsAlert - Power supply is OK: PS 1
1970 Mar 5 20:47:53.820 : CMM : ChassisSupervisor : The switch was restarted by a power cycle or due to some type of failure
1970 Mar 5 20:47:53.820 : CMM : ChassisSupervisor : chassisTrapsAlert - CMM startup completed
1970 Mar 5 20:48:13.20 : CMM : stpCmm : STP instance 3: Bridge has become new Root
1970 Mar 5 20:48:20.480 : CMM : vcmCmm : Virtual Chassis: Chassis 1 Role changed to Master
1970 Mar 5 20:48:20.480 : CMM : vcmCmm : Virtual Chassis: Chassis 1 Status changed to Running
1970 Mar 5 20:48:20.870 : CMM : ChassisSupervisor : Sending VC Takeover to NIs and applications [L6]
1970 Mar 5 20:48:23.350 : CMM : ChassisSupervisor : System Ready
1970 Mar 5 20:48:28.40 : CMM : intfCmm : Link 1/1/23 operationally up
1970 Mar 5 20:48:59.520 : CMM : intfCmm : Link 1/1/14 operationally up
1970 Mar 5 20:48:59.700 : CMM : intfCmm : Link 1/1/14 operationally down
1970 Mar 5 20:50:54.270 : CMM : ChassisSupervisor : chassisTrapsAlert - Power supply is OK: PS 1
1970 Mar 5 20:50:54.270 : CMM : ChassisSupervisor : The switch was restarted by a power cycle or due to some type of failure
