External Bell ringer for 4028/ 4018 handsets
Ask your questions, regarding data or voice!
objohnuk
Post by objohnuk »
Hi All
Im looking for an external bell ringer for IPtouch handsets. There is an RJ11 socket on the bottom of the phone that has a symbol of a Bell on it that i presume is for an external bell ringer.
There seem to be some posts on the interweb that relate to an Alcatel device but it seems it doesnt come with an actual bell in it which seems a bit pointless to me!
Has anyone got anny idea of what i should buy?
The requirement is simply to have an external bell ringer on these phones. we can do it with analogue phones easy enough with inline devices
there is a post here: http://old.alcatelunleashed.com/viewtop ... f=16&t=695, but it seems to be for digital UA phones not IP handsets.
Many thanks in advance to all constructive replies
enio.eltz
Post by enio.eltz »
Hi there
That RJ11 socket has a low tension, something between 1,7 VDC and 2 VDC.
We use 220VAC bells with an interface between IPtouch and the bell.
Regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
objohnuk
Post by objohnuk »
Thanks very much for the reply - would you mind letting me know the actual products you are using so that i can find them?
murraya
Post by murraya »
hi see post
http://old.alcatelunleashed.com/viewtop ... ernal+bell
I uploaded a circuit I designed a few years back but It may work on ipp as well.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
3gv28050aa external bell interface module oem
objohnuk
Post by objohnuk »
thanks for that - im sure it will mean something to someone in my engineering department!
I'd still like to buy an ' off the shelf' product though if anyone knows of anything. it seems a bit daft that Alcatel put a bell symbol on a port on the bottom of the phone and then dont have a product to use on it - or am i missing something? :confused:
That is "off the shelf" product. 3gv28050aa is the Alcatel part number.
objohnuk
Post by objohnuk »
Thanks to everyone. We'll be going ahead with that.
Pierre_armen_fr
Re: External Bell ringer for 4028/ 4018 handsets
Post by Pierre_armen_fr »
Hi everyone, i up the status. i actually work in an entreprise and my superior ask me to find a cheap solution to link lot of IP 4018 to an big bell for each. I found on internet and and old post the official product from alcatel but i think it's not an efficient solution because the production was stoped. So, someone have this last was posted up in here data ?
morio
Post by morio »
if you have network for analog. best is to creat a analog set to ring in parelell and fix a external ringer to it. but i am searching for a solution as well in 2023..
Return to “Pre-Sales”
