Upgrade to 8.1.0.b5031
just a joke
I tried to make a little joke: The guy is not my friend and it was not Andi but I got often help from ALU support and so I call them "my friends"
Arno
Arno
Haven´t you attend any Teamwork course? How Is it possible to do e-SR without ACSE?Arno wrote:Hello, thank you for your reply.
The problem with the slow websites was not solved - I forgot to configure the Outbound SIP Proxy (OXE), now it is solved.
Arno
BR
Daniel
I have installed the latest rel 8.1.0.b5248 from scratch, i can't construct VM. entered windows 7 prof key and office keys but windows installation doesn't start.
For this reason i have started manually, in VMWare windows 7 is not present thats why installed windows vista and after that installed 2007. still presentation are not playing says in queued.
Any one can help on this...
Re: root password
We recently had an employee quit and we have a new MTW install running with no users configured. We dont seem to have the root password. Opening an eSR is the only way?agiftel wrote:Only alcatel support can generate root password. It depends on serial number of ACS server and mtw license. :-(
When two elephants fight, only the grass gets hurt.
Re: Upgrade to 8.1.0.b5031
MTW is an "Appliance". That means you have no root access to the OS. You can manage only an application that runs on that server and for that you do not need root access. You need only administrator password for MTW - default admin password you can find in the MTW's Installation guide.
@ Arno
"MS Windows 7 prof. (single key, no muli key supported)" - multi key IS supported. You just need to raise an e-SR with ALU and they can edit the unattend.xml.in file to accept multikey.