1970 Mar 5 20:50:54.270 : CMM : ChassisSupervisor : chassisTrapsAlert - CMM startup completed
1970 Mar 5 20:51:12.870 : CMM : stpCmm : STP instance 3: Bridge has become new Root
1970 Mar 5 20:51:20.510 : CMM : ChassisSupervisor : Sending VC Takeover to NIs and applications [L6]
1970 Mar 5 20:51:21.320 : CMM : vcmCmm : Virtual Chassis: Chassis 1 Role changed to Master
1970 Mar 5 20:51:21.410 : CMM : vcmCmm : Virtual Chassis: Chassis 1 Status changed to Running
1970 Mar 5 20:51:23.940 : CMM : ChassisSupervisor : System Ready
1970 Mar 5 20:51:28.470 : CMM : intfCmm : Link 1/1/23 operationally up
1970 Mar 5 20:52: 0.70 : CMM : intfCmm : Link 1/1/14 operationally up
1970 Mar 5 20:52: 0.830 : CMM : intfCmm : Link 1/1/16 operationally up
1970 Mar 5 20:52: 0.920 : CMM : intfCmm : Link 1/1/13 operationally up
1970 Mar 5 20:52: 1.220 : CMM : intfCmm : Link 1/1/15 operationally up
1970 Mar 5 20:52: 1.700 : CMM : intfCmm : Link 1/1/12 operationally up
1970 Mar 5 20:52: 2.500 : CMM : intfCmm : Link 1/1/24 operationally up
1970 Mar 5 20:52: 6.150 : CMM : intfCmm : Link 1/1/14 operationally down
1970 Mar 5 20:52: 6.930 : CMM : intfCmm : Link 1/1/16 operationally down
1970 Mar 5 20:52: 7.300 : CMM : intfCmm : Link 1/1/15 operationally down
1970 Mar 5 20:52: 7.790 : CMM : intfCmm : Link 1/1/13 operationally down
1970 Mar 5 20:52: 7.820 : CMM : intfCmm : Link 1/1/14 operationally up
1970 Mar 5 20:52: 7.880 : CMM : intfCmm : Link 1/1/12 operationally down
1970 Mar 5 20:52: 8.450 : CMM : intfCmm : Link 1/1/14 operationally down
1970 Mar 5 20:52: 8.470 : CMM : intfCmm : Link 1/1/24 operationally down
1970 Mar 5 20:52:12.590 : CMM : healthCmm : NI 1/1 rising above memory threshold.
1970 Mar 5 20:52:38.420 : CMM : lpCmm : PSE port 1/1/12 is (not) delivering power
1970 Mar 5 20:52:38.420 : CMM : lpCmm : PSE port 1/1/13 is (not) delivering power
1970 Mar 5 20:52:38.420 : CMM : lpCmm : PSE port 1/1/14 is (not) delivering power
1970 Mar 5 20:52:38.420 : CMM : lpCmm : PSE port 1/1/15 is (not) delivering power
1970 Mar 5 20:52:38.420 : CMM : lpCmm : PSE port 1/1/16 is (not) delivering power
1970 Mar 5 20:52:38.420 : CMM : lpCmm : PSE port 1/1/24 is (not) delivering power
1970 Mar 5 20:52:43.500 : CMM : healthCmm : CMMA chassis 1 rising above memory threshold.
1970 Mar 5 20:56:13.70 : CMM : healthCmm : NI 1/1 falling below memory threshold.
1970 Mar 5 20:56:43.740 : CMM : healthCmm : CMMA chassis 1 falling below memory threshold.
1970 Mar 8 21:48:54.150 : CMM : ChassisSupervisor : chassisTrapsAlert - Power supply is OK: PS 1
1970 Mar 8 21:48:54.150 : CMM : ChassisSupervisor : The switch was restarted by a power cycle or due to some type of failure
