Guest Wireless with DHCP/DNS & NAT
benny
Post by benny »
I came across the following Youtube videos on this topic. Maybe it is interesting for you ...
English:
German:
Benny
nidal_malla
Re: Guest Wireless with DHCP/DNS & NAT
Post by nidal_malla »
I tried this scenario and there is the below problem :
- I can get IP address from DHCP only when I connect directly to the PVC , because the DHCP is located and worked only on teh PVC.
- When connecting to the same SSID but with un-PVC access point , I will never get dynamic IP address.
Alcatel-lucent Certified System Expert
at your switch ports (with attached access points) you have to tag the vlan of the SSID. And if the AP are at different switches you need to tag this vlan also at the switch connections.
dervodebayern
Post by dervodebayern »
what are Pros/Cons of having the AP do DHCP&NAT vs letting a Router e.g. Lancom do DHCP?
Im atm deciding between those scenarios.
Curious on your thoughts here,
Both is working. But if you NAT your wireless guest traffic f.e. at the AP mostly you need special policies to block this traffic to the company network. So I prefere to use NAT at a firewall/router. All the guest traffic are within a guest vlan and will be forwarded through whole the wired network to this gateway (and this is the dhcp server too).
best regards
dervodebayern
Allright.
Thanks for the answer!
Return to “OmniAccess Stellar Express”
