Upgrade AP1301
zepeki
Upgrade AP1301
Post by zepeki »
Do you know how to update the AP Stellar 1321 terminals? In the folder where there are all the .bin of each terminal, there is no .bin for the AP Stellar 1321. There is no update for these terminals?
Thank you in advance for your answers,
Zepeki
ymilner
Re: Upgrade AP1301
Post by ymilner »
The AP1321/AP1322 binary is a common one; name is OAW-AP1320_4.0.4.xxxx.bin
zepeki
Re: Upgrade AP1301
Post by zepeki »
That's what I thought. But when I try to upgrade it with this .bin via the OV2500 it fails.
Thanks for your answer.
Re: Upgrade AP1301
Via OV you always need the zip-file. This is the origin delivered one with the bin-files of all AP types.
BR Silvio
Return to “OmniAccess Stellar Express”
