OmniSwitch 6400 details
Locked
benny
Post by benny »
Alcatel-Lucent - What they say about their product: wrote:The Alcatel-Lucent OmniSwitch 6400 (OS6400) Stackable LAN Switch is a layer-2+ Gigabit Ethernet LAN switch addressing the small and medium-sized business needs for converged voice, data and video networks as well as residential and business Ethernet access service provider requirements.
The OmniSwitch 6400 is optimized for flexibility, scalability and low power consumption, and utilizes the Alcatel-Lucent Operating System (AOS) to provide an outstanding edge solution for a highly available, self-protective, easily managed, and eco-friendly networks. The OmniSwitch 6400 family has several models with a choice of port/features option combinations to fulfil the majority of fixed configuration switch requirement.
Port/Feature configurations:
  • Non-PoE Models - OmniSwitch 6400-24 and OmniSwitch 6400-48
  • PoE Model - OmniSwitch 6400-P24 and OmniSwitch 6400-P48
  • Fiber Model - OmniSwitch 6400-U24 and OmniSwitch 6400-U24D
References:
Alcatel-Lucent Enterprise web site / OmniSwitch 6400
Pictures:
Alcatel-Lucent OmniSwitch 6400-24, 24-port 1G copper model
Alcatel-Lucent OmniSwitch 6400, OmniSwitch 6800 and OmniSwitch 6850 Stacking Cables (common across all those platforms). Available in 30 cm, 60 cm, 150 cm (and 300 cm for 24-port models only).
Image If you would like to see your product pictures here, you may contact me via PM.
Locked
Return to “OmniSwitch 6400”
