I've got a 4760 server that has not synced in the last month and now in restricted mode. Is there a way to re-sync?? the only options that i have on the screen are Directory and Scheduler tabs. Any help would be greatly appreciated.
tks
4760 in Restricted mode
Re: 4760 in Restricted mode
Hi cyberbric,
In reference, kindly see previous post and the technical document from David Macharia.
URL: viewtopic.php?f=274&t=18538&p=66164&hil ... ode#p66162
I hope this will help you resolve the issue.
Thanks,
Zero
Thanks,
Zero
Zero,
thanks very much for the link will try 2mo, thanks again pal
I'm also facing same error in Omnivista 4760.
An error appears says: "Omnivista will work in restricted mode due to license error." followed by "Global Synchronization: Time out: There is no global synchronization execute since too much time elapsed.
Ping Ok
I've followed all the steps as indicated (TECHNICAL COMMUNICATION No. TCV062)
(Run 4760/bin/ntsvcexClient.exe with complete synchronization)
Trying with IP Number and Name of PC-server.
but still no luck
i attach the log of last complete synchronization (Failed attempt)
and text of license file (nmc.license)
You help will be much appreciate. Thank you!
Ping Ok
but still no luck
Can you restart the nmc services after that restart the PC and make one synchronization with OXE and let me know the feedback
Please find the attachment try with this and let me know the feedback
