Hi ,
I would like to install alcatel 08 eight swich OS6465-P6 in envirment with 50° temperature , each 20 km , it will be install one using SFP module .
What do you advise me ?
Thanks in advanced
Swich alcatel OS6465-P6 , Advise
Re: Swich alcatel OS6465-P6 , Advise
I'm not sure that I understand but.
In those temps you need to make sure the following:
Use a power supply that can handle the heath.
Use the correct SFP's, Industrial temperature range would be best.
As well for the SFP's it is best to use 40km's as a 20km sfp is not a standard.
I hope this helps.
I hope this helps.
thanks for your helps
I am loking if any one had an exprience , they used this type of industires swichs and in in these climatic conditions of installation.
best regards
best regards
ACFE R10.0
mokhtar.belkhiati@gmail.com
- Gleylancer
The OS6465 is a hardened switch, its operating temperature is -40°C to 75°C, so it will have no problems.
