Auto Answer
steg81_DUP
Auto Answer
Post by steg81_DUP »
G'Day
Is there any way to have Auto Answer off in headset mode.
Stay Cool!!!
steve
Re: Auto Answer
Post by steve »
change the "Time before auto. conn. in headset mode" timer from 1s to 90s.
You can find it in the OMC: System Misc. / Feature Design / part4
steg81_DUP
Re: Auto Answer
Thanks a heap, Is there a way to have the handset ring sound a normal sound.
Stay Cool!!!
steve
Re: Auto Answer
Post by steve »
I'm not sure, but there are two timers for the auto answer in the ringing parameters (Memory read and write / Other labels parameters)
You can find this info in the Technical Communication N80 Noteworthy Addresses ed.06 file.
Return to “MAIN”