1970 Mar 8 21:48:54.150 : CMM : ChassisSupervisor : chassisTrapsAlert - CMM startup completed
1970 Mar 8 21:49:13.240 : CMM : stpCmm : STP instance 3: Bridge has become new Root
1970 Mar 8 21:49:21.50 : CMM : ChassisSupervisor : Sending VC Takeover to NIs and applications [L6]
1970 Mar 8 21:49:21.370 : CMM : vcmCmm : Virtual Chassis: Chassis 1 Role changed to Master
1970 Mar 8 21:49:21.420 : CMM : vcmCmm : Virtual Chassis: Chassis 1 Status changed to Running
1970 Mar 8 21:49:24.480 : CMM : ChassisSupervisor : System Ready
1970 Mar 8 21:49:28.470 : CMM : intfCmm : Link 1/1/23 operationally up
1970 Mar 8 21:49:59.940 : CMM : intfCmm : Link 1/1/14 operationally up
1970 Mar 8 21:50: 0.650 : CMM : intfCmm : Link 1/1/16 operationally up
1970 Mar 8 21:50: 0.800 : CMM : intfCmm : Link 1/1/13 operationally up
1970 Mar 8 21:50: 1.160 : CMM : intfCmm : Link 1/1/15 operationally up
1970 Mar 8 21:50: 1.690 : CMM : intfCmm : Link 1/1/12 operationally up
1970 Mar 8 21:50: 3.450 : CMM : intfCmm : Link 1/1/24 operationally up
1970 Mar 8 21:50: 6.60 : CMM : intfCmm : Link 1/1/14 operationally down
1970 Mar 8 21:50: 6.820 : CMM : intfCmm : Link 1/1/16 operationally down
1970 Mar 8 21:50: 7.230 : CMM : intfCmm : Link 1/1/15 operationally down
1970 Mar 8 21:50: 7.700 : CMM : intfCmm : Link 1/1/13 operationally down
1970 Mar 8 21:50: 7.730 : CMM : intfCmm : Link 1/1/14 operationally up
1970 Mar 8 21:50: 7.800 : CMM : intfCmm : Link 1/1/12 operationally down
1970 Mar 8 21:50: 8.350 : CMM : intfCmm : Link 1/1/14 operationally down
1970 Mar 8 21:50: 8.380 : CMM : intfCmm : Link 1/1/24 operationally down
1970 Mar 8 21:50:12.560 : CMM : healthCmm : NI 1/1 rising above memory threshold.
1970 Mar 8 21:50:38.330 : CMM : lpCmm : PSE port 1/1/12 is (not) delivering power
1970 Mar 8 21:50:38.330 : CMM : lpCmm : PSE port 1/1/13 is (not) delivering power
1970 Mar 8 21:50:38.330 : CMM : lpCmm : PSE port 1/1/14 is (not) delivering power
1970 Mar 8 21:50:38.330 : CMM : lpCmm : PSE port 1/1/15 is (not) delivering power
1970 Mar 8 21:50:38.330 : CMM : lpCmm : PSE port 1/1/16 is (not) delivering power
1970 Mar 8 21:50:38.330 : CMM : lpCmm : PSE port 1/1/24 is (not) delivering power
1970 Mar 8 21:50:43.700 : CMM : healthCmm : CMMA chassis 1 rising above memory threshold.
1970 Mar 8 21:51:12.680 : CMM : healthCmm : NI 1/1 falling below memory threshold.
1970 Mar 8 21:51:38.330 : CMM : intfCmm : Link 1/1/23 operationally down
1970 Mar 8 21:51:43.760 : CMM : healthCmm : CMMA chassis 1 falling below memory threshold.
1970 Mar 8 21:52: 8.970 : CMM : intfCmm : Link 1/1/23 operationally up
1970 Mar 8 22: 8: 8.550 : CMM : intfCmm : Link 1/1/24 operationally up
1970 Mar 8 22:11:56.910 : CMM : intfCmm : Link 1/1/12 operationally up
1970 Mar 8 22:11:57.550 : CMM : intfCmm : Link 1/1/15 operationally up
1970 Mar 8 22:11:57.650 : CMM : intfCmm : Link 1/1/14 operationally up
1970 Mar 8 22:11:58.70 : CMM : intfCmm : Link 1/1/13 operationally up
1970 Mar 8 22:11:58.540 : CMM : intfCmm : Link 1/1/16 operationally up
1970 Mar 8 22:12: 3.80 : CMM : intfCmm : Link 1/1/12 operationally down
