how i Can Disable Port NTP 123 On OXE
officiel-salah
Post by officiel-salah »
Hi ,
In the company our vulnerability scan software has Display This Message:
Vulnerability Svc: ntp
Vulnerability Port: 123
Problème de version service NTP
Solution : il faux un upgrade to version 4.2.8p9 ou bien supérieur
We have a OXE RELEASE 11
Someone has a solution For This Probleme ????
sadim
Re: how i Can Disable Port NTP 123 On OXE
Post by sadim »
it can be disabled using swinst
officiel-salah
Thank u Mr Sadim !
Is there no disadvantage if I stop the service?
sadim
Post by sadim »
Only if there are OXE ntp clients
Return to “Linux tricks”
