Hello all,
I will need the preocedure to upgrade Omnivista multiuser ver. 2.1 to a new version 3.3
Thank you in advance
Omnivista Upgrade
Re: Omnivista Upgrade
From the release notes (you should have received this from your BP when you received OV):
Benny
Hope this is what you need.3.5 Upgrade Procedures
You do not have to uninstall the old installation prior to installing the new package. You may upgrade your old installation of OmniVista 3.0 or 3.1 by installing the new package over the old installation. Performing an upgrade installation will preserve user-specific data and configuration. In this way, you get the benefits of the new release and continue to use your existing data as before. For Windows and UNIX: The installation program will detect the old installation (3.0 or 3.1) and will offer to install it in your old installation directory. If you accept it, you will be able to use the data from your old system.
Note: It is recommended that before the upgrade, you stop the OmniVista server and back-up the data (e.g., "C:\Program Files\OmniVista 2500\data"). Use the Server Backup application to perform the backup.
3.5.1 Copying the "Data" Directory from OmniVista 3.0 or 3.1 to 3.3
To upgrade without giving up the current working configuration, copy the data directory and all of its files from an OmniVista 3.0 or 3.1 server to an OmniVista 3.3 server.
1. Stop the OmniVista 3.0 or 3.1 server.
2. Rename the data directory located in the C:\Program Files\OmniVista 2500\ directory on the OmniVista 3.0 or 3.1 server to something other than "data" (e.g., "data3_1").
3. Copy the data directory located in the C:\Program Files\OmniVista 2500\ directory on the OmniVista 3.0 or 3.1 server to the C:\Program Files\OmniVista 2500\ directory on the OmniVista 3.3 server.
4. Copy the openldapdb folder and all of its contents from the directory you created in Step 2 (e.g., "data3_1") to the C:\Program Files\OmniVista 2500\data\ directory on the OmniVista 3.3 server.
5. Remove the data\mibs\mibsets.txt file. (Any third-party MIB sets must be re-imported.)
6. Restart the OmniVista 3.3 server.
7. Restart OpenLDAP on the OmniVista 3.3 server.
Benny
Thank you Benny,
my problem is to upgrade from V2.3 to a 3.0, can you help me?
Well,
From the "OV 3.0 release notes":
Benny
Its the same for that release.... Just make a backup to be safe and everything will be fine.3.5 Upgrade Procedures
OmniVista 2.4.1 or 2.4.2 by installing the new package over the old installation. Performing an upgrade installation will preserve
before. For Windows and UNIX: The installation program will detect the old installation (2.3, 2.4) and will offer to install it in your
Files\Alcatel OmniVista 2500\data").
3.5.1 Copying the "Data" Directory from OmniVista 2.3 or 2.4 to 3.0
To upgrade without giving up the current working configuration, copy the data directory and all of its files from an OmniVista 2.3 or
2.4 server to an OmniVista 3.0 server.
#. Stop the OmniVista 2.3/2.4.server.
#. Rename the data directory located in the C:\Program Files\OmniVista 2500\ directory on the OmniVista 2.4. server to
something other than "data" (e.g., "data2_4_1").
#. Copy the data directory located in the C:\Program Files\OmniVista 2500\ directory on the OmniVista 2.4 server to the
C:\Program Files\OmniVista 2500\ directory on the OmniVista 3.0 server.
#. On the OmniVista 2.3/2.4 server, copy the openldapdb folder and all of its contents from the directory you created in Step 2
(e.g., "data2_4_1") to the C:\Program Files\OmniVista 2500\data\ directory on the OmniVista 3.0 server.
#. Remove the data\mibs\mibsets.txt file. (Any third-party MIB sets must be re-imported.)
#. Restart the OmniVista 2.3/2.4 server.
#. Restart OpenLDAP on the OmniVista 3.0 server.
Benny
Many thanks Benny,
now I have a old installation of Multiuser 2.1, the customer need to upgrade to 3.3. The procedure is the same or I have to upgrade to 3.0 or 3.1 and after to 3.3.
Thank you in advance and have a good day
- Create a backup as described above
- Follow the same procedure as above ... (I do not see any blocking points why it should not work.)
Benny
Benny
good night,
i need test lab in the soft OmniVista.
you could send me a demo license of OmniVsta
peu@olitel.com.br
sorry for my English.
Thank very much
peu@olitel.com.br
Thank very much
This is an Alcatel(-Lucent) user community - not Alcatel-Lucent.
Contact Alcatel-Lucent for an official license.
Thanks.
Thanks.
a lisence DEMO seria para fazer um testar no labaoartorio
não é para cliente.
tranks.
não é para cliente.
tranks.
DEMO lisence to be to do a test in laboratory
is not for customers.
tranks.
tranks.