1970 Mar 8 22:12: 3.730 : CMM : intfCmm : Link 1/1/15 operationally down
1970 Mar 8 22:12: 3.860 : CMM : intfCmm : Link 1/1/14 operationally down
1970 Mar 8 22:12: 4.250 : CMM : intfCmm : Link 1/1/13 operationally down
1970 Mar 8 22:12: 4.610 : CMM : intfCmm : Link 1/1/16 operationally down
1970 Mar 8 22:12: 4.770 : CMM : intfCmm : Link 1/1/12 operationally up
1970 Mar 8 22:12: 5.410 : CMM : intfCmm : Link 1/1/15 operationally up
1970 Mar 8 22:12: 5.560 : CMM : intfCmm : Link 1/1/14 operationally up
1970 Mar 8 22:12: 5.910 : CMM : intfCmm : Link 1/1/13 operationally up
1970 Mar 8 22:12: 6.320 : CMM : intfCmm : Link 1/1/16 operationally up
1970 Mar 8 23: 3:39.350 : CMM : intfCmm : Link 1/1/24 operationally down
1970 Mar 8 23: 3:45.500 : CMM : intfCmm : Link 1/1/24 operationally up
1970 Mar 8 23: 3:51.610 : CMM : intfCmm : Link 1/1/24 operationally down
1970 Mar 8 23: 3:53.300 : CMM : intfCmm : Link 1/1/24 operationally up
1970 Mar 9 1:58:47.660 : CMM : intfCmm : Link 1/1/19 operationally up
1970 Mar 9 2: 1:25.360 : CMM : intfCmm : Link 1/1/19 operationally down
1970 Mar 9 2: 1:29.120 : CMM : intfCmm : Link 1/1/19 operationally up
1970 Mar 9 2:22: 2.370 : CMM : intfCmm : Link 1/1/19 operationally down
1970 Mar 9 3:41:23.520 : CMM : intfCmm : Link 1/1/19 operationally up
1970 Mar 9 3:47:17.780 : CMM : ChassisSupervisor : chassisTrapsAlert - RESTORE process started
1970 Mar 9 3:47:23.330 : CMM : ChassisSupervisor : chassisTrapsAlert - RESTORE process completed successfully
1970 Mar 9 3:48:50.610 : CMM : intfCmm : Link 1/1/19 operationally down
1970 Mar 9 3:48:53.550 : CMM : intfCmm : Link 1/1/19 operationally up
1970 Mar 9 3:52:52.980 : CMM : intfCmm : Link 1/1/19 operationally down
1970 Mar 9 3:52:54.880 : CMM : intfCmm : Link 1/1/19 operationally up
1970 Mar 9 3:53: 8.30 : CMM : intfCmm : Link 1/1/19 operationally down
1970 Mar 14 22: 9:49.850 : CMM : intfCmm : Link 1/1/1 operationally up
1970 Mar 14 22: 9:56.30 : CMM : intfCmm : Link 1/1/1 operationally down
1970 Mar 14 22: 9:57.760 : CMM : intfCmm : Link 1/1/1 operationally up
1970 Mar 14 22:10:31.940 : CMM : intfCmm : Link 1/1/1 operationally down
1970 Mar 14 23: 4:36.400 : CMM : intfCmm : Link 1/1/23 operationally down
1970 Mar 14 23: 7:37.310 : CMM : intfCmm : Link 1/1/23 operationally up
1970 Mar 20 3: 6:33.440 : CMM : SES : Authentication failure detected: user po
1970 Mar 20 3: 6:43.160 : CMM : SES : Authentication failure detected: user admin
1970 Mar 20 3: 6:57.710 : CMM : SES : Authentication failure detected: user in
1970 Mar 20 3: 7:44.720 : CMM : ChassisSupervisor : chassisTrapsAlert - CERTIFY w/FLASH SYNCHRO process started
1970 Mar 20 3: 8:12.200 : CMM : ChassisSupervisor : chassisTrapsAlert - CERTIFY process completed successfully
1970 Mar 20 3: 8:27.680 : CMM : healthCmm : NI 1/1 rising above memory threshold.
2022 Sep 20 3: 9:32.740 : CMM : ChassisSupervisor : chassisTrapsAlert - CERTIFY w/FLASH SYNCHRO process started
2022 Sep 20 3: 9:37.60 : CMM : healthCmm : CMMA chassis 1 rising above memory threshold.
2022 Sep 20 3: 9:45.800 : CMM : ChassisSupervisor : chassisTrapsAlert - CERTIFY process completed successfully
