OV2500 web login
sb0526
OV2500 web login
Post by sb0526 »
hi,i already new install the ov2500 4.2
but i can't login the ov2500 from web,it is show "Login failed"
I'm sure my cliadmin password is correct
how to check this issue
Re: OV2500 web login
The login via web is not the same like cliadmin. There are a default user "admin" with same default password like all the omniswitches.
Return to “OmniVista 2500 v3.5”
