Compvisu on GA Card Shows Busy as "OFF, no TG!!
SteveRB
Post by SteveRB »
The display is shown below. What I want to know is what does no TG!! mean. I thought it may be related to trunk groups but this makes no sense to me as why would a GA card carebaout a trunk group. Any help would be appreciated.
| C O M P R E S S O R S T A T E Coupler type : GA, (1-1) MADA3 |
| Coupler state : IN SERVICE |
| - compvisu - Busy : OFF, no TG !! |
| | TS : 4 5 6 7 8 9 10 11 12 13 14 15 17 |
|PCM| Neqt : |
| 0 | Comp : . . . . . . . . . . . . . |
| | TS : 18 19 20 21 22 23 24 25 26 27 28 |
|PCM| Neqt : |
| 0 | Comp : . . . . . . . . . . . |
| Max Nb Compr Allowed SIMULTANEOUSLY : 24 |
| Compr State: X = unusable, . = Free, OS = Out Of Service |
| IP Device : CI = Local IP Phone, CR = Local Remote |
| RTP Direct : CG = Comp used:Flux RTP on GW, FI = Comp Free:Flux RTP on IPP |
| Fax Over IP: TF = T38 Fax |
| Transparency over IP : M = Modem, D = Data |
tincho.rn
Post by tincho.rn »
Hi. For H323 TG, you assiged it to a GD, GA or INTIP. Regards.
Return to “MAIN”