2022 Sep 20 3:16:28.0 : CMM : healthCmm : NI 1/1 falling below memory threshold.
2022 Sep 20 3:17:37.540 : CMM : healthCmm : CMMA chassis 1 falling below memory threshold.
2022 Sep 20 3:27:45.220 : CMM : intfCmm : Link 1/1/13 operationally down
2022 Sep 20 3:27:52.930 : CMM : intfCmm : Link 1/1/13 operationally up
2022 Sep 20 3:27:59.310 : CMM : intfCmm : Link 1/1/13 operationally down
2022 Sep 20 3:28: 0.970 : CMM : intfCmm : Link 1/1/13 operationally up
2022 Sep 20 3:32: 1.300 : CMM : intfCmm : Link 1/1/13 operationally down
2022 Sep 20 3:35:23.930 : CMM : intfCmm : Link 1/1/23 operationally down
2022 Sep 20 3:40:21.380 : CMM : intfCmm : Link 1/1/23 operationally up
2022 Sep 20 3:50:53.200 : CMM : intfCmm : Link 1/1/13 operationally up
2022 Sep 20 3:50:59.300 : CMM : intfCmm : Link 1/1/13 operationally down
2022 Sep 20 3:51: 1.0 : CMM : intfCmm : Link 1/1/13 operationally up
2022 Sep 20 3:52:21.110 : CMM : intfCmm : Link 1/1/13 operationally down
2022 Sep 20 3:52:30.930 : CMM : intfCmm : Link 1/1/13 operationally up
2022 Sep 20 3:52:37.310 : CMM : intfCmm : Link 1/1/13 operationally down
2022 Sep 20 3:52:39.10 : CMM : intfCmm : Link 1/1/13 operationally up
2022 Oct 3 2:59:18.990 : CMM : stpCmm : STP instance 0: Bridge has become new Root
2022 Oct 3 2:59:38.340 : CMM : ChassisSupervisor : chassisTrapsAlert - CERTIFY w/FLASH SYNCHRO process started
2022 Oct 3 2:59:47.920 : CMM : healthCmm : NI 1/1 rising above memory threshold.
2022 Oct 3 3: 0: 2.10 : CMM : intfCmm : Link 1/1/21 operationally up
2022 Oct 3 3: 0: 3.850 : CMM : ChassisSupervisor : chassisTrapsAlert - CERTIFY process completed successfully
2022 Oct 3 3: 0:47.960 : CMM : healthCmm : CMMA chassis 1 rising above memory threshold.
2022 Oct 3 3: 1:48.160 : CMM : healthCmm : NI 1/1 falling below memory threshold.
2022 Oct 3 3: 2:48.80 : CMM : healthCmm : CMMA chassis 1 falling below memory threshold.
2022 Oct 3 3:10:45.960 : CMM : intfCmm : Link 1/1/21 operationally down
2022 Oct 13 2:44:45.490 : CMM : SES : Authentication failure detected: user admin
2022 Oct 13 2:44:57.80 : CMM : SES : Authentication failure detected: user admin
2022 Oct 13 4:46:37.880 : CMM : intfCmm : Link 1/1/7 operationally up
2022 Oct 13 4:59: 8.310 : CMM : intfCmm : Link 1/1/7 operationally down
2022 Oct 13 4:59:12.550 : CMM : intfCmm : Link 1/1/7 operationally up
2022 Oct 13 5: 5:31.230 : CMM : intfCmm : Link 1/1/7 operationally down
2022 Oct 17 21:22:59.560 : CMM : intfCmm : Link 1/1/24 operationally down
2022 Oct 17 21:22:59.560 : CMM : intfCmm : Link 1/1/12 operationally down
2022 Oct 17 21:22:59.570 : CMM : intfCmm : Link 1/1/14 operationally down
2022 Oct 17 21:22:59.580 : CMM : intfCmm : Link 1/1/13 operationally down
2022 Oct 17 21:22:59.590 : CMM : intfCmm : Link 1/1/16 operationally down
2022 Oct 17 21:22:59.600 : CMM : intfCmm : Link 1/1/15 operationally down
2022 Oct 17 21:22:54.290 : CMM : ChassisSupervisor : chassisTrapsAlert - Power supply is OK: PS 1
2022 Oct 17 21:22:54.290 : CMM : ChassisSupervisor : The switch was restarted by a power cycle or due to some type of failure
