Cancel Scheduled backups
songstadw
Post by songstadw »
I followed the manual to create a test backup to see how the process works and see what files are created. Two questions have come up.
1) Where are the backup files located?
2) How do you stop the schedule?
Neither topic seems to be covered in the manual.
Any guidance will be greatly appreciated since I set the schedule to hourly so as to generate data quickly.
-Bill
Thank you,
Bill
songstadw
Re: Cancel Scheduled backups
Post by songstadw »
I found where the backup scheduled is kept. Under Administration group -> Schedule. There you will find all the scheduled backups in a table called "Scheduled Task List". You can modify or delete the schedule.
Still haven't figured out where they store the backup data though.
Thank you,
Bill
Which version? You have opened the question in OV 3.5. This version is very very old and should be updated.
Return to “OmniVista 2500 v3.5”
