OTMC-V
munzik
OTMC-V
Post by munzik »
Hi all,
does anybody have experience with install OTMC to virtual server ?? ?
we tried it with last bootdvd-12.1.009.000-x86_64 and bootdvd-12.1.010.000-x86_64 ...
• Virtualmachinename:OTMC-V
• Operatingsystem: SUSE Linux Enterprise Server 12 (64 bits)
• Hyper-threadingmustbedeactivated: set theoptionHyperthreadedCoreSharing to None
• VMwareESXimustbe 6.0 , theVirtualMachineVersion 11( tried 10 too)
• CPU: 2 VCPUs
• RAM: 8 GB
• Network adapter: VMXNET 3
• SCSI controller: LSI Logic SAS
• Create a newvirtual disk – 105 GB (ThickProvision Lazy Zeroed) – SCSI (0:0)
then • SelectOpenTouchMessaging Center forVirtualizedInfrastructure (15000 users).
install was started, but in a part ´create partition plan ´ instalallation stopped by fault message:
device "" not found by storage backend
http://www.imgup.cz/image/Lh4n
if any idea, please reply
thanks
Re: OTMC-V
Try to change the drive type. Scsi, ide
munzik
Re: OTMC-V
Post by munzik »
Thanks Cavargnaro... I will try it and write result here
jigareda
Re: OTMC-V
Post by jigareda »
Hi munzik,
We had the same problem, it was about disk space. I had to put double size disk space, because I selected smooth updates in previous installation steps. I recomend you that use OTCP tool in order to size your system, then you should create your virtual machine with double space disk that OTCP said before.
munzik
Re: OTMC-V
Post by munzik »
Cavargnago : We tried to change SCSI controller, but the instalation was stoppet at the same time and message fault
Jigareda : Thanks ! It could be good idea.. we will try it with 250Gb size and let you know
munzik
Re: OTMC-V
Post by munzik »
installation with 250Gb HDD without problem , thanks :-)
Re: OTMC-V
Thanks for sharing
Return to “OTMC - OpenTouch Message Center”
