SIP Trunk issue
SIP Trunk issue
Hi vad,
I have two oxe , in one system 26 sip n/w link lic & in other 81 sip n/w link lic and is connected through SIP Proxy.
But after 21 channel, I am getting congestion error on both oxe.
PLZ REPLY....,
PLZ REPLY....,
Rajkumaaaaaaaaaaaaaaar
Rajkumaaaaaaaaaaaaaaaaaar
Rajkumaaaaaaaaaaaaaaaaaaaaar
Re: SIP Trunk issue
You can have limitation - not only from licences but from management/hardware/provider requirements.
For example:
- you have no free codec (check with "compvisu lio" command) for voice on VoIP boards
- you have some limitation (f.e. IP/ IP domain) in your management
- may be exist some limitation from provider.
Make SIP trace.
For example:
Make SIP trace.
Re: SIP Trunk issue
Hi Seethram,
Are you getting any incidents in oxe while there is a congestion
Re: SIP Trunk issue
Thanks to all,
Yes i have a log of traced command
But i did not check incidents.
(1)sigma_as1> traced
** UNIX-trace-daemon started ... (static user group No 1) **
traced started ...
1493015264 -> IsIP_Phone neqt(5359) true
1493015265 -> INCMNGT:get_one_instance dom=0
1493015268 -> IsIP_Phone neqt(6809) true
1493015271 -> IsIP_Phone neqt(5599) true
1493015276 -> Mon Apr 24 11:45:13 2017 ALARM: 1148[CMotorCall::methodInviteReceived] Call failed, No license available
Mon Apr 24 11:45:13 2017 ALARM: CPU main
Mon Apr 24 11:57:03 2017 ALARM: 11c8[CMotorCall::methodInviteReceived] Call failed, No license available
Mon Apr 24 11:57:03 2017 ALARM: CPU main
Mon Apr 24 11:57:16 2017 ALARM: 11cb[CMotorCall::methodInviteReceived] Call failed, No license available
Mon Apr 24 11:57:16 2017 ALARM: CPU main
Mon Apr 24 11:57:23 2017 ALARM: [receiveInviteEvent] Call: eqt: 7676 INITIAL_STATE failed to emit an Invite message.
Mon Apr 24 11:57:23 2017 ALARM: CPU main
Mon Apr 24 11:57:23 2017 ALARM: [receiveInviteEvent] Call: eqt: 7406 INITIAL_STATE failed to emit an Invite message.
Mon Apr 24 11:57:38 2017 ALARM: [receiveInviteEvent] Call: eqt: 7685 INITIAL_STATE failed to emit an Invite message.
Mon Apr 24 11:57:38 2017 ALARM: CPU main
Mon Apr 24 11:57:38 2017 ALARM: [receiveInviteEvent] Call: eqt: 7406 INITIAL_STATE failed to emit an Invite message.
Mon Apr 24 11:57:48 2017 ALARM: [receiveInviteEvent] Call: eqt: 7685 INITIAL_STATE failed to emit an Invite message.
Mon Apr 24 11:57:48 2017 ALARM: CPU main
Mon Apr 24 11:57:48 2017 ALARM: [receiveInviteEvent] Call: eqt: 7406 INITIAL_STATE failed to emit an Invite message.
Mon Apr 24 11:57:56 2017 ALARM: 11dc[CMotorCall::methodInviteReceived] Call failed, No license available
Mon Apr 24 11:57:56 2017 ALARM: CPU main
1493015276 -> IsIP_Phone neqt(6696) true
1493015277 -> IsIP_Phone neqt(5205) true
1493015278 -> INCMNGT:get_one_instance dom=0
1493015280 -> Mon Apr 24 11:57:57 2017 ALARM: [receiveInviteEvent] Call: eqt: 7685 INITIAL_STATE failed to emit an Invite message.
Mon Apr 24 11:57:57 2017 ALARM: CPU main
Mon Apr 24 11:57:57 2017 ALARM: [receiveInviteEvent] Call: eqt: 7406 INITIAL_STATE failed to emit an Invite message.
Mon Apr 24 11:58:00 2017 ALARM: 11e1[CMotorCall::methodInviteReceived] Call failed, No license available
Mon Apr 24 11:58:00 2017 ALARM: CPU main
1493015282 -> IsIP_Phone neqt(746) false
(1)sigma_as1> timed out waiting for input: auto-logout
traced started ...
Re: SIP Trunk issue
Analysis
This could result of two things :
-number of SIP licenses are under estimated
-Licenses are not released in some particular scenario and after a while, the number of available licenses is not enough to path though the traffic peak.
It has been found that for some particular scenario involving CANCEL method, licenses might not be released.
Solution
In such case ( no incoming or outgoing call possible) dhs3_init –R SIPMOTOR command will restart the sipmotor (10 seconds) and all blocked licenses will be released.
This CANCEL scenarios has been fixed in :
crqms 00122575 : fixed in j1.410.62 and j2.603.28
crqms 00147196 fixed in j2.603.36 and k1.520.36
crqms00162224 fixed in k1.520.39 + External Services/trunk COS 31/ change T381 : from 2 to 20
Solution
Re: SIP Trunk issue
Topology:
SIP Provider --------------SIP ISDN-------------OXE
Environment:
j2.603.29.b
Issue:
In the SIP motor traces we could see the following
Fri Nov 21 06:02:08 2014 SEND MESSAGE TO NETWORK (213.213.213.213:16394 [TCP]) (BUFF LEN = 382)
SIP/2.0 403 No license available
numerous of incident like :
02/18/15 - 11:57:13 Minor alarm
11f6[CMotorCall::methodInviteReceived] Call failed, No license available
randomly users could not make or receive SIP calls.
Environment:
j2.603.29.b
Issue:
Re: SIP Trunk issue
Can you try above and let me know the feedback
Re: SIP Trunk issue
thanks hussain ,
I will restart sipmotor and also i will check sip dump.
But can any one guide me what are all the things i get in sip dump.
Re: SIP Trunk issue
The sipdump tool gives information about SIP calls and the SIP gateway. It’s useful in order to know in which
state the SIP calls are, to know which calls are handled by the SIP gateway, to release a call, to know the
inactive calls, etc…