2022 Oct 17 21:22:54.290 : CMM : ChassisSupervisor : chassisTrapsAlert - CMM startup completed
2022 Oct 17 21:23:12.970 : CMM : stpCmm : STP instance 0: Bridge has become new Root
2022 Oct 17 21:23:20.440 : CMM : vcmCmm : Virtual Chassis: Chassis 1 Role changed to Master
2022 Oct 17 21:23:20.460 : CMM : vcmCmm : Virtual Chassis: Chassis 1 Status changed to Running
2022 Oct 17 21:23:21.230 : CMM : ChassisSupervisor : Sending VC Takeover to NIs and applications [L6]
2022 Oct 17 21:23:25.230 : CMM : ChassisSupervisor : System Ready
2022 Oct 17 21:23:26.440 : CMM : intfCmm : Link 1/1/12 operationally up
2022 Oct 17 21:23:26.530 : CMM : intfCmm : Link 1/1/13 operationally up
2022 Oct 17 21:23:26.610 : CMM : intfCmm : Link 1/1/14 operationally up
2022 Oct 17 21:23:26.690 : CMM : intfCmm : Link 1/1/15 operationally up
2022 Oct 17 21:23:26.720 : CMM : intfCmm : Link 1/1/16 operationally up
2022 Oct 17 21:23:28.140 : CMM : intfCmm : Link 1/1/24 operationally up
2022 Oct 17 21:23:29.40 : CMM : intfCmm : Link 1/1/23 operationally up
2022 Oct 17 21:24:12.580 : CMM : healthCmm : NI 1/1 rising above memory threshold.
2022 Oct 17 21:24:43.450 : CMM : healthCmm : CMMA chassis 1 rising above memory threshold.
2022 Oct 17 21:26:12.820 : CMM : healthCmm : NI 1/1 falling below memory threshold.
2022 Oct 17 21:26:43.570 : CMM : healthCmm : CMMA chassis 1 falling below memory threshold.
2022 Nov 7 8:10:58.230 : CMM : intfCmm : Link 1/1/14 operationally down
2022 Nov 7 8:10:58.340 : CMM : intfCmm : Link 1/1/13 operationally down
2022 Nov 7 8:10:58.370 : CMM : intfCmm : Link 1/1/16 operationally down
2022 Nov 7 8:10:58.390 : CMM : intfCmm : Link 1/1/15 operationally down
2022 Nov 7 8:10:58.400 : CMM : intfCmm : Link 1/1/24 operationally down
2022 Nov 7 8:10:58.410 : CMM : intfCmm : Link 1/1/12 operationally down
2022 Nov 8 4:37:46.20 : CMM : ChassisSupervisor : chassisTrapsAlert - CERTIFY w/FLASH SYNCHRO process started
2022 Nov 8 4:38:11.460 : CMM : ChassisSupervisor : chassisTrapsAlert - CERTIFY process completed successfully
2022 Nov 8 4:38:26.140 : CMM : healthCmm : NI 1/1 rising above memory threshold.
2022 Nov 8 4:39:45.580 : CMM : healthCmm : CMMA chassis 1 rising above memory threshold.
2022 Nov 8 4:41:26.500 : CMM : healthCmm : NI 1/1 falling below memory threshold.
-> sh health
CMM Current 1 Min 1 Hr 1 Day
Resources Avg Avg Avg
CPU 5 8 3 3
Memory 81 80 79 79
-> sh slot 1/1 lanpower slot 1/1
Port Maximum(mW) Actual Used(mW) Status Priority On/Off Class Type
1 30000 0 Searching Low ON *
2 30000 0 Searching Low ON *
3 30000 0 Searching Low ON *
4 30000 0 Searching Low ON *
5 30000 0 Searching Low ON *
6 30000 0 Searching Low ON *
7 30000 0 Searching Low ON *
8 30000 0 Searching Low ON *
9 30000 0 Searching Low ON *
10 30000 0 Searching Low ON *
11 30000 0 Searching Low ON *
12 30000 1600 Powered On Low ON *
13 30000 1700 Powered On Low ON *
14 30000 1600 Powered On Low ON *
15 30000 1600 Powered On Low ON *
16 30000 1700 Powered On Low ON *
17 30000 0 Searching Low ON *
18 30000 0 Searching Low ON *
19 30000 0 Searching Low ON *
20 30000 0 Searching Low ON *
21 30000 0 Searching Low ON *
22 30000 0 Searching Low ON *
23 30000 0 Searching Low ON *
24 30000 1700 Powered On Low ON *
ChassisId 1 Slot 1 Max Watts 195
-1445 Watts Actual Power Consumed
1640 Watts Actual Power Budget Remaining
195 Watts Total Power Budget Available
1 Power Supply Available
'*' appending port maxpower indicates 4pair port operating in 2pair mode
this is my log we have a 6 omni switch the switches stop the lan power randomly. the above show lan power command was taken when the time of lanpower not deliver on ports, but the switch shows it gives lanpower. after reboot only it works. please assist me to rectify the issue.
-> sh health
CPU 5 8 3 3
Memory 81 80 79 79
This is a new topic than factury reset.
Do you have the newest release/uboot installed?
No, the switch running on earlier image only. if it upgrade to latest version is it possible to arrest the lanpower issue.
You need to try it with new image. There are known issues with this.
