Auto answer on user set
sofia.oikonomou
Post by sofia.oikonomou »
I need some help, about setting auto answer on/off, from a 4012 or 4035 set. I tried with the mute button but it won't work. I don't want to have headset function.
Thanks,
Sofia
Re: Auto answer on user set
Auto answer on/off - mute key from the idle state (but only if in the phone feature cos managed item "rights Interphony=1").
Set can answer to local calls.
If on set present key (headset) and pressed - set will answer to external incoming calls too.
sofia.oikonomou
Thank you!
tommyphelan
Post by tommyphelan »
Im using R9.1 OXE.
i set auto answer on my 4068 handset and local calls are auto-answered.
but extenal calls dont auto answer.
i dont undertand the instruction below :
"If on set present key (headset) and pressed - set will answer to external incoming calls too."
do you know how i get external calls to auto answer on my 4068 ?
knightrider
Post by knightrider »
what the instruction tries to tell you is: If you have a headset key programmed on one of your programmable keys and it is activated, or turned on, then external calls will auto-answer too.
HTH..
Return to “Users”
