ARS timer issue with Route selection
sitig
Post by sitig »
Hi All
I have a problem with ARS and TBRL.
Scenario:
2 x Trunk groups
TG1 - Route 1 in ARS Table
TG2 - Route 2 in ARS Table
1 x TBRL
Primary - Route 1
Secondary - Route 2
User made first call, call is routed through Route 1, user hang up and make another call straight away, call routed through Route 2.
I noticed that if the user waited for a couple more seconds (can't figure out exactly), may 10-20 secs, the next call will be routed through Route 1.
What I wanted to achieve is calls to be routed through Route 1 always, Route 2 will only be used if Route 1 is either saturated or out of service.
Is there a timer that can be modified in the system to handle this issue?
I hope I've explained myself clearly. I've searched high and low on the forum but could not find anything related to my issue.
Cheers
Siti
Every adversity has within it a seed of an equivalent or greater benefit....
Re: ARS timer issue with Route selection
Some questions:
1 - TG type (ISDN, IP, analogue)?
2 - In ARS route - Low level signalling route (poor signalling) - not selected?
sitig
Post by sitig »
Hi Vad
Thanks for your response.
TG type is ISDN (PRI)
Low level signalling was selected. Should I remove this?
Cheers
Depends of your connection.
When you call subscriber (subscriber busy, no free channel...):
- if you receive (in t3 trace) - messages disconnect (User busy, Destination out of order, no circuit available ,.. etc) - not use "Low level signalling" in route.
- if you receive just busy tone (nothing in t3 trace) - use "Low level signalling", but you need some additional management (reed in system doc - about Poor signalling in ARS)
sitig
Post by sitig »
Oh OK, so the Low Level Signalling has nothing to do with Route 2 selected on the second call?
Just remove Low Level Signalling from route.
And read about Poor signalling in ARS (system doc)
sitig
Post by sitig »
Alright, will do that tomorrow and will provide a feedback.
Thanks a lot Vad.
Cheers.
sitig
Post by sitig »
Hi Vad
Removing Low Level Signalling did the trick for me.
Thanks a lot for your assistance.
Barrykeery
Post by Barrykeery »
You really do not need the Ready Response with that timer. That was really intended for a timer that has a prolonged reset sequence.
Return to “Translator”
