Good day,
I have one issue creating new users with new phone numbers in Omnivista 8770 OXE. So i am following one procedure that i have :
1.Right click number you need and export to modify for a new number
2.Change in the file the name + number + mac address of the phone you want to install (number can be found in like 86 places in the file, use notepad ++ to find and replace, example: 120 to 128)
3.Import the new file with new number and name and mac, after refresh should appear [/i]
But is not working, i have this log:
[4:25:44 PM] > Request 1 sent to B851.
[4:25:49 PM] > Request 1 completed on B851: 435 instance(s) received.
[4:27:02 PM] > Begin export in C:\Users\Omnivista\Desktop\Fitter.txt ...
[4:27:03 PM] > Exporting Users...
[4:27:04 PM] > Exporting Progr.Keys...
[4:27:06 PM] > Exporting Directory Keys...
[4:27:08 PM] > Exporting User Aliases...
[4:27:10 PM] > Exporting Dynamic State User...
[4:27:12 PM] > Exporting User Associated Sets...
[4:27:14 PM] > Exporting TSC IP User...
[4:27:16 PM] > Exporting 8&9 Series Parameters...
[4:27:18 PM] > Exporting Ith Profile...
[4:27:19 PM] > End Of Export.
[4:31:30 PM] > Performing first pass on C:\Users\Omnivista\Desktop\Fitter.txt ...
[4:31:30 PM] > It is not possible to import the User Associated Sets class.
[4:31:32 PM] > Performing first pass ...
[4:31:33 PM] > Import pass 1...
[4:31:33 PM] > Import of 'Users' class
[4:31:37 PM] > Import pass 1 failed.
[4:31:37 PM] > Import of 'Progr.Keys' class
[4:31:38 PM] > Import of 'Directory Keys' class
[4:31:39 PM] > Import of 'User Aliases' class
[4:31:42 PM] > Import pass 1 failed.
[4:31:42 PM] > Import of '8&9 Series Parameters' class
[4:31:44 PM] > Noe_Parameters Cannot be created
[4:31:44 PM] > Import of 'Dynamic State User' class
[4:31:46 PM] > Dynamic_State_Subscriber Cannot be created
[4:31:46 PM] > Import of 'TSC IP User' class
[4:31:49 PM] > Tsc_IP_subscriber Cannot be created
[4:31:49 PM] > Import of 'Ith Profile' class
[4:31:51 PM] > Subscriber_Profile Cannot be created
[4:31:51 PM] > Import pass 2...
[4:31:51 PM] > Import of 'Users' class
[4:31:56 PM] > Import pass 2 failed.
[4:31:56 PM] > Import of 'User Aliases' class
[4:31:59 PM] > Import pass 2 failed.
[4:31:59 PM] > Import pass 3...
[4:31:59 PM] > Import of 'Users' class
[4:32:02 PM] > Create \B851\Users::995
Lock 330 (Adv. MIPT Users): Soft. Protection Error
[4:32:02 PM] > Apply failed on '\Users::995'.
[4:32:02 PM] > Import pass 3 failed.
[4:32:02 PM] > Import of 'User Aliases' class
[4:32:05 PM] > Apply failed on '\Users::995\User Aliases::0'.
[4:32:05 PM] > Import pass 3 failed.
[4:32:06 PM] > End of Import.
If i am making the classic way, to create the user is working but i need to Set Type from ANALOG ( because only this i working ) to Mobile IPTouch and i have this error:
[4:36:52 PM] > Request 39 completed on B851: 0 instance(s) received.
[4:36:52 PM] > Set or change \B851\Users::995
Type modification not allowed
So, where i am wrong?
I cannot add new phone number in Omnivista 8770 OXE
Re: I cannot add new phone number in Omnivista 8770 OXE
So no enough licenses for Wi-Fi phones, this is the issue.
how to see available or free phone number
how to see available or free phone number using omnivista?
- frank
Licenses are not a question of free numbers.
Use spadmin command , option 2 , to look at your licenses and current usage
If they're alredy managed you found them under system
ther System Param. ISDN Basic Call Control IE x
x SIO Parameters Dynamic gain for port class x
x Timers Z2 Board Dynamic Parameters x
x Tones Z2 Board Initialization Parameters x
x Voice Guides Flash Voice Guide Configuration x
x Incoming Greeting Guides CLIP Timers x
x Alarm Set SOSM GW Parameters x
x Remote V24 Box Licenses x
x V24 Port x
x UA Set - Audio Parameters x
x PWT/DECT Audio Parameters (dB) x
x Z Board Audio Parameters x
x Tone detector Parameters x
x Migration Interfaces Config x
x Free Adresses x
x Free Numbers Ranges List x
x Free Directory Numbers x
x Dynamic Voice Guides x
x Broadcast
if not, go to user and make a filter to select users with analog or digital set type and physical adress 255 255 255
